First post, by myne
Anyone with an x64 with an agp port feel like testing something?
Win10 2016 removed agp support.
As we all know, that should simply mean the drivers were removed from the iso.
So what I did was grab the drivers from 1507,rename one inf file to avoid overwriting and edit the other to match.
Theoretically, that should be all that's needed for 10 and 11 to re-add agp support. It also seems to have several references to Isa, so that may do something.
Details/method:
1 agp.inf points to several sys files and machine.inf
2 grabed those
3 renamed machine.inf to legacymachine.inf
4 edited agp.inf references to machine.inf
5 zipped
To test, 2 options.
1 Slipstream into iso
2 install fresh w10/11 and use device manager to update whatever the agp port shows up as.
In theory, everything that used to work should work again. I doubt Ms made any deeper architectural changes.
Agp is just an extended pci port, and pcie is a pci port with a serial layer 1. So it's hard to imagine removing support went too deep.
I built:
Reply 1 of 8, by myne
Anyone actually test this?
I built:
Reply 2 of 8, by old school gamer man
This would be a good thing to ask on hardware bot. A lot of folks there have agp 775 and am2 boards
Reply 3 of 8, by myne
Not a member, but if you are, feel free to link it.
I built:
Reply 4 of 8, by WinSxS
I had trouble running these drivers because of digital signature issues. I could only install 1507 and then upgrade to 11 23H2.
It works, but it's very glitchy. I had to turn off windows transparency because I couldn't see the new UI at all. So even though it was installed in the end, I can't recommend doing it.
Bad english? Don't mind, i'm still learning
Reply 5 of 8, by Living
WinSxS wrote on 2025-08-10, 19:58:
dont blame on this agp driver, its the fault of the last ever driver from nvidia that works with Geforce 6000 and 7000 on windows 10.
I get the same problem when i install in the igpu's (6150, 7025, etc), even when they are on pci express motherboards. It started happening on Windows 10 1909
Reply 6 of 8, by myne
Interesting. What were the signature issues?
Did I forget a file? Or do the signatures expire?
I built:
Reply 7 of 8, by OMORES
I recently tested an ATI HD4650 in Windows 11 on an ASRock 865PE motherboard (yes, running DDR1!).
You can see all the hardware and how the installation went here: https://youtu.be/vs4bqCEnvUA
I was actually surprised by how it turned out: you can successfully install the AGP bus driver (AGP440.SYS in this case), and the final 2012 Catalyst driver works fine with H.264 hardware decoding and OpenGL acceleration in Firefox.
3DMark 2001 scores: 18K with a Q6600 CPU. Not great, not terrible...
Also, the INFs circulating on the internet don't have any entries for Intel motherboards to load AGP440.SYS, so I've attached my modified INF containing those entries.
Classic Windows on modern hardware? Sure.
Reply 8 of 8, by myne
Heh cool. So it does work.
AGP440 is mentioned in the legacymachine.inf
Even your exact device
%CpuToAgpBridge_Desc% = AGP440_Install, PCI\VEN_8086&DEV_2571
I assume it didn't work as expected?
I built:
