Let's make some memories (SIMMs)
Reply 20 of 33, by Teti
Hi guys, I have processed a lot of data to generate out my database of vintage SIMM and SIPP DRAM chips and modules:
http://martenelectric.cz/simm-sipp-ram-chip-database.html
This should be handy for those brewing at home 😀
www.martenelectric.cz | https://www.youtube.com/MartenElectric
Vintage audio gear connoisseur, computer enthusiast, time-nut, music lover, vintage games gamer, nerd, tinkerer and shady electronic projects maker
Reply 21 of 33, by Thermalwrong
Great choice of font 😀
That's quite handy for me right now, so thank you for putting this together! I'm making an AMD InterWave GuS clone card and it'll have 8x 4Mx4 modules to get its full 16MB of RAM. This list should make finding parts much easier - right now I'll just be destroying 16MB 72-pin EDO SIMMs (though that is likely the most cost effective way overall).
Looks like a superb tool for telling which RAM is EDO and which is FPM as well.
Reply 22 of 33, by BitWrangler
Thanks for that ref, very handy.
xtgold wrote on 2020-03-07, 16:29:
1 meg simm kit from the 1980's
I would strip the 1meg x1 dram chips from defective 286 motherboards
I think it was Maplin Electronics in the UK had a SIMM kit, but with the chips supplied, by the time they had it ready and in the catalog, it was 30 pounds vs 20 pounds per regular 1MB SIMM assembled.
Reply 23 of 33, by Teti
Thermalwrong wrote on 2022-01-02, 16:20:
Yes thank you, I've put some serious work into this and I'm glad this will be put in good use 😀
Please let me know if you need datasheets, I should have most of them. As always confirm with datasheets prior to use of chip ( ͡° ᴥ ͡°)
Reply 24 of 33, by JDW
UpLateGeek wrote on 2020-03-05, 10:10:
Larger capacity 30 pin SIMMs (e.g. 4MB) are pretty hard to come by where I live, so I've decided to make my own!
When I upload a ZIP file of your Gerbers to PCBWay, it doesn't automatically show the correct PCB thickness. It sticks with the default 1.6mm. I've had issues with BMOW's ROM-inator II ROM SIMM (for SE/30) in the past due to it being too thin (thinner than stock ROM SIMMs, I mean), so when making 30-pin RAM PCBs using your Gerbers, it's critical to get the thickness correct.
I measured the thickness of some old 1MB SIMMs with precision calipers and found that, when measured across the pads, the PCB is 1.35mm thick. On yet other 1MB SIMMs I am measuring about 1.2mm across the pads. PCBWay allows selection of 1.2mm or 1.6mm, with nothing in between.
Am I correct in assuming you choose a PCB thickness of 1.2mm?
Reply 26 of 33, by JDW
Tiido wrote on 2022-05-20, 22:46:
Yes, you need 1.2mm
Thank you for confirming that a 1.2 mm PCB thickness will not be too thin for use in vintage Macs. I appreciate it.
Reply 27 of 33, by ayandon
Teti wrote on 2022-01-02, 14:32:
This is an awesome list. Very very informative.
My knowledge in retro hardware is very limited because I was a kid at that time.
I have some memory kits (belongs to my late father) with ICs that may not be in your list (I am not sure about it).
I have attached the images of these memory kits (two different sets - GoldStar, HY & VT)
I want to restore my late father's 1st ever computer IBM ET&T PC-XT that he gifted me.
Hope you will be kind enough to guide and support me to restore his loving memory.
Reply 29 of 33, by rasz_pl
I remember seeing someone making 72pin sodimms, does anyone remember the URL?
Reply 30 of 33, by 486guy
This thread answers a lot of questions for me about using a 30-pin SIMM memory. I wasted a lot of time trying to use and test a 486 motherboard with a 30pin memory from another working 486 motherboard. I can't get it to work of course because it's using EDO chips. Thank god I found this post.
IBM XT/AT USB Converter -- PS/2KB2USB
Reply 31 of 33, by zuldan
rasz_pl wrote on 2022-10-18, 19:41:
Did you ever find the link to the 72pin sodimms? I'd love to get hold of the Gerber files and get some made.
Reply 32 of 33, by zuldan
Made 8 of these chips today. 32MB for my 386's woot. Make sure you add the stencil to your PCBWay order. Stencil + Solder paste makes the process 10x easier and they look like they are from a factory.
I got these chips from Aliexpress, all worked perfectly https://www.aliexpress.com/item/1005005484137764.html
The attachment IMG_9058.JPG is no longer available
The attachment IMG_9057.JPG is no longer available
Reply 33 of 33, by Lostdotfish
I've been making memories over the weekend. I have made some 4MB simms and some 16MB simms for my AWE32 today.
Just wondering if there is a PCB design floating around anywhere for 8x2MB (using the same RAM ICs as my 4MB sticks)?
The attachment PXL_20260614_201650873.jpg is no longer available
