First post, by Ahrle
- Newbie
Hi everyone
I’m losing my mind with this 486 build that has become completely unstable. While I suspect severe IRQ and DMA resource conflicts, I’m not entirely ruling out motherboard issues at this point. The PSU has been swapped for an Antec 380W, so I doubt it is the problem.
Specs as following:
- ECS UC-4914G
- i486DX2/66, actively cooled
- 2x32MB RAM (memtested 9 passes, no errors)
- 541MB Conner drive
- ET4000/W32 VLB
- CT3900 ISA 28MB
- Lo-Tech MIF-IPC-B connected to MPU-401 and a bunch MIDI modules
- 3Com ISA NIC
- MS serial mouse
The symptoms have been piling up, starting with the CPU randomly downclocking from 66 MHz to 16 MHz on roughly every second soft reboot. Sometimes this happens even while actively running Windows 95, rendering the system painfully sluggish. Hard reboots always revert it back to its full 66 MHz.
On top of that, every other time the external MPU-401 interface is connected, the system fails to detect it and defaults back to the AWE32 CT3900. The times the MPU-401 actually is detected, it often works great momentarily, until certain notes start sounding glitchy and corrupted, or the device shows up in Device Manager with an exclamation mark. A reboot may fix the problem, and it also remove the device entirely.
The 3Com ISA NIC has to remain permanently disabled - if turned on, Windows throws a VxD blue screen immediately on startup.
Yesterday, I was just chilling some MIDIs when out of nowhere a "Windows protection error, You must restart your computer." appeared.
Rebooted it six times since, with various results - mostly unable to finish loading Windows at all, but also once got 25% through "Add/Remove hardware" until hard freezing.
It has never been this broken before, but I suspect IRQs are haunting me again. Device Manager isn't giving anything useful, assuming I could even get into Windows to begin with.
I'm eager to know how on earth you reliably figure out which IRQs and DMAs are actually in use vs. free on a setup like this. No conflicts are present in Device Manager. Any insights, or troubleshooting ideas on what might be causing these crashes would be hugely appreciated!
Project 357575: ECS UC4914-G | i486DX2-66 | ET4000/W32 | CT3900
Main: IBM PC300PL | PIII 750 | Viper AGP + V2 SLi | CT4500
