First post, by jesolo
I've recently managed to acquire an XT motherboard, complete with an NEC V20 12 MHz CPU, the manual & utility diskette.
Unfortunately, the utility diskette (due to its age) has become unreadable with data reading errors.
I've attached a picture of the motherboard, manual and utility diskette.
I was hoping that someone might perhaps have (or know where I can find) the utility software that came with this motherboard.
The volume label on the diskette is "UX-UTILITY" and the main utility that is on the diskette is a file called "TURBO.COM".
I know that this is a small software utility that, when loaded, will enable a user to switch between normal and turbo mode by pressing either "CTRL"+"ALT"+"+" or "CTRL"+"ALT"+"-".
Fortunately, the motherboard can also be adjusted via a hardware turbo switch, but I would just like to obtain the software as well.
2.19 MiB
UX Turbo Mainboard
1.52 MiB
XT Turbo manual & diskette
Reply 1 of 29, by Jo22
Hey, that's a nice board! Congratulations! 😀
Sure the disk is hopelessly damaged ? It doesn't look too shabby.
From personal experience, even dirty disks can be partially saved now and then.
Sometimes this involves the use of a cleaned drive or a 360K drive.
Personally, I try to copy files manually first if I do enounter lots of read errors.
Sometimes lifting the floppy heads manually with the lever helps to find the sweat spot of maxium readibility.
I know, that sounds very amateurish, but it worked several times for me. 😊
Another trick is to use WinImage and try to re-try reading the disk on and on.
Sometimes I combined that with inserting an alcoholl (isopropyl) soaked spare floppy (dirty disk->alcohol disk->pause->dirty disk->alcohol disk->pause..).
That was only a last resort, of course. Doing so will damage the floppies (esp. the fleece) beyond repair. I don't recommend that.
Anyway, maybe other Turbo utilities will also work ? Maybe you'll find a fitting utility by searching for the chipset.
Otherweise, I have no clue what to do. I'm still learning about XT machines..
Good luck! 😀
Reply 2 of 29, by Anonymous Coward
Your board is the Juko ST.
Reply 3 of 29, by jesolo
Thank you for the advice.
I did try by cleaning my floppy drives (tried it with two floppy drives).
I even tried cleaning the disk itself, but no luck.
I'll try searching around for the Juko utilities.
Reply 4 of 29, by carlostex
This is the kind of board i use in my Turbo XT build. Quite speedy for an XT. I've been looking forever for the 10Mhz 8086 version but that one is extremely hard to find.
Reply 6 of 29, by jesolo
Errius wrote:
Can these boards run at precisely 4.77 MHz?
I've since packed away the motherboard as I'm wanting to build it into another case but, when I tested it, Landmark 2.0 & Norton SI 6.0 did indicate it was running at 1.0x that of a 4.77 MHz XT (in "de-turbo" mode).
How "accurate" it runs at precisely the speed of a real IBM PC 4.77 MHz, I can't say.
However, I would guess that if you have an old CGA speed sensitive game, that only wants to run at 4.77 MHz, then it should be "accurate" enough to allow you to play such a game.
Reply 7 of 29, by jesolo
The closest I got to an 8086 was to buy an old Olivetti M24 (AT&T 6300) that runs at 8 MHz. I believe that CPU can be upgraded to a faster version.
Reply 8 of 29, by Predator99
Nice board!
I would also recommend to try some other floppy drives, had success with many old floppies that failed to be read in one.
What is the exact size of the file?
Is there any hint in the manual how to enable this feature by Software?
Reply 9 of 29, by jesolo
Predator99 wrote:
Nice board! […]
Nice board!
I did try to read it another floppy drive, but no luck.
Unfortunately, the disk has become totally unreadable (I'm getting the infamous "General Failure" error in DOS) and I therefore cannot look up the contents on the disk or their file sizes.
The manual indicates that you just run the "TURBO.COM" utility after which you can use the shortcut commands on the keyboard (as described in my original post) to either run the PC in "normal" or "turbo" mode.
Reply 10 of 29, by Predator99
I would try to create a disk image with your favorite utility and note what sectors on the floppy are actually unreadable. Post that image if its not too bad...maybe we are able to reconstruct this file 😉
Reply 11 of 29, by jesolo
No luck - I think the magnetic parts of the disk was too far gone.
Reply 13 of 29, by Predator99
Have found this here
Category: resident utilities
INT 13 - UNIQUE UX Turbo Utility - SET TURBO MODE
AX = FFFFh
BH = AAh
BL = subfunction
00h installation check
Return: AX = 1234h if installed
01h turn on Turbo mode
02h turn off Turbo mode
03h set Turbo mode according to hardware switch
04h set disk access to Turbo mode
05h set disk access to Normal mode
Return: nothing
SeeAlso: INT 15/AH=DFh
Index: installation check;UNIQUE UX Turbo Utility
Should be simple to rewrite it on your own 😉
EDIT: But seems to be related to disk access???
Reply 14 of 29, by jesolo
Predator99 wrote:
Hmm...I assume it does not detect the right capacity? Maybe your drive tries to access 1.2 MB but its a 360K or 180K disk?
Do you have a 360k disk drive?
Yes, tried it in both a 360k & 1.2 MB floppy drive.
Reply 15 of 29, by jesolo
Predator99 wrote:
Have found this here […]
AX = FFFFh
BH = AAh
BL = subfunction
Return: nothing
Where did you find this?
Reply 16 of 29, by Predator99
Google 😉
http://www.delorie.com/djgpp/doc/rbinter/id/15/8.html
Can you test if installation check works? Do you know how to do with debug?
Maybe its a 180k disk and you have to tell the disk imager to treat it as one?
Reply 17 of 29, by jesolo
No, it was definitely a 360k diskette.
With the help of Norton Utilities, I was able to "reconstruct" some of the files on the disk. I've attached a zip file with the files that were on the disk.
Initially, Norton Utilities just renamed every file as "FILE000X" and, by using the DOS editor, was able to deduce what each file was.
There are basically three utilities on the disk, namely TIME.COM (I assumed the extension was .COM), TURBO.COM & CDISK.SYS
The other two files appears to be text files and I just named them the same as the two utilities with a *.TXT extension.
The two text files appears to be "broken" (some "garbage" at the end of each file) and I'm not sure about the RAMDrive file (haven't tested it yet).
Maybe someone will have some of these Juko utilities somewhere.
    Juko_util.zip
    4.86 KiB
    227 downloads
    Juko ST utilities
Reply 19 of 29, by jesolo
Predator99 wrote:
Looks good! Does Turbo.com work?
Would appear so - I don't have the actual motherboard installed right now, but by just running it on my other DOS PC, it does load the tsr and I am able to select the different "switches".
