Cannot copy onto floppy drive
Reply 20 of 91, by Im from Windows
DaveDDS wrote on 2026-07-04, 10:02:
You don't want to go spraying things into a drive. You can clean drive heads by hand, but 3.5" drives are difficult. […]
Basically you cut a strip of paper which can placed under the head and pulled back and forth.
With power-off you mildly impregnate the strip cleaning alcohol place it under heads, close the drive and GENTLY pull the strip back a forth a few times under the head.
Easy to do with most 5.25" drives (head is well exposed), very hard to do on 3.5" drives (head is well covered)
Do I need to take the cover off of the Fdrive?
DaveDDS wrote on 2026-07-03, 12:48:
Good, 643+780=1423- about right for a 1440k HD drive
A DD drive would have a total of 720k - clearly yours is HD.
So a DD drive is half the size of a HD right? or is that the floppy disks them self?
You were able to figure the size otherwise, so you don't need to now. but FYI (IIRC):
Start -> Programs -> Accessories -> Command Prompt
OK thanks! good to know for next time/ something ells
Reply 21 of 91, by Im from Windows
superfury wrote on 2026-07-04, 10:06:
You usually open the imz or img/ima file in software like WinImage, then use the program to write the data onto the floppy disk. If you try to copy the file directly to the floppy using Windows itself (windows explorer), it won't work, as you're attempting to copy a 1.44MB image file into a file system that IS the 1.44MB (2880 sectors on the disk) file itself, which is 1) missing the FAT and boot sector required for booting and 2) putting the filesystem with it's data into a filesystem, which won't ever work (since the BIOS booting it can't read it, besides it being a SECTOR copy of the disk and not a FILE copy). Usually you'd open it in software like WinImage, navigate to disk and select the option to write it to your inserted floppy drive.
For the 7z archive you'd find the imz/ima/img file inside it, so you'd need to extract that first.
Imz files can't be written directly and need extraction using a tool (or WinImage, which does extract it itself when you open it).
Dont understand! but are you saying "7-zip file manager" is the wrong program and i need WinImage instead?
Reply 22 of 91, by Im from Windows
DaveDDS wrote on 2026-07-04, 10:29:
1st floppies were 8" - these were used on mainframes (size of small house) and minicomputers (size of a refrigerator) These had […]
These had 77 "tracks" (logical rings where head writes data)
They were at first single sided, then advancement led to both sides being used.
Originally "single density", later "double density" (twice as many data bits per track)
Was this the 60s and 70s by any chance?
Then came 5.25 - almost the same but smaller and only 40 tracks. Single sided: 180k Double sided: 360k (this is where IBM 5150 " […]
Single sided: 180k
Double sided: 360k (this is where IBM 5150 "PC" started)
Then "High Density" was developed (Even more data bits per track via different media and more tracks) - appeared in the PC "AT")
5.25 DSDD = 360k (40 track)
5.25 DSHD = 1.2m (80 track)
An ongoing problem with DD<>HD was that there was no physical difference that the drive could detect and some people formatted DDs as HDs and it "sort of" worked but was unreliable.
Then disks got even smaller and physically changed: 3.5" format. By this time all were 80 track.
3.5 DSDD: 720k
3.5 DSHD: 1.4m
At this time an ID hole was added so a drive could tell the different between DD and HD disks, this appearsa on HD disks but NOT on DD disks (easy to tell apart visually as well)
I found a good photo showing the differences here: https://www.micropolis.com/support/kb/3.5-inch-floppy-disk
So HD and DD where in bough 5.25 and 3.5 right? and where the floppy disks them selfs and not the floppy driver?
I have included much more information about floppy diskette and drive types in my ImageDisk documentation.
ImageDisk can be gotten from "Daves Old Computers"
Yes that is what my floppy disk looks like!. one square hole at the top and another one on the other side with a slider (presume its to look the drive like a video cassette)
Reply 23 of 91, by NeoG_
Im from Windows wrote on 2026-07-04, 12:56:
Yes you need an image writer (such as WinImage). An image file is an entire disk, not just individual files so you need a program that can write an entire disk in one go. Neither Windows nor 7-Zip have this feature.
1. Use 7-Zip File Manager to extract the .img file contained inside somewhere on your hard drive
2. Use WinImage to write the .img file to a floppy disk
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 24 of 91, by Im from Windows
DaveDDS wrote on 2026-07-04, 11:44:
Brief history of floppy disks: (you don't need to know this - but it might help understand where things came from)
Just in case anyone is interested in this stuff, I do have a picture showing examples of the actual drive types I mentioned:
http://dunfield.classiccmp.org/misc/index.htm
In europe we only do 110v on caravan and building sites (typical 16amp ring main) Stricklly 240v domestic use! Dont see a lot of small AC motors nower days! think my 3.5" floppy is 12 and 5v
Reply 25 of 91, by DaveDDS
Im from Windows wrote on 2026-07-04, 12:53:
Yes, but once you do, you'll find that (at least on most 3.5" drives that I've seen) the heads are still mostly covered by the internal mechanism.. some drives I've been able to slip a long thin piece of paper under the heads from the side, some not.
Same physical size - but 1/2 the capacity.
DD drive electronics can't write to HD media properly.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 26 of 91, by DaveDDS
Im from Windows wrote on 2026-07-04, 13:13:
Good point & Thanks - I've never seen one, but I would guess that European 8" drives used 220/240v for the motor.
Next time I'm updating "Daves Old Computers" - I'll update that text "110v" -> "mains"
Reply 27 of 91, by Im from Windows
NeoG_ wrote on 2026-07-04, 13:10:
I get fed up with downloading so many things that wont run because they are 64bit and never bothered to tell you before you downloaded them. But this site looks very early 90s layout or just simple good old school HTML1
https://www.winimage.com/download.htm
And they have even bothered to label then with 64 or 32. But there are quite a few 32bit one there for me to choise from. Can you recommend one please?
I though 7-zip file manager was pathiificlly for zip files only. and things like "image burn" and "ISO burn" where for .img files only
Reply 28 of 91, by DaveDDS
FWIW, the smallest/simplest Win32 FloppyImage -> ActualDisk tool i've found is called DSKWRITE.EXE, (17k) doesn't have to be installed etc.
I stumbled across it somewhere, didn't find an official distribution site, so I just included in DOSBOOT.ZIP archive on my site.
Reply 29 of 91, by NeoG_
Im from Windows wrote on 2026-07-04, 13:22:
Get the third file from the top (winima110.exe)
Don't overthink it, just follow the two steps provided and you will have a working boot disk
Reply 30 of 91, by Im from Windows
DaveDDS wrote on 2026-07-04, 13:29:
I looked on your site you linked in your signature but could not find the link
Reply 31 of 91, by Im from Windows
NeoG_ wrote on 2026-07-04, 13:30:
So I have downloaded and installed the one you said. then I opened the win98 file in question. But I am unsure of what to do next! please see image attached
Reply 32 of 91, by DaveDDS
Im from Windows wrote on 2026-07-04, 13:34:
"https://dunfield.themindfactory.com" -> "Download files" -> "DOSBOOT.ZIP"
Reply 33 of 91, by Im from Windows
hear i was before the above photo
Reply 34 of 91, by NeoG_
Im from Windows wrote on 2026-07-04, 13:41:
In the disk menu, select your floppy drive, then in the disk menu again select write disk
Reply 35 of 91, by Im from Windows
DaveDDS wrote on 2026-07-04, 13:44:
I just downloaded it thanks! after abstracting the file to my chosen folder (compressed zipped files) it looks identical to the other one that I downloaded before in the above screenshots
Reply 36 of 91, by Im from Windows
NeoG_ wrote on 2026-07-04, 13:44:
There are 4 options showing a disk. again please see attachment
Reply 37 of 91, by NeoG_
Im from Windows wrote on 2026-07-04, 13:52:
The word "Disk", in the top menu
Reply 38 of 91, by DaveDDS
It's not clear what exactly the file type is (only that it's ".im?") or it's size .
A 1.44m 3.5" floppy disk image would normally be ".IMG" with a size of 1,474,560 bytes.
When posting screenshots of files like this when seeking help with them, it's worth turning on the display of extensions and sizes (things I always keep turned on in my systems)
Reply 39 of 91, by DaveDDS
Im from Windows wrote on 2026-07-04, 13:49:
I'm not sure exactly what you are doing ... my DOSBOOT.ZIP archive contains a bunch of DOS boot disk images, as well as some tools for working with them:
W:\SITE\DNLD> ZDIR DOSBOOT.ZIP
2026-04-24 16:49:04 8362 _DOSBOOT.TXT
2026-04-24 16:49:04 1474560 CALDERA.IMG
2026-04-24 16:49:04 17408 DSKWRITE.EXE
2026-04-24 16:49:04 6776 FDI.COM
2026-04-24 16:49:04 3234 FDI2ISO.COM
2026-04-24 16:49:04 1474560 FREEDOS.IMG
2026-04-24 16:49:04 327680 MSDOS112.IMG
2026-04-24 16:49:04 368640 MSDOS211.IMG
2026-04-24 16:49:04 1474560 MSDOS331.IMG
2026-04-24 16:49:04 1474560 MSDOS400.IMG
2026-04-24 16:49:04 1474560 MSDOS500.IMG
2026-04-24 16:49:04 1474560 MSDOS622.IMG
2026-04-24 16:49:04 163840 PCDOS090.IMG
2026-04-24 16:49:04 163840 PCDOS100.IMG
2026-04-24 16:49:04 163840 PCDOS110.IMG
2026-04-24 16:49:04 368640 PCDOS210.IMG
2026-04-24 16:49:04 368640 PCDOS300.IMG
2026-04-24 16:49:04 1474560 PCDOS330.IMG
2026-04-24 16:49:04 1474560 PCDOS71.IMG
2026-04-24 16:49:04 1474560 PTSDOS.IMG
2026-04-24 16:49:04 3302 XDISK.COM
W:\SITE\DNLD>
The one you want is DSKWRITE.EXE
