Reply 40 of 45, by rjbrown99
- Newbie
OK, so today my giant carton of every type of resistor showed up, so it was time for soldering.
To recap - the board uses an LT1085CT regulator near the CPU socket. I measured the original voltage at the LT1085 tab:
Original Vcore:~3.437V idle~3.438V under TESTCAB / SpeedSys load
So the regulator was stable and had essentially no droop, but it was only providing about 3.44V.
The LT1085CT pinout is:
Pin 1 = ADJPin 2 = VOUTPin 3 = VINTab = VOUT
I measured the existing feedback path:
Pin 1 / ADJ to Pin 2 / VOUT: ~0.618k ohmsPin 1 / ADJ to ground: ~1.049k ohms
The lower feedback resistor is the blue SMD resistor marked 1051, which measured about 1.049k ohms and goes from ADJ to ground.
The mod was to add a resistor in parallel with the VOUT-to-ADJ resistor path, by soldering a through-hole resistor on the underside of the board between LT1085 pin 1 and pin 2:
Added resistor:8.2k ohm, 1% metal filmConnection:LT1085 pin 1 / ADJ <-> LT1085 pin 2 / VOUTDo not connect to pin 3 / VIN.
Before soldering, the resistance between pin 1 and pin 2 was:
~0.618k ohms
The 8.2k resistor itself measured:
8.29k ohms
After soldering it across pin 1 and pin 2, the measured resistance between those pins dropped to:
~0.574k ohms
I started it up, and here's what the voltage regulator measured:
~3.599V
Which is just about perfect if I am to understand that this chip is rated for 3.6V maximum. I reassembled the board and confirmed the voltage was still around 3.59V after power-up.
Before changing jumpers back to 160MHz, I kept the system at the known-stable 3x40 / 120MHz setting and tested the mod:
40MHz bus3x multiplier = 120MHzVcore ~3.59VExternal cache enabled
That passed my TESTCAB copy-file test and SpeedSys normally, so the voltage mod itself did not appear to introduce instability.
I then changed only the multiplier jumper back from 3x to 4x:
JP24:1-2 = 3x3-4 = 4x
The system is now back at:
40MHz bus4x multiplierAMD-X5-133ADZ at ~160MHzVcore ~3.59V
Early testing looks promising so far. Both benchmarks have passed and there have been no crashes. I'm going to keep testing and we'll see where we wind up.
I had an Adrian Black style "IT FREAKING WORKED" moment already. Given that I have minimal electronics and soldering skills and had no confidence in what I was doing here, I'm surprised in a good way. This forum plus a bit of ChatGPT input might have unlocked the key to 160MHz for this board. A huge thanks to jakethompson1 and the other ideas on this thread so far. Woot!
