First post, by sonik
I've added i-force emulated device to dosbox.
It can map forces to a connected FFB device like a joystick or a racing wheel.
Can also map some forces as emulated rumble, compatible with many gamepads.
Immersion i-force 1.0 (serial + gameport)
Tested with Need for Speed Special Edition, DOS version.
Also tested with Immersion tester app (from https://www.driverguide.com/driver/detail.php … driverid=137120)
Immersion i-force 2.0 (serial only?)
Not tested at all
Both versions should be compatible with DOS and Windows.
Binary here:
https://github.com/sonik-br/dosbox-staging/releases
Windows only for now.
I hope to release source code in the near future.
Will be cool to see this being integrated into other PC emulators.
Got this list of i-force only games from Immersion site:
ABC's Monday Night Football
Air Warrior II
Descent 2
Extreme Assault
Fighter Duel SE
JetFighter Full Burn
JetFighter III
Need for Speed SE
Rocket Jockey
SODA: Off Road Racing
SpearHead
Unneccessary Roughness '96
Reply 1 of 3, by jmarsh
DOSBox is GPL. Binary releases without source code is a violation of the license. If you're going to make the binary available to other people you have to do more than "hope" to release the source code.
Reply 2 of 3, by sonik
Ok. Removed.
Until I get the source online.
