Retro Rig Photo Thread
Reply 3300 of 3312, by Law212
devius wrote on 2026-06-03, 20:31:
Seems a bit of a waste to use 2x Voodoo2 in SLI on a Pentium MMX. Do you really get any benefit from using SLI instead of a single card?
Higher resolutions and a small performance increase. Nothing like it would get if the voodoos were in a P2 300 or 400.
But for pentium 3 i have a voodoo 3 so im good there.
Its also just cool. That computer is running at 262 MHz and you can tell there is a slight but noticeable boost in framerate over the 233 .
I dont see it as a waste at all. I dont really need another system with a voodoo 2 . I have all eras of PC gaming covered that I want
Reply 3301 of 3312, by BadFox_1
It's kinda a RETRO RIG!
Anyone remember these! Such cool machines. I remember drooling over these in Best Buy around 1998 🤣!
This is my Sony Mavica MVC-FD85 which was released Feb. 2000. It was heavily marketed during that iconic Y2K millennium wave as Sony's premium "High Resolution" floppy camera. The FD85 was a massive deal because it shattered the standard ceiling by introducing a 1.3 Megapixel Super HAD CCD sensor, stepping image dimensions up to a sharp 1280x960 pixels. The Storage Strain: Because it was shooting true megapixel files onto an old-school 1.44MB floppy disk, the math got incredibly tight. At maximum image fine-quality resolution, a standard floppy disk could only hold about 6 images total before hitting full capacity. That exact restriction is precisely what gives the camera its authentic "digital film roll" nostalgia factor today. The FD85 handles modern 12-bit color rendering beautifully, features awesome internal legacy digital processing effects like "Negative Art" and "Sepia", and doesn't suffer from the grainy low-quality limits of the older 1997 models. I also own a MVC-FD73 which was a 1999 model that features the low-tier 1997 0.3 Megapixel (640x480) resolution. At Max Resolution ("Fine" Mode): Image files clock in around 35KB to 60KB each. This gives you roughly 25 to 30 photos per disk. In Standard Resolution ("Standard" Mode): It compresses the files down to around 20KB to 30KB, allowing you to squeeze a massive 45 to 60 photos onto a single floppy, Much better than the 6 on the FD85 🤣. Luckily the FD85 and newer models had a Floppy to Memory stick adapter for a dual media Format. Sadly I do not have the adapter it was probably lost in 2000.
Reply 3302 of 3312, by Intel486dx33
BadFox_1 wrote on 2026-06-08, 11:46:
Hey, I bought a used one a couple of years ago I think it works.
Do you have the PC software CD ?
I want to try out on my retro Sony Vaio laptops
Reply 3303 of 3312, by BadFox_1
Intel486dx33 wrote on 2026-06-08, 12:02:
Hey, I bought a used one a couple of years ago I think it workshop. Do you have the PC software CD ? I want to try out on my ret […]
I do not have the FD's CD YET. I will have the Mavica MVC-CD300 CD sometime this week... I wonder if the software package is the same?
Reply 3304 of 3312, by Intel486dx33
Yeah,
the problems I have experienced with old Sony cameras is that the capacitors go bad
And cause the cameras not to work anymore.
Let me find this old mavica and see if it still works.
It’s in storage in my garage somewhere.
Reply 3305 of 3312, by 2Buck
BadFox_1 wrote on 2026-06-03, 08:01:
I feel you. Sometimes we do dumb things thinking we are doing the right thing. I also had a Laser 128 WAY Back in the day sadly the cat pee'd on it and shorted it out. hahaha. The late 80's-90's was a magical time. GOOD LORD Vista Nearly 20 years.... Man I'm getting OLD! I remember my one and only experience with Vista since around that time i went FULL Apple. I bought a HP DV6000 laptop with a x2 Turion. everyone was griping about Vista around me I never had any issues and really enjoyed that laptop. It ran for MANY MANY years with the original Vista install... I've thought about putting Vista on my Athlon 64 Rig and I may one day is xp 64bit annoys me enough.
I actually have a Vista dv6000 that still runs! Although it runs a centrino and I don't have a history with it, I got it a few years ago. But it's a solid little machine! It's funny I've only ever used vista when I went out of my way to, in actuality I skipped from XP straight to 7. All my experience with vista has been positive, although I've run it pretty much only on ideal hardware!
i'm 2buck
939 Athlon 64 3700+ @ 2.53ghz, 2GB DDR400, PCIe x850XT, XP SP3, 64GB SSD
939 Athlon 64 x2 3200+ @ 2.75ghz, 2GB DDR400, PCIe HD 3850, W7SP1, 120GB SSD
Presario 4546, K6 233mhz, AudioDrive ES1887f, Trio64V2/DX, 48mb, w95, TX Bigfoot 4GB+120GB SSD
Reply 3306 of 3312, by 2Buck
Law212 wrote on 2026-06-03, 14:58:
I bought a desk off marketplace to put my retro PCs on. They were under my modern PC for so long and it was messy and cramped. N […]
I bought a desk off marketplace to put my retro PCs on. They were under my modern PC for so long and it was messy and cramped. Now i have a retro spot thats much better . I finished setting up the two Pentiums and setting up the desk last night. Though I need to clean up the wires.
The Comp on the left in the small case is a pentium 1 233 MMX running at 262 MHz. The motherboard is a TX97 With an ati rage pro and 2 Diamond Monster Voodoo 2 12 Meg cards in SLI. It also has an awe 32 with some extra ram.
The computer to the right in the tall case is a 486 DX 2, 66Mhz. It has an ati mach 32 1 meg video card and a Media Vision Jazz 16 running Dos 6.22 and i might add Win 3.1
The computer on the bottom is a Pentium 1 , 233 MMX with an ati rage pro, Vibra 16. I need to add a cd rom to it. I did have a scsi cdrom attached but i cant find the install cd right now .
Not pictured at my P 3, P4 and my other 486 DX 2 66.
absolutely lovely setup, love period correct desks, always brings it all together big time! Especially the desks with the shelves up top, just perfection!!! 😀
i'm 2buck
Reply 3307 of 3312, by Law212
2Buck wrote on 2026-06-08, 16:49:
Thanks ! I'm glad someone else appreciates that the desk is also period correct. I love this set up , I just need a good KVM set up but now I am enjoying my retro PC set up immensely
Reply 3308 of 3312, by RetroPCCupboard
Law212 wrote on 2026-06-09, 14:30:
I wish I could see it, but your chosen image host doesn't display images in the UK.
Reply 3309 of 3312, by RetroPCCupboard
Great cameras. I have the FD90 which is 1.6Megapixel, and two FD73 cameras. For the FD73 I also have an add on lens that can be used to do closeups.
The attachment 20260609_221823.jpg is no longer available
Reply 3310 of 3312, by BadFox_1
RetroPCCupboard wrote on 2026-06-09, 21:24:
They are a cool piece of history and I never thought about it but the original FD7 was $900 in 1997 and the FD5 was $600. I don't remember them being that much but they where and you'd think at those prices they wouldn't sell but in 1997 Sony FD5 and FD7 sold over 50% of all digital camera sales. They did so because in 1997 it took an act of god to transfer pics from your camera to your PC for Processing... The FD made it painless and the people LOVED it despite the price. I also now have a CD300 a CD400 and I bought a FD75 and a FD92 🤣 They are like Computers they are Multiplying 🤣 It's a SLIGHT Addiction I'd say... Here is a pic of my FD73.
Reply 3311 of 3312, by songoffall
Finally finished my year 2002 build.
The attachment 717960063_10164435185743839_6432392714511486711_n.jpg is no longer available
The specs are:
M/B: Intel 850MD
CPU: Pentium 4 2.0A Northwood
RAM: 512Mb Samsung PC800 RDRAM (4x128Mb RIMM)
Graphics: GeForce4 Ti4200
Sound: Creative SoundBlaster Live! 5.1 Digital
All this in a tiny MATX/SFF package with some case modes to provide adequate cooling.
I run Win98SE on this bad boy so I decided to go with SB Live! instead of Audigy2, because none of the games seemed to go past EAX2 and I'm not running Prey or Doom3 on this thing, not even HalfLife2.
P2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 HT 3.0GHz/GeForce FX 5500/Creative Audigy 2
Core2 Quad Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
Reply 3312 of 3312, by Lodge_
Asus B85M-E
Intel i7-4790K
16 GB DDR3
NVIDIA GeForce GTX TITAN X (Maxwell)
Auzentech X-Fi Prelude 7.1
512 GB and 256 GB SSD's.
XP / Windows 7 / Linux (Zorin OS) tripleboot.
Windows XP overkill or a budget gaming rig?
This build could be both. I call it “The Garbage” since most of the parts were salvaged from e-waste (apart from the GPU and the sound card). The name is also a nod to a location in the S.T.A.L.K.E.R. games. I use this rig to play slightly modern games on a CRT.
The motherboard might not be the fanciest, but it has a PCI slot for the sound card, which I really wanted to use, and Windows XP is officially supported by ASUS. I couldn’t make up my mind about the OS, so I installed three. Linux is there in case I ever want to use Steam for more modern-ish gaming. So far, I’ve been using Windows XP for pre-2010 games and Windows 7 for anything newer.
I think I’ve had this build for about two years now. During that time, I’ve played through the original S.T.A.L.K.E.R. trilogy along with a ton of different mods. I also enjoy playing these newer pixel-art point-and-click adventures like The Last Door and An English Haunting on this rig.
