Reply 59240 of 59246, by Shader_BiH
- Newbie
Dan386DX wrote on 2026-06-11, 04:08:zuldan wrote on 2026-06-10, 19:56:Shader_BiH wrote on 2026-06-10, 19:35:Meanwhile I ordered a pair of those ATX to AT PSU connector converters... I've read somewhere that they are perfectly fine to us […]
Meanwhile I ordered a pair of those ATX to AT PSU connector converters... I've read somewhere that they are perfectly fine to use as long as you have strong 3.3 and 5v rails... I guess I'll find out 😁
Those converters are great. I use them in all my 386 and 486’s. Connect those 2 leads directly to the 4 pin power switch of your AT case. Also much safer than having mains (120v/240v) going to the power switch.
I agree, I swear by them; I like to keep the hardware as period correct as possible but it's hard to trust a 35 year old PSU if it's not been recapped/refurbished lately.
The only problem with these, is that those four metal terminals behind the power switch can vary in size, I've had to modify the connectors on the adaptor to make them fit before.
Yes those can be tricky... but then again, that's a much easier DIY correction than hack-jobbing entire ATX to AT connection 🤣 I'm just happy people make these and you can get them brand new. Concerning old PSUs... every time I use them it feels like gambling on a slot machine, but regardless, PSUs from 95-2000 proved to be much higher quality than those from 2001-2005, at least in my experience. I had so many MS and Codegen PSUs blow up... and those like "brands" from early 2000s era, they must have got those bad capacitors as well. (and I'm not even considering inherent bad design here...) Recently I got a pentium mmx rig with very old Seasonic PSU and it works great... checked inside, no bad caps, at least visually.
