Best version of DOS
Reply 20 of 25, by aVd
IMHO SvarDOS is way better, than FreeDOS. As for compatibility... m$-DOS 6.22 for pre-386 CPU based systems, and 7.10 (or even ROM-DOS 7.10) for 386 and newer. PC-DOS 2000 (7.0 rev.1) is also good alternative to m$-DOS 7.10.
SvarDOS fan :: artificial "intelligence" bots - not a fan at all :: say NO to systemd :: is freeware a lie, when human freedom is a fundamental lie? :: f00ck €u!
Reply 21 of 25, by keenmaster486
I will say that although I use DOS 7.1 on all my 32 bit machines, if the machine is 16 bit I use DOS 5.0. DOS 7.1 won't even boot on a 16 bit machine.
I think I might have a couple of machines that I put DOS 3.3 on though.
The real advantages or disadvantages for older machines like that have to do with the utilities. EDIT is nice to have.
World's foremost 486 enjoyer.
Reply 22 of 25, by cyclone3d
MS-DOS 6.22 for most things before Win9x. For Win9x, the DOS that comes with it.
FreeDOS has too many issues with stuff that makes it too much of a headache to work with retro hardware.
Most people have forgotten this, but MS-DOS 6.22 was available for free via the MS ftp site as well as a host of other things before they took the ftp down.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 23 of 25, by maxtherabbit
appiah4 wrote on Today, 13:02:
theelf wrote on Today, 12:58:
PC-DOS 7.1, same compatibility MSDOS, FAT32 support even on 286 machines (maybe 8088 but never tested FAT32), very VERY reduced memory needs
Exelent DOS
Hello, fellow man of culture.
Gang PC-DOS
I generally use version 7 unless I need FAT32. The reduced memory use applies not only to the kernel, but also most of the commonly used installable device drivers. Vernon did a great job optimizing it.
Reply 24 of 25, by jakethompson1
cyclone3d wrote on Today, 16:20:
I recall the 6-to-6.22 "StepUp" upgrade being there, but not the full version.
Reply 25 of 25, by BitWrangler
jakethompson1 wrote on 45 minutes ago:
That is my recollection also, you had to have 6.0 already. Some folks claimed it worked on 5, but IDK if that was the download version or something they got from their OEM.
