Reply 140 of 231, by DustyShinigami
- l33t
MagefromAntares wrote on 2026-06-07, 16:13:DustyShinigami wrote on 2026-06-07, 15:09:I think the default refresh rate of 60Hz is set, though I'm using PS/2 Rate, which is set to 100Hz. Not sure if that's overriding anything...?
I have a bit of trouble understanding this part of your post, PS/2 rate should adjust the mouse refresh rate and shouldn't adjust the refresh rate of the display system.
Yeah, ignore this. I wondered if it was affecting/changing the refresh rate, but it's not.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
