shevalier wrote on 2026-07-28, 17:00:A driver file has a 'certain checksum of all its data' calculated and stored in a special area inside the file.This prevents the […]
bitzu101 wrote on 2026-07-28, 12:48:
shevalier wrote on 2026-07-28, 12:32:
https://x.com/The_Cyber_News/status/2070267289971392845
Can you explain in normal human being terms what this means? I don t understand a thing...
A driver file has a 'certain checksum of all its data' calculated and stored in a special area inside the file.This prevents the file from being modified.
The expiration date of this 'checksum' is also specified. It is necessary so that if the 'checksum calculator' is stolen, it cannot be used forever.
The OS itself features a built-in check for both this checksum and the date.It also includes two exception lists: a 'blacklist' (for drivers known to be bad despite meeting all formal validity criteria) and a 'whitelist' (for cases when the time has expired, but the driver is still not blocked).
For major manufacturers, Microsoft makes an exception by adding their expired drivers to this very whitelist.As long as these drivers do not cause any problems for Microsoft.It seems they decided last year that there were already enough problems, and they started a policy of shrinking this whitelist in this spring.
Creative is still on it for now, but no one knows for how long
Falcosoft wrote on 2026-07-28, 13:53:
you can use any driver files on Windows as long as you want.
That’s also an option. But how long will it last?
As far as I know, X-Fi drivers definitely do not support Core Isolation / Memory Integrity.
For Recon3D / Z(xR), they most likely don't either.
Even the AE series didn't get a driver with this feature right away.
And Microsoft loves to forcibly enable all kinds of security features, making them mandatory. 🙁
a complete cracked and pirated version of windows?
I mean , win 11 is pretty poor as it is , i ve had to install so many scripts and disable so much crap , I could not care for a second if i use a 100% cracked and pirated version that has no crap and "security features" that are only there to benefit microsoft. I did pay for my windows , but I don t want all this crap , certificates , siganatures , ai , cortana , etc. i just don t want it.
If it would still work today , I could easily live with windows XP with no bloatware.
Microsoft has gone dystopian , Creative no longer makes chips.. this is just silly...
Is creative even plannign on making a new chip ever? If not , mind as well collapse. Let someone else that wants to make good products come to the table...
