Reply 20 of 26, by geordiepingu
Decided to buy some more stuff this morning, after buying another project car.... A fun day for me!
XSPC 240mm x 50mm rad.... £20 new from WCUK (yes, £20!!!)
16/10 fittings, 45s etc. Mostly Barrow, as I refuse to spend more watercooling on this than my main PC!
Alphacool Eisfach dual 5.25" bay reservoir with a D5 Vario pump
Hose
Inhibitor and deionised water
Chipset block
Basically, everything I need for a good day of plumbing
On top of that, I bought all the connectors and wire to make EVERY power connector for the PSU, in the right "old school ATX" colour. Unfortunately, I damaged the ATX12v cable taking it out - think it's had a bit too much abuse over the years, so figured now is the opportunity to make it look as period correct as possible, as well as beef up the power delivery to the board. It's also something new for me. I've made plenty of car ECU looms before with my crimps, but I've never tried making my own modular PSU loom. Plenty of spare cable and pins to make mistakes with... I am just trying not to think about how tedious it is going to be, crimping probably 150+ pins...
So you may ask, am I beefing up the power delivery? Well, I can safely say the old P4 connector measures at 2mm OD, which I would estimate as 18AWG. I am going to swap it for 16AWG, my logic being that it's a 4-pin connector powering 2x Bartons overclocked, it needs as much power as it can get without getting hot (and voltage droop over resistance).
The ATX12v connector has some sense wires the PSU uses for its voltage regulation feedback loop circuitry, so I've accounted for that.
I've also started thinking about how I'm going to mount this XSPC rad. I am going to go with the option of mounting it above the PSU, eventually venting out of the side panel (when I figure out how or who I'm going to use to cut it). Very simply, I am going to get some 1.2mm steel laser cut, then drill and tap some M3 screw holes to mount it in situ. It will mean DVD drives won't be mounted at the top, which is fine, as I need to show off my bay reservoir. Picture with some scrap steel to show the concept. It will screw to the PSU bracket and the inside of the drive cage very easily. It does give me an option for draining the system, as I am still unsure whether to cool the GPU, which would make it easy for me to T off and have a ball valve. Albeit more cumbersome, I can dismount the radiator and drain it from the back side.
Clever money tells me that I will "just fit" the radiator horizontally and have ample space vertically. (I've measured 6 times). Here's a concept with a bit of scrap steel:
file.php?mode=view&id=244938
While I was ordering connectors from CPC, I saw the main power cap on the X-Fi was looking a little bit sad. I've ordered a Panasonic FR series for it. In the same thought of "pushing things to their limit", I did also get some caps for the 7800GS, although they are Unicon and probably fine, so I will leave them until they are not fine. One of the decouplers looks a bit sad, so that is getting swapped (Rubycon for Rubycon).
shevalier wrote on 2026-06-30, 04:23:
Chifteс now makes different shapes of cutouts.
Sawing two small holes instead of one large one seems a bit odd, especially considering the steel is about 1 mm thick.
Always work on the principle that it's easier to remove metal than add metal. I made the cuts with my angle grinder out of impatience, which (as we always know) will end up too big and wrong. As such, I kept cutting and filing by eye until I got rid of my cut marks, which ironically gave me one mid-size hole. What I should've done in hindsight is employ some patience and get my plasma cutter out of my workshop and dig out my straight edges. Alas, got a hole and it's functional, and hasn't removed too much rigidity from the case. I have sprayed some clear lacquer on for now to prevent any flash rusting since I live by the coast, with a view that I will paint the entire thing at some point in the future. I will get some PVC trim to make it look a bit less horrid. The concept works well, though, with plenty of access to solder some wire in from the back while it's screwed together.
file.php?mode=view&id=244939
Reply 21 of 26, by geordiepingu
My rad arrived today, which meant I could do some further mocking up and triple-check my measurements. Just as well, I needed to shift the rad over another 5mm, due to the bungs at the end. The bottom of the rad sits with about 2mm of clearance from the top of the PSU.
I did get some cursory quotes to get the template laser-cut. However, looking at the cost, I think I'll be getting my jigsaw and metal blade out... I have some contact adhesive and have remembered how to export my CAD designs onto paper 1:1, so guess what I am going to be doing.
This is what the radiator mounting panel looks like at the moment. I haven't done holes for tapping on the design intentionally; I intend to clamp it in place, then drill and tap it in situ, so I don't have the difficulty of making holes line up.
file.php?mode=view&id=244968
I have also been thinking about the side panel in the same context. At first, I modelled a full-size window with a 30mm offset. I'm now contemplating whether to do a 20mm offset to allow a little bit more airflow from the rad out of the side of the case. Either way, it will be a bit of an arduous process lining up 8x sheets of paper and trimming the overlaps to fit, but nothing I haven't done before. Unless I can find someone nearby with an A3 printer to make it a few less sheets....
Not going to drill screw holes for the window. Sikaflex can hold a windscreen to steel so it should be alright at holding something like this together, for a cleaner look and easier assembly.
Here's the 30mm offset variant with 30mm radials.
file.php?mode=view&id=244969
Repaired my X-Fi too, happy bunny.
Reply 22 of 26, by TELVM
geordiepingu wrote on 2026-06-29, 10:38:
... the NZXT C750 Gold Gen1 is a great PSU for what I am using the system for ...
The NZXT C750 Gold ...
file.php?mode=view&id=244976
... is essentially a rebadged Seasonic Focus Plus 750W Gold, good stuff ...
file.php?mode=view&id=244977
Seasonic goes the extra mile and attaches a heatsink to the minor rails' DC-DC FETs:
file.php?mode=view&id=244978
Just make sure the stupid "ZERO RPM FAN MODE" is switched off:
file.php?mode=view&id=244979
Let the air flow!
Reply 23 of 26, by shevalier
The case for my main PC is the CHIEFTEC Mesh LCX-01SL, which is based on a similar platform.
like this https://www.ebay.com/itm/175492093873
Over the past 20 years, it has seen a great many different pieces of hardware inside it.
Its advantages include a relatively modern design, thick metal and a large internal volume.
Unfortunately, that’s all there is to it.
With a 120mm exhaust fan running at 1,000 rpm, and the PC drawing 100 watts from the mains whilst idle (20 of which come from a rather old PSU), the temperature inside the case is 10 degrees higher than the ambient temperature.
Cases like this are sorely lacking in intake airflow, and there’s nowhere to fit 2–3 low-RPM 120–140mm fans.
You need to get rid of the HDD/CD bays and cut out the front panel.
For cable management, you need to make significant cuts to the backplate.
And add a plate to block the PSU’s air intake from the motherboard.
If I had water/laser/CNC, I could get to it. But sawing all this stuff off by hand is less than enjoyable.
As a result, this summer, I started seriously looking at the Chiftec NightHunter 3. 🙁
The classic ATX case design is a complete failure.
And now their design has taken a huge leap forward.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 24 of 26, by shevalier
shevalier wrote on Today, 06:45:
Cases like this are sorely lacking in intake airflow, and there’s nowhere to fit 2–3 low-RPM 120–140mm fans. You need to get rid […]
The Athlon XP decipate around 50 watts, overclocked - 70+ watts
Dual CPUs - 150 watts, + 50 watts video card
Total (including other small parts) - about 250 watts.
To blow them out, you'd have to make the case look like a Sharkoon PURE STEEL.
https://en.sharkoon.com/product//26616
https://www.techpowerup.com/review/sharkoon-p … el-atx-chassis/
Reply 25 of 26, by geordiepingu
shevalier wrote on Today, 12:44:
The Athlon XP decipate around 50 watts, overclocked - 70+ watts Dual CPUs - 150 watts, + 50 watts video card Total (including ot […]
To a degree, you're right, but I don't need to go that far to solve the problem! I accept that full towers make noise and they are imperfect. I can still achieve my goal. In a sense, I want to relive the hum my old full tower made. If I didn't, I would've bought a Silverstone FLP02 (would've probably been cheaper...)
I can squeeze 2x140mm fans into the bottom if I change the feet, which I think you suggested to do anyway. I've snapped a foot, so I may as well change them. I've found some units that will raise the case an inch off the floor and are also rubber. The GPU is staying air-cooled for now, as it may change in the near future. Being a blower-style card, it will benefit from cold air from the bottom, and I suppose if I could reverse the airflow, that would also be beneficial.
I will keep the 5x 80mm fans - they are Arctic P8 Maxes and shift some air.
The rad at the top is running 2x P12 Pros. I also have a 92mm P9 Max I can add for some additional cold intake, above the PSU, quite easily.
The trick will be making sure I get a sufficient baffle made between the exhaust of the radiator and the cut-out in the side panel window, to make sure I don't recirculate air in the case. But I will be keeping the HDD cages and 5.25" bays. I may play with the airflow direction of the 80s to see what impact they have closer to the time. I am tempted to print some TPU fan mounts with tighter tolerances than the standard fan mounts, so it acts as both a natural air gasket between the case and fan, and as a vibration dampener.
Reply 26 of 26, by H3nrik V!
geordiepingu wrote on Today, 17:50:
To a degree, you're right, but I don't need to go that far to solve the problem! I accept that full towers make noise and they a […]
Blower style gpu, but am I right that it expels the hot air inside the case?
As for baffles for fans; may I suggest the eternal joy of owning a 3D printer? 😎
