Reply 320 of 339, by theelf
- Oldbie
Xp users we really need a firefox backport
I think Mypal 74 works well in many cases, now with 3D accel and for the rest Supermium 138...
RayeR wrote on 2025-12-26, 15:41:I think Mypal 74 works well in many cases, now with 3D accel and for the rest Supermium 138...
Sadly i found mypal too slow for everyday use compared to supermium, and outdated
theelf wrote on 2025-12-26, 19:36:RayeR wrote on 2025-12-26, 15:41:I think Mypal 74 works well in many cases, now with 3D accel and for the rest Supermium 138...
supermium v138 just not work here and I can't downgrade the profile back to v132 so I have to switch to https://github.com/e3kskoy7wqk/Chromium-for-windows-7-REWORK
roytam1 wrote on 2025-12-27, 01:48:theelf wrote on 2025-12-26, 19:36:RayeR wrote on 2025-12-26, 15:41:I think Mypal 74 works well in many cases, now with 3D accel and for the rest Supermium 138...
Hi! greetings, i use XP, what's the problem of supermium v138? which sites you can't visit? im using latest supermium in XP and is working fine... well all fine a chromium browser can do... i really hate chromium jeje
theelf wrote on 2025-12-27, 10:44:roytam1 wrote on 2025-12-27, 01:48:theelf wrote on 2025-12-26, 19:36:Sadly i found mypal too slow for everyday use compared to supermium, and outdated
it launches but having a transparent blank window and totally unusable, as filed in https://github.com/win32ss/supermium/issues/1716
roytam1 wrote on 2025-12-27, 12:08:theelf wrote on 2025-12-27, 10:44:roytam1 wrote on 2025-12-27, 01:48:supermium v138 just not work here and I can't downgrade the profile back to v132 so I have to switch to https://github.com/e3kskoy7wqk/Chromium-for-windows-7-REWORK
Ah ok, in XP at least 32bits is working fine here, i dont have win7+ to test only XP
I have XP SP3 + all POS ready patches and it works fine, launched from SATA SSD within 1s.
theelf wrote on 2025-12-27, 12:30:roytam1 wrote on 2025-12-27, 12:08:theelf wrote on 2025-12-27, 10:44:Hi! greetings, i use XP, what's the problem of supermium v138? which sites you can't visit? im using latest supermium in XP and is working fine... well all fine a chromium browser can do... i really hate chromium jeje
author reached that issue and gave me a workaround switch so it is working again for now.
https://github.com/win32ss/supermium/issues/1 … ment-3694155606
roytam1 wrote on 2025-12-27, 23:26:theelf wrote on 2025-12-27, 12:30:roytam1 wrote on 2025-12-27, 12:08:it launches but having a transparent blank window and totally unusable, as filed in https://github.com/win32ss/supermium/issues/1716
Remember long time ago i enabled GPU but find some glicthed, disabled and never try again. I think i dont need at alla, even youtube works fine at 1080p using only 25-30% of CPU
In win7 there is better options than supermium? i think some firefox builds work fine no?
Anyways personal opinion, i dont see much the point of using win7 over win10 or 11, look similar for me, only 10+ have some extra work to enable classic theme
theelf wrote on 2025-12-27, 23:36:Remember long time ago i enabled GPU but find some glicthed, disabled and never try again. I think i dont need at alla, even you […]
roytam1 wrote on 2025-12-27, 23:26:theelf wrote on 2025-12-27, 12:30:Ah ok, in XP at least 32bits is working fine here, i dont have win7+ to test only XP
https://github.com/win32ss/supermium/issues/1 … ment-3694155606Remember long time ago i enabled GPU but find some glicthed, disabled and never try again. I think i dont need at alla, even youtube works fine at 1080p using only 25-30% of CPU
using classic theme in win8/10/11 is fragile and it can break by many ways, or in multiuser environment.
and new apps no longer consider dwm is inactive in classic theme and you need an external way to correct them and this makes me tired.
roytam1 wrote on 2025-12-27, 23:49:theelf wrote on 2025-12-27, 23:36:Remember long time ago i enabled GPU but find some glicthed, disabled and never try again. I think i dont need at alla, even you […]
roytam1 wrote on 2025-12-27, 23:26:author reached that issue and gave me a workaround switch so it is working again for now.
I dont have much interest in any windows beyond XP, but other day i tested classic mode in win10 using windhawnk, and keep dwm active still while in classic mode
theelf wrote on 2025-12-27, 23:36:In win7 there is better options than supermium? i think some firefox builds work fine no?
Firefox 115 esr, the last officially supported version for win7, still works fine, I use it daily and I have yet to find a website it can't load
theelf wrote on 2025-12-27, 23:36:Anyways personal opinion, i dont see much the point of using win7 over win10 or 11, look similar for me, only 10+ have some extra work to enable classic theme
win7 is for me the last good version of windows, I hate win 10 and 11... with some modding you can make them look the same I guess, but you certainly can't make them function the same. Win7 for now still works just fine and covers all my needs, if a day comes when it's no longer usable I'm switching to linux
So, there's a new Firefox-based browser for OSX 10.5 and 10.6. PowerPC as well. And it has nothing to do with TenFourFox, but it's based on Basilisk. Sites that rely heavily on Javascript, like Github, work properly now. Pictures till render blue here for some reason...
Pinned comment from JKTwice's post on r/VintageApple:
PowerFox is a new web browser for your PowerPC Macs running Mac OS X Leopard 10.5.8. There's also versions for Intel 10.5.8 and […]
PowerFox is a new web browser for your PowerPC Macs running Mac OS X Leopard 10.5.8. There's also versions for Intel 10.5.8 and 10.6.8 if Early Intel Mac is more your cup of tea.
This is not a fork of TenFourFox. This is a completely new browser for Mac OS X based on Basilisk. You get a newer Firefox backend that supports more websites, TLS 1.3, security patches, more Firefox Classic and Basilisk extensions, GPU web rendering acceleration, and more.
It will even play YouTube videos on the native frontend depending on your hardware. The recommendation at the present moment for 1080p playback is a Dual Core 2.3GHz or faster G5 system with a GPU that supports Core Image. A GeForce 6600 will be sufficient for this task. For other webpage rendering, Core Image is still required for GPU acceleration at the moment but even a lowly FX 5200 Ultra or Radeon 9550 will improve your browsing experience.
Some of the webpages that work well are Wikipedia, Old Reddit, BBC News, Facebook, and countless forum boards like MacRumors, TinkerDifferent, and more.
The developer of the project is Jazzzny. You can check out the GitHub repo here https://github.com/Jazzzny/powerfox-browser/issues and report bugs/give feedback. This is a beta project and is not stable, so please keep your expectations in check.
Hopefully the year is even better for the PowerPC platform!
MyPal 78.0.2 for XP is released. If you add ublock origin, use version 1.67 . The web page has a mistake; use this link: https://www.mypal-browser.org/release/
R3dfox 148.0.2 for Vista and Win7 is released. They fixed the bug with setting the downloads folder. Comes with latest (1.70) ublock origin pre-installed.
The main eclipse website is down so use this instead: https://github.com/Eclipse-Community/r3dfox/releases
There's a new version of PowerFox that supports OS X 10.4 Tiger. There are builds for i386, G3, G4 and G5 as well.
To my surprise, Firefox 115.34.0 esr (win7,8,8.1) appeared, as I thought that support was ended. It fixes another 17 security issues, after the 20 from last time.
As for MyPal 78.0.2, I should mention that it doesn't give access to the facility to download extensions. If you want something, you need to find the release site (usually github) yourself. I normally only get ublock origin 1.67 ( https://github.com/gorhill/ublock/releases ), and new tab override 15.1.0 ( https://github.com/cadeyrn/newtaboverride/releases ).
MyPal still has the bug where it asks if you want to close multiple tabs even if you only had one tab open.
Robbbert wrote on 2026-03-24, 23:23:To my surprise, Firefox 115.34.0 esr (win7,8,8.1) appeared, as I thought that support was ended. It fixes another 17 security issues, after the 20 from last time.
it got a 2nd extension from march to August 2026
I have an Athlon XP (no sse2) machine where I triple boot Windows XP, Windows 98 and Devuan Excalibur (a debian based linux distro.)
I wanted to settle on a relatively modern browser to get on the "modern" internet.
With the help of this reddit post... https://old.reddit.com/r/vintagecomputing/com … at_could_run_a/
...I managed to compile the latest version of the Basilisk web browser for linux for the Athlon-XP.
There are pages that fail to load, sure, like youtube for example, but that is more a consequence of the garbage javascript those sites use than anything else.
On XP I use mainly 2 browsers: MyPal for less complex pages - consume less memory and Supermium for ibanking, github, winraind forum, discord, aggresive cloudflare and other heavy load JS crap - consumes more memory...
