Reply 20 of 46, by Errius
I had difficulty reading a damaged 360 KB floppy a while ago. I finally got an image of it using RESQFLPY, however certain files were still corrupt. Others were OK though.
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 21 of 46, by jesolo
That is essentially the same I did.
Made a copy of the disk and then ran Norton Utilities on it (since the original was unreadable under DOS and I didn't want to cause further problems).
I think some of the files were corrupted, but it's fortunately not a crisis.
But, as you've stated, once a disk goes bad, then you can end up with some files being corrupted.
Reply 22 of 46, by Robin4
Hi
Iam now being busy trying to make an image of the disk..
There are a few bad sectors on the disk, but it seems to be readable fine on my NEC V20 XT clone.. I can tell these files are on the disk:
Command.com
Cdisk.sys
Config.sys
Turbo.com
Turbo.doc
Cdisk.doc
Tu.com
7 files 30,203 bytes used and 274,432 bytes free.. Iam trying to upload the copy i made, but can tell if it would work for you.
Device line in config.sys is
device=cdisk.sys
Has someone the diskcopy.com file from Dos 6.22 for me?
Reply 23 of 46, by jesolo
Thank you for the files.
Sent you a PM.
Reply 24 of 46, by Robin4
I think iam going trying to use diskcopy to clone that protek disk.. First cloning it, then trying to image the good copied disk in my Pentium III 550Mhz setup with 360KB disk drive installed..
I use a USB transfer cable to transfer the files from internet from the Intel core i7 2600K to my pentium III machine.
Reply 25 of 46, by GrooBR
Hi
Can you scan this motherboard's manual ?
It apperars to be the same of mine.
Thank you,
Reply 26 of 46, by kalohimal
GrooBR wrote on 2019-08-10, 23:29:
Hi Can you scan this motherboard's manual ? It apperars to be the same of mine. Thank you, […]
Hi
Thank you,
It's available here.
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 27 of 46, by Cezary
Im looking for help, my JUKO ST (green board) find some damages
Can someone help me, what is the resistance on the board:
R1=
R2=
R3=
R4=
R5=
Thanks
Reply 28 of 46, by Miphee
Cezary wrote on 2020-07-20, 22:50:
R1= 820R
R2=12K
R3=4,7K
R4=680R
R5=680R
All 5% tolerance.
Reply 29 of 46, by Cezary
Miphee thanks a lot
Reply 30 of 46, by SaveTheHuman5
HI everybody!
I own the same motherboard and have a big question.
There is no batter in this board.
I cant put to run, I'm in the process of clean, and waiting for an XT keyboard.
But I inspect in the clean process and won't see any battery.......
Some info about this please?
Reply 31 of 46, by wbahnassi
No battery here (thank goodness). The IO card you use for it might have a battery for time (mine does). And then you have to use TIMER.COM to program the time or propagate it to DOS during boot... or just enter date/time on every boot (vanilla DOS boot without Autoexec/Config).
Fantastic board if you ask me... and the turbo button makes all the difference for XT-class software.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 32 of 46, by SaveTheHuman5
Thanks for the info wbahnassi
And yes no battery here.
One more question.
This board only work with 5 1/4 floppy 360kb?
NO way to make this work with 1.2mb floppy?
Reply 33 of 46, by wbahnassi
I think XT cannot recognize 1.2MB, but I remember I read there were ways around that. My Juko machine came with a 360K 5.25", a 720K 3.5", and a 10MB MFM HDD. The floppy drives connected to a controller card that has a battery on it too, and the HDD connected to an MFM controller card.
So yeah, the design allows for 720K floppy drives at most. I haven't tried connecting a 1.2MB to it, but the mobo's dip switches can only specify how many drives you have connected.. not their type.
Reply 34 of 46, by holoprox
Miphee wrote on 2020-07-21, 03:58:
R1= 820R R2=12K R3=4,7K R4=680R R5=680R […]
R1= 820R
R2=12K
R3=4,7K
R4=680R
R5=680R
All 5% tolerance.
Does allways c14 getting so hot? 62 C
RAM and chipset cold...
POSTcard little use...
Won't boot, tried 4 bioses
https://theretroweb.com/motherboards/s/auva-c … -baby-xt-bxm-12
must be something like this...
Open to suggestions!
150+ retro computers on board!
80+ flightsticks!
Reply 35 of 46, by aVd
Robin4 wrote on 2017-04-17, 02:09:
Hi […]
Hi
Command.com
Cdisk.sys
Config.sys
Turbo.com
Turbo.doc
Cdisk.doc
Tu.com
device=cdisk.sys
Hi, @Robin4,
And thanks for the shared utilities diskette image.
TU.COM utility is pretty useless in this state - it only resets wait states to their default values.
There is something wrong with the TU.COM disassembled code shown here, since it generates 5 bytes of redundant data code (DB) at the end of the com-executable. Probably this is also a result of improper floppy bad sector recovery.
The TU.ASM code should look like this (without the useless DB data at the end):
    org 100h
cli
in al, 70h
mov al, 95h ; 1001`0101b
out 70h, al
sti
sti
int 20h
TU.COM should be 11 bytes in size, not 16.
what comes around goes around
Reply 36 of 46, by aVd
I have some newer tools and utilities for Juko Super Turbo motherboard, that come from another setup diskette. I can't recall from where I got them.
STURBO.COM - a newer version 3.00 of TURBO.COM
CDISK.SYS - a newer version 3.00 of RAM disk driver
CCACHE.SYS - HDD caching driver ver. 2.00
RATE.COM - HDD cache hit rate checker ver. 1.00
CPRINTER.SYS - printer buffer driver ver. 2.00
CP.COM - clears printer buffer ver. 1.00
READ.ME - some brief text documentation
README.COM - shows READ.ME
INSTALL.EXE - installer
The attachment Juko_ST_Utils.zip is no longer available
P.S. Ans here is the correct TU.COM utility - 11 bytes in size:
The attachment TU.zip is no longer available
It is still almost useless like the damaged version from the recovered diskette image. Who will gonna change wait states set by jumpers to their defaults from DOS, and why? I have some better idea for this piece of code.
Reply 37 of 46, by aVd
My previous post makes this one kinda useless, but for the sake of software preservation I fully recovered the files from this attachment:
The attachment Juko_Utils_Recovered.zip is no longer available
It seems like, that TIMER.COM is not part of the original driver diskette, since it is a revision of PC TIMER 2.x found on -0degree site and it works only with specific 8-bit ISA multi I/O cards.
Reply 38 of 46, by aVd
aVd wrote on 2026-08-05, 05:54:
And my idea has been brought to life here: New DOS Tools for Juko ST motherboard and XT clones based on VDL C1, TD3300A, NEC 567 or Hitachi HG62E22R36FS chipset . There are two new tools for Juko ST motherboard and similar motherboards with VDL C1 chipset (and clones like Tamarack TD3300A, NEC 567 and Hitachi HG62E22R36FS):
1) JSTWSR.COM - JSTWSS "Juko ST Wait States Reader" version 1.0 is tool for reading the wait states values in VDL C1 chipset registers.
2) JSTWSS.COM - JSTWSS "Juko ST Wait States Setter" version 1.0 is tool for reading and setting the wait states values in VDL C1 chipset registers.
Reply 39 of 46, by Babasha
aVd wrote on 2026-08-13, 21:05:
And my idea has been brought to life here: New DOS Tools for Juko ST motherboard and XT clones based on VDL C1, TD3300A, NEC 56 […]
Tnx!
Will test it after Semptember,1.
Need help? Begin with photo and model of your hardware 😉
