Reply 540 of 571, by bloodem
- Oldbie
SlowA wrote on 2026-08-04, 08:58:The ESR of 18mOhms is too high. The stock Nichicon HM or Rubycon MBZ 6.3V 3300uF caps got about 10-13mOhms of ESR.
Unfortunately only Panasonic is available here, what is the worst outcome if I recap with Panasonic FR?
You can use Panasonic FR without any issue, nothing will happen, I've used them to recap 50+ boards.
On the CPU VRM there are multiple caps in parallel anyway, so effective ESR will be much lower. As long as the caps don't heat up excessively (which they surely won't) and you won't notice any instability, you are good.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
