Reply 20 of 42, by aVd
Hi, @itzCrassio,
This problem with C-Media CMI8738 sound cards driver/initializer is well known. "IRQ=A" (in hexadecimal) is same as "IRQ=10" (in decimal) and this is not correct setting for SB emulation. In order to make working CMI8738 sound card SB emulation, first you need to be sure that the motherboard's chipset supports DDMA, and second - you have to set "legacy mode" with manually set IRQ in the BIOS for the PCI slot with the installed sound card. It seems like the "reserved" setting in your BIOS will be same as "legacy mode".
Good luck!
SvarDOS fan :: artificial "intelligence" bots - not a fan at all :: say NO to systemd :: is freeware a lie, when human freedom is a fundamental lie? :: f00ck €u!
