Socket A: Aiming for the Stars!!!
Reply 360 of 690, by supercordo
zuldan wrote on 2026-06-18, 17:41:
Thermaltake Volcano 11+ Cooler Xaser Edition - Pure copper heat sink https://www.ebay.com/itm/126561673010
Info and reviews https://www.newegg.com/thermaltake-volcano-11 … N82E16835106031
Bought it. There are now 9 available.
Reply 361 of 690, by cyclone3d
cyclone3d wrote on 2026-06-18, 16:40:
That is really strange. I've never had issues like that. Makes no sense. […]
PcBytes wrote on 2026-06-18, 13:49:
PSU: Chieftec GPS-350FB-101A (Delta, recapped), Corsair TX850M (v1, orange) […]
cyclone3d wrote on 2026-06-18, 13:40:
That sounds like something else is at play. Having that many components that refuse to cooperate is very suspicious. […]
Have you tried a different power supply? If so, what brand and model and gold old are the ones you have tried?
Has that motherboard been recapped?
Do you have another socket 462 motherboard you can use to test?
Motherboard uses Rubycons exclusively (no Nichicon)
Tested on 7N400 Pro2, same behavior across all T-Bred chips.
The dropping to a lower multiplier on some CPUs is normal behaviour.
Have you tried lower voltage on the T-Breds? Default voltage is max 1.65v. I wouldn't feel safe going over 1.85v with excellent cooling unless using sub-ambient cooling and even then that would only be for max speed runs.
You should be able to get at least a couple hundred Mhz extra at about default voltage.
Ok, looking up some more stuff since it has been so many years since I have had a regular T-Bird.
1. It sounds like the draw from the 5v rail is really high and most newer boards may have issues with powering them.
2. May / probably need heatsinks on the VRMs to keep them cool.
3. You want a PSU with 30A+ on the 5V rail. Higher than 30A is better.
4. Pushing that much amperage on 5v through the 20-pin ATX connector can be a problem and may overheat and possibly even melt the plastic on the connector - need to keep it cool. Making sure the connector has a really good connection should help somewhat.
5. Newer boards may not handle the multiplier as expected, even with the bridge unlock done.
6. Newer boards that have the 4-pin connector, have a different VRM design than those that don't. Those that don't have a much better design for 5v heavy loads. Apparently when converting those types of boards to accept power from the 12v connector, you get a much more efficient setup along with much cooler running VRMs.
Hmmmmm. Now I want to mod one of my ASUS A7N8X v2.0 boards.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 362 of 690, by zuldan
supercordo wrote on 2026-06-18, 17:56:
….now the rest of us will consult our wives 🤣
Reply 363 of 690, by supercordo
Good luck!!
Reply 364 of 690, by zuldan
supercordo wrote on 2026-06-17, 00:36:
zuldan wrote on 2026-06-16, 23:12:
supercordo wrote on 2026-06-16, 22:19:
This is what i have been using. It is compatible with Intel Pentium 4 (Socket 478, LGA775), AMD Athlon/Duron/Athlon XP (Socket A/462), and Athlon 64 (Socket 754/939/940).
It be going on my DFI LANParty UT nF4 Ultra-D when im done playing with Socket A. Socket 939 will probable be the next Aiming for the stars.
That thing looks so good. Unobtainium 🙁
Its one of my prized possessions.
I might be able to get a WB4 with WB2 socket 462 mounting kit. Do you think that would work?
Reply 365 of 690, by supercordo
zuldan wrote on 2026-06-19, 01:35:
Im not sure, the wb4 has the hose connector in the middle. If its a good price might be worth trying.
Reply 366 of 690, by zuldan
supercordo wrote on 2026-06-19, 02:03:
Unfortunately, it's ultra expensive so I'm going to try get the seller to test a 462 setup before purchasing. Trying to Google someone else with this sort of setup.
What's interesting is 3dguru mentions 462 is supported https://www.guru3d.com/review/zalman-reserato … -review/page-3/
Reply 367 of 690, by zuldan
I see what you mean by the hose connector being in the middle. Bugger!
I wonder if I could make my own little metal bracket to fit around the hose.
The attachment WB4 vs WB2.png is no longer available
The WB3 doesn't official support 462 (well from what I could tell). Are you using a bracket from a WB2 462 system?
Reply 368 of 690, by supercordo
The wb3 gold come with the bracket for 462. Its the bottom right setup in your pic.
If you use the provided bracket that goes around the pipe it might line up with the holes with the two metal brackets that are used on the holes on the motherboard.
Reply 369 of 690, by zuldan
supercordo wrote on 2026-06-19, 02:36:
Yes you're right. Hopefully it will line up. I could adjust the height with some washers.
Going to send the seller this pic
Reply 370 of 690, by geordiepingu
Very nice, very rare to see so many come up.
eBay reckons £146.28 incl VAT and Shipping to the UK for a pair (Roughly $193). My man maths priorities are struggling... Do I bite the bullet and get a pair, or do I go full man maths brave pill and invest a few hundred £ into modding a Dual Athlon MP rig with some modified Chinese waterblocks.....
geordiepingu wrote on 2026-07-05, 17:19:
All for the benchmarks!
Petrol head and serial PC tweaker
Reply 371 of 690, by zuldan
geordiepingu wrote on 2026-06-19, 07:49:
Think of it as an investment. You could probably sell it for double the price in a couple of years 😝
Reply 372 of 690, by zuldan
Would it be difficult to get a Zalman Reserator for the WB4? How rare are they? And what are you using with your WB3?
The attachment IMG_0297.webp is no longer available
Reply 373 of 690, by geordiepingu
zuldan wrote on 2026-06-19, 08:12:
Was also trying to hunt one of these down!!!!
Reply 374 of 690, by zuldan
I couldn’t help myself. I bought one. Seller offered US $41.25 (25.00% off)
Reply 375 of 690, by cyclone3d
geordiepingu wrote on 2026-06-19, 08:26:
That actually looks like a horrible design for a radiator. The efficiency in actually removing heat has to be terrible.
YMF7x4 Guide
Reply 376 of 690, by supercordo
cyclone3d wrote on 2026-06-19, 13:39:
When it came out it had very bad reviews. Good for holding ice water tho.
Reply 377 of 690, by supercordo
Im running a custom loop.
Reply 378 of 690, by The Sandman
...not giving up. In this moment there are two (maybe 3) mighty Boards floating around in germany.
266-MHz x 10 CL2 is the goal.
Reply 379 of 690, by supercordo
The Sandman wrote on 2026-06-19, 15:59:
Good luck!!!
