Socket A: Aiming for the Stars!!!
Reply 300 of 543, by tehsiggi
zuldan wrote on 2026-06-16, 05:47:
Gimme your water cooler and I won’t complain 🤣
Just checked the australian amazon for you.. https://www.amazon.com.au/Yeyian-Liquid-Cooli … 0/dp/B07PJRWLLX looks like it has the same pump than my MARS one. 😉
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 301 of 543, by cyclone3d
Have a Thermaltake SOrb cooler arriving in the mail (attached to a junk video card) that I will be putting on the 7950GT.
The stinky thing about the AGP 7950GT is that the cooler mounting holes are a 40x47.5mm pattern, which no aftermarket coolers support so I will have to mod or make a custom bracket anyway.
Also, good coolers for older video cards are even harder to find at good prices than good coolers for older CPUs.
Will also have to make a heat plate / heatsink plate for the RAM and bridge chip. I thought about cutting up the original cooler and using the plate form that but it isn't quite large enough to reach two of the required mounting holes in the card.
Then I will join the competition.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 302 of 543, by supercordo
cyclone3d wrote on 2026-06-16, 18:03:
Have a Thermaltake SOrb cooler arriving in the mail (attached to a junk video card) that I will be putting on the 7950GT. […]
Sounds like fun to me. Welcome to the fun.
Reply 303 of 543, by PcBytes
After some more fiddling I got the 7800GS working so, good news I guess 🤣
Bad news: one of the Bartons I have (the one on the NF7) is genuinely multiplier SUPERLOCKED - you CANNOT go lower or higher whatsoever. I found this while trying to do 10.5 x 245 FSB - CPU ignores it and does 11 x 245.
Good news: a few more Bartons showed up from my collection (including some Semprons) so idk, hopefully any of those work instead of the actual one I have.
Reply 304 of 543, by supercordo
PcBytes wrote on 2026-06-16, 20:16:
You still using the stock bios? That could be why.
Reply 305 of 543, by PcBytes
supercordo wrote on 2026-06-16, 21:07:
Nope, switched to digitalbath's modded BIOS, D27 ED55, POST sign-on is "D27 [ED55] vB4 NVDAMC 3.19".
Reply 306 of 543, by supercordo
PcBytes wrote on 2026-06-16, 21:09:
I have never heard of a cpu locked from lower multipliers before.
Reply 307 of 543, by Repo Man11
supercordo wrote on 2026-06-16, 21:12:
The Tbred B 2700+ that I have in the Soyo is the same - lower the multiplier in the CMOS settings and it won't POST again until you clear CMOS.
Reply 309 of 543, by PcBytes
Repo Man11 wrote on 2026-06-16, 21:22:
My Barton outright ignores any other multis than stock. It'll just enforce 11 regardless of settings.
Reply 310 of 543, by zuldan
tehsiggi wrote on 2026-06-16, 15:58:
Now that is tempting, thanks for that.
Reply 311 of 543, by supercordo
This is what i have been using. It is compatible with Intel Pentium 4 (Socket 478, LGA775), AMD Athlon/Duron/Athlon XP (Socket A/462), and Athlon 64 (Socket 754/939/940).
It be going on my DFI LANParty UT nF4 Ultra-D when im done playing with Socket A. Socket 939 will probable be the next Aiming for the stars.
Reply 312 of 543, by zuldan
supercordo wrote on 2026-06-16, 22:19:
That thing looks so good. Unobtainium 🙁
Reply 313 of 543, by supercordo
zuldan wrote on 2026-06-16, 23:12:
Its one of my prized possessions.
Reply 314 of 543, by supercordo
Was playing around with the Geode NX 1750. This is a fun chip!! All cpu overclock. Ill play with FSB tomorrow. Sorry Tehsiggi, I took your #1 spot for Thoroughbred cores.
Reply 315 of 543, by cyclone3d
I was trying to look into the digitalbath BIOSes, and it looked like they were mods that different timings were being tested with. What exactly do they do different than say a trats BIOS?
YMF7x4 Guide
Reply 316 of 543, by tehsiggi
supercordo wrote on 2026-06-17, 02:08:
Nice score.. So you are telling me i have to strap that poor Athlon XP 2400 onto the A7N8X now to come and try to get you? I am tempted. Especially since my FSB was way higher. Perhaps dual channel memory could get me a little closer. But that GPU is making it hard.
Reply 317 of 543, by zuldan
tehsiggi wrote on 2026-06-17, 04:15:
Maybe 3850's should be banned. They are way too fast 🤣
Reply 318 of 543, by supercordo
I could make a bracket just for 3850's. But then I would just use my gainward bliss 7800 GS+ 🤣
Reply 319 of 543, by tehsiggi
supercordo wrote on 2026-06-17, 04:40:
Nah, keep it that way. I like the back and forth. Honestly, I feel like a youngster again sitting there with my dad and oc'ing Athlon XP2100 and XP2000 together with him. He had a 6600GT, I had an X700AGP - it was a fierce battle and I fondly remember it. Systems are what they are.
Once you get to the tbred again, can you run SuperPi? That'll give me a rough feeling for how much I have to torture that poor Tbred 😁
