A day of triumph and setbacks again. I got the loop plumbed in and decided to test it (with all the components unplugged, of course). It survived a few hours and didn't leak, so I decided to plug everything in. The system belched into life, and would you have it, my CPU temps went from 58c to 38c. Magic.
I then spent 4 hours trying to find a set of drivers for the HD3850 that would play nicely with the 760MPX, where I eventually got a 3DMark01 score of 14400, which felt a bit pants. I then discovered there are much faster drivers out there, of which, by the time I discovered this, a bit of a setback occurred... But not before another triumph.
Being big and brave, I thought I should test my motherboard cut out and set the multiplier to 15x (15x150). 10-15 mins of soldering some tinned wire to the back, the system immediately belched into life. I had set the FSB to 133, so the system identified itself as having Athlon 2600MPs. I then ramped it back up to 150, increasing the volts for stability as required, getting it to 2x 2250MHz. Not bad for the first go. I think I will set the multiplier higher - perhaps to 17 (17x133 = 2800+/2261MHz). This will give me room to get up to 2550MHz via FSB speed. Hope the chips will go that fast, I don't want to lose the memory speed I've gained getting 150MHz FSB stable!
This is where I manage to get Catalyst 8.12 installed and stable. Except when I come to reboot the system, a strange oddity in the BIOS appears. Athlon XP 2250MHz. And then an error that I cannot install an XP with an MP, and such it will identify as an XP. Bummer. Looks like one of my L5 bridge mods hasn't lasted, and I can see which CPU looks suspect. Having re-visited the TDS for the MG overcoat pen I used to fill in the "ground plane", I haven't let it fully cure before overcoating with the conductive paint. What I suspect has happened is that over time, the thin layer of silver paint on top has shifted due to the curing process not completing on the substrate. With it being the sort of die where you have to scrape the solder mask and the pins are super tiny, the substrate from the overcoat pen wasn't that big to begin with, really. So I have started the L5 bridge mod on my spare 2500. You live and learn...
Still stoked I hit 2x 2250MHz on this build. I dare say, with my research on the net, that's serious for a K7D rig. Can't be too selfish, I've had other wins this week. Finally got my G4 Cube swapped over to an SSD and working.
I still haven't sorted the paint. I've been aching with the flu I've got at the minute, so I stayed indoors.
