Reply 2360 of 2435, by Ozzuneoj
- l33t
BitWrangler wrote on 2026-07-18, 22:53:Ozzuneoj wrote on 2026-07-18, 20:13:BitWrangler wrote on 2026-07-18, 18:19:Woohoo, think this is first yard sale computer part of the year. Cost next to nothing so I didn't expect much, bundled in AS bubble wrap. Thought it was gonna be some R5 200 or worse... actually turns out to be an HP 1030GT , which is kinda useful still. Will maybe go in a LP (not the tiny) 1155.
Nice! Is it a GDDR4 or GDDR5 model? There can be a pretty big performance difference between the two, though if it isn't really being used for gaming it won't matter much.
Very little ID on it apart from HP PN LO1825-001 ... and the HP resellers list it, but only as part number and bare minimum details, like GT1030 PCIe 2GB and that's all you get. There's a number advertised on eBay claiming GDDR5 and in shitty looking part stores, but no real definitive source. TechPU seems to use same photo for both versions which is unhelpful. Just gonna go see if GPUzoo lists it..
Edit: ugh, passmark data is a mess, they didn't distinguish between pascal, kepler and GDDR5 and DDR4 so there's 3 peaks on the graph and the average is way back from GDDR5 card scores it looks like.
Is it one of these?
https://www.ebay.com/itm/374975407018
If so, it's a super tiny card so may have reduced clocks (or just run hot), but... amazingly... it does seem to be a GDDR5 model. This Zotac uses basically the same PCB design and says GDDR5 on it:
https://www.ebay.com/itm/318534445838?chn=ps& … ction=view_item
So yeah, not a bad little card! With GDDR5 it is somewhere roughly in the realm of GTX 750 to GTX 750 Ti performance. No XP support though, since it is a Pascal GPU.
