List of open-source PC hardware projects
Reply 161 of 170, by mr.spencer
Hello adalbert,
Here is a new one to the list:
I wanted to share a PC/XT motherboard I designed, based on the IBM 5160 and influenced by the many Taiwanese turbo clones of the era. I called it the DubaiXTClone.
The main differences from a standard XT design: 8MHz turbo with runtime speed switching, static RAM (no refresh), reduced IC count, 4-layer PCB, and real-time bus activity LEDs driven by otherwise unused gate outputs.
Fully open hardware under CERN-OHL-W v2 — schematics, PCB and PAL source code all included.
Tested with JUKO 2.31, Turbo BIOS 3.1 and others. SVGA Trident, 3COM, RTC, Floppy, and XTIDE all confirmed working in turbo mode.
As a side note, it also runs LMChat (https://github.com/spencer-uk/LMChat), a chat client that connects the board to a local LLM via LMStudio.ai application - ELKS and MS-DOS, both are supported.
GitHub: https://github.com/spencer-uk/DubaiXTClone/
(in the picture: top board DubaiXTClone, bottom IBM5160 - for comparison)
Happy to answer any questions.
~Spencer
Thanks for the link @rasz_pl.
posted with pictures here: Re: DubaiXTClone — 8088 Turbo 8MHz PC/XT Motherboard with Static RAM
Reply 162 of 170, by rjbrown99
It has been brought up in other threads on Vogons, but suggesting this to be added here as well:
https://www.yyzkevin.com/picopcmcia/
I just ordered one of these, it looks awesome in terms of modernizing an older laptop. Especially the network bridge piece of it.
Reply 163 of 170, by RayeR
Cool, this seems to be "must build" for my HP 200LX. I tried 2 old PCMCIA eth. cards, even able to load drivers and exchange few packets all attempts with mTCP failed, maybe due too excessive current load. Even better this adapter can combine network and storage and others. As this palmtop has only one slot and very limited internal storage so it's crucial. Going to check for PCB data to put some order in JLC...
Reply 164 of 170, by Duffman
Has anyone downloaded the files that were here?
https://github.com/slobworks/sisyphus
it's gone now.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 165 of 170, by LSS10999
Duffman wrote on 2026-06-28, 22:41:
it's gone now.
Here are the files I got from the repo back then (excluding the sisyphus-pci-backups folder as they are mostly unnecessary duplicates).
I did order a few PCBs and all necessary parts around early 2025, but I haven't really assembled a unit yet, as I'm still looking for a suitable 3D-printable bracket for this card's layout.
Without a good bracket I won't be able to actually put it into a case after assembly... even the brackets I could find online for the ES1868-ISA8 project did not fit that card and I had to manually drill more holes to adapt to its jack layout.
EDIT: There was a "low-cost" version of the card meant for half-height use cases. I'm only just made aware of this repo's disappearance.
EDIT 2: Turned out I did have the data about the "low-cost" version in my cloned local copy, the "LC" branch. Uploading it as well in case anyone's interested.
Reply 166 of 170, by Duffman
@LSS10999
Thanks very much!
CPU: Ryzen 9 5950X
Reply 167 of 170, by RayeR
rjbrown99 wrote on 2026-06-25, 22:24:
I looked closer but it seems not be opensource/openHW now:
$50 refundable deposit.
$160 expected final price.
Shipping in ~30-90 Days
You said its opensource, where are the files?
The repository will be made public prior to shipments. Many portions of the code are already publicly available via other products that there has been collaboration with.
Reply 168 of 170, by BitWrangler
Somehow this did not get in here yet, Asus MIR riser board reproduction, for USB, PS/2, IR from Asus header on socket 5, 7, 370, slot 1 boards in second half of 1990s.
Asus USB/MIR reverse engineering
Reply 169 of 170, by rasz_pl
Open source project to use vintage hardware - USB xHCI driver for Windows 98/2K https://yeokhengmeng.com/2026/08/xhci98-usb-host-driver/
https://github.com/yeokm1/xhci98
Reply 170 of 170, by RayeR
Cool project, the author also mentioned improved NUSB stack by SweetLow - where's more info about it? I use older CZ version of NUSB, I think 3.3...
My machine still has EHCI (only) but I have also installed PCIe x1 XHCI USB3 card so it could make this ports working too (even still in slower USB 2.0 mode)...
So the last critical missing is some (at least 2D) accelerated driver for newer VGA cards, maybe one day someone squeeze AI to port e.g. Nouveau from Linux to Win98 😜
