First post, by zuldan
- Oldbie
I still remember walking into the computer store in 1999 and purchasing this board. For the life of me I cannot remember what I did with the board. The last time I have any memory of it was when it was sitting in my cupboard as a Linux server around 2004. Unfortunately, it's been lost to time. Recently I've had the urge to buy one and recreate the machine I had but these boards are crazy expensive these days. I came across this one going for pretty cheap (way too cheap for obvious reasons). The board has been in a fire. Probably sitting in a house fire. None of the plastic is melted but there is a layer of soot on the board. I'm guessing the board was decommissioned because the CPU sockets are covered in soot as well. I manage to read the BIOS perfectly so that's another a good sign that the board wasn't in direct heat of the fire. Here is the first interesting information. The board was running a PIII BIOS. There are also no shorts on the ATX connector.
File: Abit_BP6_-_W29C020.BINVendor: AwardVersion: v4.51PGString: 04/20/2000-i440BX-W83977-2A69KA1SC-RUSign-on: BP6 DUAL PIII BIOS V1.1 modified by ROBYSOFT 01-04-2002Metadata: [ACPI] DSDT FACP RSDT[DMI] [BIOS] Award Software International, Inc. 4.51 PG 03/29/00[Board] <http://www.abit.com.tw> i440BX-W83977 (BP6)[CPU] SLOT 1 Intel INTEL(R) CELERON(TM)[ID] Award Modular BIOS v4.51PGROMs: [1103:0004] HighPoint HPT366/368/370/370A/372/372N
Here are the pictures from the seller. I have since received the board and gave it a deep clean using a chemical I use for ultrasonic cleaning (just a hand wash though). The soot came off pretty easily. It then got a soap bath. It's now drying under a fan. I'll get some high res images of the board once I get some sunlight.
