akais3000 wrote on Yesterday, 16:29:
I unfortunately have no electrical engineering experience or further indepth knowledge of how displays work, but from my naive point of view, it can't be that hard to get a modern driving board capabable of delivering HDMI and DP and a chinese manufactorer of 4:3 IPS panels to work together.
There is a Russian forum that hacks lcd tv/monitor firmware and junction boards.
There is believe it or not a finite number of lcd panels and a more finite number of junction boards with a handful of strange junction boards that can control a few different panels types.
Years ago The final TV repair guy in town was swapping junction boards on some form of large monitor he got in bulk for pennies with a better junction board for some form of tv set that was compatible adding a tuner, HDMI and oddly smooth sub pixel scaling with blank insertion. He then could sell a non-proprietary moderately cheap gaming tv/monitor.
This is something that is done in China and Russia to improve the scrap/recycled stuff we inevitably send there and likely due to cost is pretty much completely ignored in the west.
Many limitations on old LCDs like bad scaling, poor resolution support, poor video input options, poor refresh rate support , lack of blank insertion could theoretically be improved with a new board , even a new firmware might help.
MagefromAntares wrote on Yesterday, 16:43:
I have suspected, currently no display panel manufacturer creates 4:3 panels with high refresh rates because there is no demand for it. I also asked him about the possibility of overclocking, and he basically told me to not bother with it, as display panels are large pieces of semi-conductor not small ones like a regular microchip, so overclocking a display panel is a whole degree harder than a regular IC, and as the panels produced typically tops at 80Hz for a 144Hz refresh rate that is a 80% OC, basically and practically impossible. He also remarked that the best possibility is with an OLED panel as OLED has the best response times of common technologies and the LEDs output the light directly so the chemical and electric properties of the liquid crystals present in other display technologies that uses a backlight would not interfere, but according to him the best OC result with them would be still only ~100Hz and he says that would still need a hand picked panel and custom driving circuitry, so not impossible but "very hard and with a lot of effort". So the best thing with modern technology is to run the game on a wide-screen panel and use a 4:3 resolution centred instead of stretched and trying to tolerate the two black bars on the side 🙁.
An LCD is more like a bunch of batteries that can charge or discharge at a specific rate, the tcon and junction board can affect the refresh irregardless of the panels physical reaction time, either by frame skip or by just clocking inputs faster or by inserting blank frames.
The belief that you can’t send more frames physical is mostly false, very old LCDs were maybe capable of 10hz but were almost always driven around 60hz, just had a lot of ghosting.
If you had a new tcon and junction board designed for vintage panels (I use 1600x1200) you could definitely eliminate all frame skipping issues on 70/72/75hz
With fancier electronics blank frames and higher refresh rates would open up also, just would have ghosting.
And believe it or not the 15-20ns response panels were the same panels that became 8-12ns panels just because of blank
