IBM XT 5160 (project complete)
Reply 20 of 71, by JAKra85
8087-1 FPU has been added.
No real difference in SimCity observed. Will check later with some other tools.
Retro PC Gallery:
https://docs.google.com/document/d/1ara32t4rV … nU/edit?tab=t.0
Reply 21 of 71, by JAKra85
H3nrik V! wrote on 2026-06-18, 14:09:
JAKra85 wrote on 2026-06-18, 12:07:
- Turned on, measured voltages. All good. I got 10,8V instead of 12V and also got a bit sad at this point and less confident about this PSU... too late.
- Tested on a different low value AT board. Measured again, exactly 12.00V (and 4,99V).
- Important: with no load the 12V measures way less that 12V!
I would fear that the lower unloaded voltage could be a symptom of some regulator not working correctly - maybe from dried up capacitors?
I might have used a wrong phrase or wording here.
Unloaded not equal to powered on and idle state.
In this case I used "unloaded" as not connected to anything. With PSU powered on and AT pins P8 and P9 hanging in the air and measured voltage.
Upon further investigation this is natural as many classic power supplies require a load on the 5V or 12V rail to properly regulate and output correct voltages.
"- Tested on a different low value AT board. Measured again, exactly 12.00V (and 4,99V)."
Measured this by connecting to an AT motherboard, powered on and low load.
Retro PC Gallery:
Reply 22 of 71, by NeoG_
JAKra85 wrote on 2026-06-18, 14:50:
SImCity uses the FPU in specific circumstances, you wouldn't really see a benefit in moving around a map
https://michaeldale.com.au/archive/2026/06/07 … y-use-your-fpu/
(The usage is the same for original and 2000)
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 23 of 71, by JAKra85
NeoG_ wrote on 2026-06-19, 04:53:
SImCity uses the FPU in specific circumstances, you wouldn't really see a benefit in moving around a map […]
Good read!
I can confirm, not many games used FPU before Quake engine and even those that used it have no breathtaking uplift.
Google AI was misleading with up-to 50% increase... when asking for 8087 FPU upgrade. 😀
Pointed to a Reddit post with SimCity Classic with FPU +50% uplift, that Reddit post pointed to this Vogos entry:
Interesting findings with simcity classic
Yeah, but here it's a 386 with 387 FPU, not really comparable with 8088 with 8087 FPU.
I will do a bit more test and research.
I've read previously that the FPU can become hot, but damn... it's like dangerously hot. Thinking adding some heat sink...
I specifically choose 8087-1 with 10MHz, thinking that if the FPU is rated to 10MHz when running at 4,77MHz it will be cooler than the one rated to 5MHz.
Retro PC Gallery:
Reply 24 of 71, by Jo22
Software written using QB 4.5 does use a math co-processor, if available.
Examples:
https://www.youtube.com/watch?v=mYJ1IPph4tw
https://www.youtube.com/watch?v=FaQa9INqZf8
Edit: This might be of relevance in so far, because QBasic/QB had quite a community in 90s and early 2000s.
Many applications and games had been written using them, many websites had offered QB 4.5 examples and tutorials.
So depending on the situation, the QB runtime can make use of the x87 math co-pro.
Reply 25 of 71, by Irinikus
Very cool system! 😀
YouTube
Reply 27 of 71, by JAKra85
Jo22 wrote on 2026-06-19, 07:42:
Software written using QB 4.5 does use a math co-processor, if available. […]
Examples:
Thank you! I've done some benchmarking and now I am sure the FPU is there and working. That is enough for me.
The past few days I was thinking on the purpose of this system.
Now I have 2 (maybe 3) goals:
1) SimCity Classic "ultimate gaming machine" with mouse and playing on the original 5151 monitor. Running the game in EGA is barely playable, it does not matter if EGA mono or EGA color. Resolution matters.
2) Very simple e-mail sending station. I think it's cool to be able to send even a simple e-mail from the original PC to any modern device.
3) Copy files to and from; over the network. I had enough of floppies.
Any other ideas?
Don't forget I only have 10MB total and about 2MB free.
Retro PC Gallery:
Reply 28 of 71, by JAKra85
Double trouble!
The attachment 20260614_144213.jpg is no longer available
I have a back-up drive to this machine in case the primary dies (when it dies).
The one used right now is made in Singapore, the back-up drive is made in USA.
Tested it... and it was not working. Applied the same trick that is mentioned in the first post and now it works fine.
Drive had been formatted and copied the system files.
Booting. Put it aside in a safe place, not the attic (it gets too hot in the summer).
More pics:
The attachment 20260614_144300.jpg is no longer available
The attachment 20260614_144330.jpg is no longer available
The attachment 20260614_144428.jpg is no longer available
Retro PC Gallery:
Reply 29 of 71, by rmay635703
I don’t know of any vintage dos games that were dramatically accelerated by an FPU but an IBM PC/XT did have floating point and parallel processing upgrade options that were far faster than 4.77mhz.
Similar to the later 287 upgrades there were ways of running your 8087 at speeds higher than 4.77mhz on your XT.
There were also 10-16mhz accelerators that included 287 or 387 chips or even non-x86 parallel processors like the 68k that could be supported by database and lotus 123 with a driver.
In the case of sim city have a slow 8088 combined with a light speed floating point may still not do much.
Reply 30 of 71, by JAKra85
JAKra85 wrote on 2026-06-16, 19:59:
Thank you for the detailed description! I set the IBM 5151 monitor aside, takes too much space. Now only using the VGA with thi […]
Jo22 wrote on 2026-06-05, 23:12:
Hi, it might be that PC-Tools Deluxe from the 80s checks for full 256 KB or less. 256 KB was the full expansion for EGA cards an […]
JAKra85 wrote on 2026-05-24, 21:33:
Today I brought it down, did a clean, disassembled made photos, reassembled. Changed the videocard to ATi Wonder 1024 - ISA - 51 […]
Changed the videocard to ATi Wonder 1024 - ISA - 512KB (PN 109-00095-10).
One of the fastest videocards possible from ATi (28800-5) for this CPU.
This is a 16b ISA working in 8b ISA mode.
The PC Tools program reports only 256KB RAM on the videocard, not exactly sure why that is.
Has both VGA and EGA outputs.
(Tried IBM 5151 monitor and an LCD at the same time, does not work. 😜 )
256 KB was the full expansion for EGA cards and the base memory for VGA cards.
So the register in memory can't tell if its 512 KB or 1 MB.
Other programs might report "256 KB/512KB" instead.
Merely VGA aware programs do really count the video memory, I think.
https://dosdays.co.uk/topics/Manufacturers/at … vga_wonder+.php
I was just curious to see what happens if VGA and MDA are connected at the same time. There was no motive behind it, only curiosity.
The MDA monitor did not get a signal.
With this videocard it takes a bit of time for the MDA monitor to get a signal. Maybe I will try by attaching the VGA after I have an MDA output.
This works just fine, if two cards for each monitor is used.
VGA and MDA can co-exist, an MDA monitor was often used by developers to see debugger output (SoftICE, Windows etc).
Things is, there are two types of MDA cards.
Real MDA cards with 4 KB of RAM and MGA (Hercules, HGC) cards with 64 KB of RAM.
But because Hercules cards do boot up as plain MDA cards, as well, they cause no trouble.
Programs like Checkit will merely see a plain MDA card in short.
It needs a driver or utility to enable the graphics RAM (Hercules driver disk, msherc driver etc).
If other graphics cards can be used in graphics mode or not is up to the VGA BIOS.
It has to be smart enough to decide if the VGA card makes room for another graphics card.
If it makes room, the VGA card looses some of its video modes.
Edit: Two monitors on one VGA card may or may not work.
I vaguely remember that some VGA cards from late 80s (ATI?) had "auto-sense" and would try to detect the monitor type.
Now only using the VGA with this IBM XT.
I now have other issues, I think it could be videocard related.
I need assistance/advice if and how I can fix this.
1) There is a corruption visible in SimCity. It's a mouse trailer issue, I do not know how to better describe it. 😀
Since I do not yet have a mouse I'm using the keyboard to move the cursor.
The attachment 20260616_213836b.jpg is no longer available
The attachment 20260616_213730.jpg is no longer available
The attachment 20260616_213750.jpg is no longer available
2) After 10-15 minutes there is a fuzziness on the screen, it might be PSU related.
When the PC boots everything is clean and clear after a time I see this fuzziness and it gets worse with time.
It is very strong when both HDD and FDD are active (high load). With less load or idle this does not go away.
Also almost all ISA ports are populated.
I'm thinking of changing the capacitors in the PSU for a cleaner voltage. Manufacture date is 1983 week 41. I don't think anyone touched this since. 😀
The attachment 20260616_211457.jpg is no longer available
"1) There is a corruption visible in SimCity. It's a mouse trailer issue, I do not know how to better describe it. 😀
Since I do not yet have a mouse I'm using the keyboard to move the cursor."
This issue or screen coruption was caused by the ATI Wonder 1024 BIOS (I think) and the keyboard-mouse emulation in SimCity.
Once I've set up an IRQ based mouse the visible corrution was gone.
Next week I think I can complete this project and will post pictures.
Retro PC Gallery:
Reply 31 of 71, by JAKra85
IBM XT 5160 connected to the internet!
I have finally managed to connect this PC to the internet.
Originally I have used a WD8003W network card.
I had issues, this 8bit ISA network card: can't do auto-negotiation and can't do full-duplex.
Because of this even if the driver was properly set up and working once connected to my home router (FTTH - 4 Gigabit ports) I had no connection.
I had two options:
1) Man in the middle: An older switch or router between the two parties.
2) Change the network card with something more recent that still works in an 8bit ISA slot and the IBM XT (4,77MHz) CPU.
I took option two:
3Com EtherLink III (3C509B-TPC)
Made in 1997; Made in USA. 😀
The attachment 20260713_193605.jpg is no longer available
I use it currently to set the system time. There is no RTC on an IBM XT.
Later I plan sending simple e-mails from it.
Once (or if) I open a Retro PC Gallery to the public, users will be able to send an e-mail from the original IBM XT to any modern device.
Current autoexec.bat:
The attachment 20260713_193334.jpg is no longer available
Current mTCP config file:
The attachment 20260713_193358.jpg is no longer available
IBM XT booted and time set:
The attachment 20260713_193251.jpg is no longer available
Next is the sound card.
I already have it, it is set up and working.
The problem I have is that the bracket is missing...
The attachment 20260607_135307.jpg is no longer available
I already tried two (non-Creative) brackets and they did not fit, it's not a standard.
Once this sound issue is solved it's project complete.
Photo time and putting it aside for later.
Retro PC Gallery:
Reply 32 of 71, by JAKra85
rmay635703 wrote on 2026-06-25, 19:49:
I don’t know of any vintage dos games that were dramatically accelerated by an FPU but an IBM PC/XT did have floating point and […]
Original SimCity with a 8088 CPU and 8087 FPU is quite playable on an MDA monitor\resolution.
I don't plan any accelerators, this is good enough to enjoy.
If I want more speed, I have over 30 PCs that are faster than this one. 😁
I was simply curious of the speed change once an FPU is added. - Barely noticeable.
Retro PC Gallery:
Reply 33 of 71, by Grzyb
JAKra85 wrote on 2026-07-13, 18:02:
Your TZ variable is only good for the summer time.
For the whole year, use:
set TZ=CET-1CEST-2,M3.5.0/02:00:00,M10.5.0/03:00:00
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 34 of 71, by JAKra85
Grzyb wrote on 2026-07-15, 12:18:
Your TZ variable is only good for the summer time. For the whole year, use: […]
Big thanks! 😀
Set, checked and working nicely! (<- Will check again during winter.)
Retro PC Gallery:
Reply 35 of 71, by JAKra85
Changed the two RAM cards (2x256KB) to one 768KB RAM extension card with RTC mentioned in one of the previous entries.
(this system by default can use a max. of 640KB and that is fine, I don't mind the "lost" RAM)
The attachment 20260703_172754.jpg is no longer available
Also sent it to TheRetroWeb: https://theretroweb.com/expansioncards/s/atd-model-116
Unfortunately the RTC chip (ATD-20) is dead and it is not a DS1287 or DS12887.
I did not want to brake it apart, left it like it is.
Previously I've already modified a DS12887 to "look good" and work at the same time:
The attachment DS1287.png is no longer available
The system time is synced over the internet (SNTP) during the boot sequence so nothing is lost.
Retro PC Gallery:
Reply 36 of 71, by rmay635703
There are utilities to “use some of the lost ram”
Reply 37 of 71, by wierd_w
Use!UMBS comes to mind.
As long as it's in the 384k adapter rom area, that can turn it on as upper memory, even on an XT.
Reply 38 of 71, by JAKra85
Project complete!
IBM XT 5160 connected to the internet with time&date synced&set:
The attachment 20260812_124348.jpg is no longer available
Pinging google.com:
The attachment 20260812_124240.jpg is no longer available
ISA cards nicely lined up:
Microsoft InPort - MS Bus mouse card
3Com EtherLink III - LAN card
Western Digital WD1002A-WX1 - MFM hard disk controller
A.T.D. Model 116 - Memory expansion card
ATi Wonder 1024 - Video card
Creative Sound Blaster 2.0 - Sound card with CMS Upgrade
FDC - Original IBM floppy drive controller
The attachment 20260812_121129.jpg is no longer available
Back:
The attachment 20260812_124401.jpg is no longer available
The attachment 20260812_124410.jpg is no longer available
Retro PC Gallery:
Reply 39 of 71, by JAKra85
Copying game Tetris from a Windows 11 PC to the IBM XT trough FTP:
The attachment 20260812_125912.jpg is no longer available
The attachment Screenshot 2026-08-12 125845.png is no longer available
Playing SimCity:
The attachment 20260812_133528.jpg is no longer available
AMD CPU and Intel FPU playing nicely with each other. 😀
The attachment 20260812_121212.jpg is no longer available
Now, I just need time to enjoy it. 😀
The attachment 20260812_124339.jpg is no longer available
Retro PC Gallery:
