First post, by Pluming
Hi there,
I came across this P4P800 Deluxe, but I am not sure what to make of it. It's described as working, but there's a bunch of white stuff around the CPU socket (thermal paste?), and it looks like they took the chipset cooler and placed on top of the socket.
I would appreciate the community's opinion on it. Is this worth cleaning, or might it be too tarnished? This is the one and only picture I am privy to:
Thanks.
Reply 1 of 5, by PC Hoarder Patrol
Pluming wrote on 2026-06-22, 21:56:
Hi there, […]
Hi there,
Thanks.
Looks OK, but not really clear enough to be definitive.
Looks like 2 of the 4 chipset cooler mount points (closest to the AGP slot) are missing.
Reply 2 of 5, by Pluming
PC Hoarder Patrol wrote on 2026-06-22, 23:43:
Hi there, […]
Hi there,
Thanks.
Good catch, thank you for pointing out the mounting points. I'll have to pass then.
Reply 3 of 5, by Repo Man11
Pluming wrote on 2026-06-23, 00:25:
Hi there, […]
Hi there,
Thanks.
Those are easily fixed, so if the price is right that shouldn't stop you. My Epox 8KRA2+ uses those, and one popped off one evening while the computer wasn't in use. I heard a noise inside the case, and when I opened it up the northbridge cooler was lying on the bottom of the case; finding that hoop was a challenge, but it was in there. Easily soldered back in place.
Reply 4 of 5, by jmarsh
I'd definitely pass on it, who knows what the CPU socket looks like under there...
Reply 5 of 5, by Pluming
Repo Man11 wrote on 2026-06-23, 00:56:
It's quite cheap. About $30 USD not including shipping. But after doing some research, there's also the issue of most Asus P4P boards having manufacturing defects/short lifespans. Ah well. Thank you for your input though.
