Creative Labs Introduces The Next-Gen Sound Blaster!
Reply 320 of 342, by shevalier
Law212 wrote on 2026-07-27, 15:34:
Creative Sound Blaster Z SE PCIe High-Performance Gaming and Entertainment Soundcard | Sound Core3D 116dB Signal-to-Noise Ratio (70SB150000004)
Overall, the card is ......
It’s no longer an X-Fi with hardware sound processing.
And not yet an AE with a decent headphone amplifier.
You should stay away from the Recon 3D/ZXR lineup.
As far as I know, despite having the same chip as the AE, there are no longer any drivers for them.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 321 of 342, by bitzu101
shevalier wrote on 2026-07-27, 15:45:
Well, if you don't consider the top-tier DAC CS43131 from Cirrus Logic (whose DACs are used in your own X-Fi, just a bit more bu […]
bitzu101 wrote on 2026-07-27, 15:20:
shevalier wrote on 2026-07-27, 14:57:
It is a tradition that all motherboard manufacturers simply do not know how to implement an audio codec properly. Literally all […]
Literally all of them, always.
They know how to pick an expensive one and garnish it with pretty yellow capacitors. They manage to ruin even the ESS SABRE9018.
But
Right now, there are a bunch of dongles that haven't been ruined, even by severe cost-cutting and the developers' clumsiness.
In the post above, I mentioned one like that for 30 $.
Internal sound cards are practically non-existent now and will be completely gone soon. Creative's move to a PCIe-to-USB bridge hints at this.
So it's not a problem. Anyone who wants better quality will easily find something for themselves.
Sorry , does the $30 usb thing have a dedicated sound chip? Does it have a headphone amp? It seems very improbable that a usb cable like the one you showed in that link has all the features of a internal/dedicated sound card. I also see only one jack connection , where as my system needs 3 jacks to plug in all the speakers. Also , my AE 7 , has dedicated hardware for 5.1 system , not software , etc...
Well, if you don't consider the top-tier DAC CS43131 from Cirrus Logic (whose DACs are used in your own X-Fi, just a bit more budget-friendly and older), then you have vastly inflated expectations. 😀
Besides, it's very hard to mess up when implementing the final device.
Shponglefan wrote on 2026-07-27, 15:00:
One reason I'm still using internal sound cards is because of ground loop interference. I get noisy interference with motherboard audio, but using Sound Blaster Z sound cards the interference is minimized to the point it's not audible.
https://jdslabs.com/product/synapse/
USB galvanic isolator.
Now they have gone mainstream and are no longer exotic. And they radically solve the ground loop problem for external DACs.
so you have to complicate yourself with isolator , usb cables , etc... rather than having a stationary card , fixed in place with a scrue that does not move , that is shielded and you just plug in a 3.5mm jack ....
100% this is not for me. There is 0 interest on a usb card for me. I see no point in it. but that is JUST me. I think that Creative and other companies (think Asus used to make sound cards) should have invested in their own dedicated chips so the competition would result in better options and prices on the market.
Because they did not do that , now we are using sound chips designed years ago. The aim is to progress , not to stagnate.
Also , why on earth Cirrus Logic stopped making sound cards? They used to make the Crystal chips.
Reply 322 of 342, by bitzu101
shevalier wrote on 2026-07-27, 15:50:
Overall, the card is ...... It’s no longer an X-Fi with hardware sound processing. And not yet an AE with a decent headphone amp […]
It s not the best card , that is correct , but it s defo better than the realtek garbage on the motherboard.
Reply 323 of 342, by Shponglefan
I have a USB isolator on one of my systems that has an external audio interface.
Of course that only helps with external audio interfaces, not internal.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 324 of 342, by shevalier
bitzu101 wrote on 2026-07-27, 15:59:
Microsoft is starting to revoke drivers with expired certificates this spring.
My X-Fi Titanium HD is still working for now, but alas, it’s only a matter of time.
And without up-to-date drivers, these sound cards are just a pretty piece of PCB.
In the sense that buying Z(xr)/Recon right now is absolute insanity.
That’s the beauty of a USB DAC — it’s just a generic USB device. You plug it in, and it just works.
Reply 325 of 342, by Law212
bitzu101 wrote on 2026-07-27, 15:39:
So what do you think about this one?
I had that card and done me very well for over 4 years. very good card. I sold it on ebay for 40 pounds or so. You can probably find one at a similar price. It has a dedicated chip , it s a very good card for the money. Much better than that Audigy Fx V2 crap they now sell at the bottom end.
Thanks, ill look on marketplace
Reply 326 of 342, by bitzu101
shevalier wrote on 2026-07-27, 17:13:
Microsoft is starting to revoke drivers with expired certificates this spring. My X-Fi Titanium HD is still working for now, but […]
I understand you , 100%. It s just not for me.
Drivers will always be there. If they remove the certificate , then will be moded drivers. There will be work arounds.
Reply 327 of 342, by shevalier
bitzu101 wrote on 2026-07-28, 08:16:
Nope.
There are only two ways to sign a driver:
The legit way:Prove that it is your intellectual property and brand (sign a contract with Microsoft) and pay $2,000 for each signed driver.
Steal a certificate from somewhere:But it will be revoked immediately as soon as it becomes clear that it's invalid.
It looks like Creative’s software is on the compatibility whitelist, but nobody knows how long that will last.
It’s just easier to grab an AE-5 Plus and stop sitting on a ticking time bomb.
Reply 328 of 342, by bitzu101
shevalier wrote on 2026-07-28, 09:09:
Nope. There are only two ways to sign a driver: The legit way:Prove that it is your intellectual property and brand (sign a cont […]
Nope.
So how come I can use my X-FI from 2006 in my windows 10 machine? with the same old drivers? Or my audigy 2 zs with my retro windows xp 32 bit? this one is even connected to the internet.
Reply 329 of 342, by shevalier
bitzu101 wrote on 2026-07-28, 11:03:
Nope.
https://techcommunity.microsoft.com/blog/wind … ver-pro/4504818
https://x.com/The_Cyber_News/status/2070267289971392845
Microsoft is having another security episode
Reply 330 of 342, by bitzu101
shevalier wrote on 2026-07-28, 12:32:
https://techcommunity.microsoft.com/blog/wind … ver-pro/4504818 https://x.com/The_Cyber_News/status/2070267289971392845 Microsof […]
Nope.
Can you explain in normal human being terms what this means? I don t understand a thing...
Reply 331 of 342, by Falcosoft
... Nope. There are only two ways to sign a driver: The legit way:Prove that it is your intellectual property and brand (sign a […]
Nope.
This is not entirely true. Self signed drivers can also work. That is you can install any self signed certificate on your own PC into the Trusted Root Certification store and then you can sign any diver files with this certificate. If you also enable test mode on Windows by running
bcdedit /set testsigning on
you can use any driver files on Windows as long as you want.
You can use this tool to make the above described process somewhat more user friendly:
https://www.ngohq.com/2008/04/25/driver-signa … ment-overrider/
Website, Youtube
VST Midi Driver Midi Mapper
Reply 332 of 342, by shevalier
bitzu101 wrote on 2026-07-28, 12:48:
A driver file has a 'certain checksum of all its data' calculated and stored in a special area inside the file.This prevents the file from being modified.
The expiration date of this 'checksum' is also specified. It is necessary so that if the 'checksum calculator' is stolen, it cannot be used forever.
The OS itself features a built-in check for both this checksum and the date.It also includes two exception lists: a 'blacklist' (for drivers known to be bad despite meeting all formal validity criteria) and a 'whitelist' (for cases when the time has expired, but the driver is still not blocked).
For major manufacturers, Microsoft makes an exception by adding their expired drivers to this very whitelist.As long as these drivers do not cause any problems for Microsoft.It seems they decided last year that there were already enough problems, and they started a policy of shrinking this whitelist in this spring.
Creative is still on it for now, but no one knows for how long
Falcosoft wrote on 2026-07-28, 13:53:
That’s also an option. But how long will it last?
As far as I know, X-Fi drivers definitely do not support Core Isolation / Memory Integrity.
For Recon3D / Z(xR), they most likely don't either.
Even the AE series didn't get a driver with this feature right away.
And Microsoft loves to forcibly enable all kinds of security features, making them mandatory. 🙁
Reply 333 of 342, by Falcosoft
shevalier wrote on 2026-07-28, 17:00:
Yep, if the problem is not the certificate but the driver itself then not much can be done.
But all I can say is that I can still use my SB Audigy 1 and SB Audigy 2 ZS even on Windows 10/11 despite the fact that the Audigy 1 was released 25 years ago. We can hope that at least for good/popular hardware there will be alternative solutions.
Website, Youtube
Reply 334 of 342, by RetroGamer4Ever
The mainstream SB cards from the PCI/PCIe generation - which pretty much all of us have - work pretty well under Linux, but the advanced/premium PCIe cards do not, likely due to lack of reverse engineering resources by audio system devs, as they have to get their own hardware via donations, scrounging, or outright buying when it's available.
Reply 335 of 342, by bitzu101
A driver file has a 'certain checksum of all its data' calculated and stored in a special area inside the file.This prevents the […]
a complete cracked and pirated version of windows?
I mean , win 11 is pretty poor as it is , i ve had to install so many scripts and disable so much crap , I could not care for a second if i use a 100% cracked and pirated version that has no crap and "security features" that are only there to benefit microsoft. I did pay for my windows , but I don t want all this crap , certificates , siganatures , ai , cortana , etc. i just don t want it.
If it would still work today , I could easily live with windows XP with no bloatware.
Microsoft has gone dystopian , Creative no longer makes chips.. this is just silly...
Is creative even plannign on making a new chip ever? If not , mind as well collapse. Let someone else that wants to make good products come to the table...
Reply 336 of 342, by sfryers
I'm still using a ZxR on my main Windows 11 machine. It currently works perfectly with the 6.0.102.75 drivers, but I hold my breath every time Windows reboots after an update 😂.
The attachment zxr.jpg is no longer available
MT-32 Editor- a timbre editor and patch librarian for Roland MT-32 compatible devices: https://github.com/sfryers/MT32Editor
Reply 337 of 342, by shevalier
sfryers wrote on 2026-07-28, 21:03:
Does Core isolation/Memory integrity work after installation?
Because it's a 2020y driver
Reply 338 of 342, by sfryers
shevalier wrote on 2026-07-29, 05:02:
Memory Integrity is switched on, Stack Protection is off. Not sure if the latter is due to the ZxR driver or not:
The attachment Core Isolation.jpg is no longer available
Reply 339 of 342, by shevalier
sfryers wrote on 2026-07-29, 07:01:
Great. That means my information is outdated. When I looked into it, things weren't looking so good in that regard.
