First post, by Sh1nRa358
I tried to use DXCpl.exe with the latest debug version of dgvd2 but im not seeing any logs pop up unless i forgot how to use it. Im using the latest version of the Memoria mod with it as well. When using dgvd2 on dx12 for this game, i can reproduced a memory error crash 100% either through gameplay or their model viewer. Doesnt seem to happen with DXVK. Go in the model viewer and navigate to the environment section and just keep rapidly tapping the --> arrow button. Before the environment setting is completely navigated through, you will definitely get a crash halfway through with a silent crash. in game, if you play for about 30 to 45min, you'll get a crash with a memory error. This happens with most recent versions of dgvd2.
Reply 1 of 18, by Dege
I installed the GOG version of the game and also the Memoria patch. So now I have a config panel when launching a game. But where is that model viewer? Once I launch the game, I can only play the story.
Could you plz give a step-by-step guide to the viewer?
Reply 2 of 18, by Sh1nRa358
I have the steam version. dont know if that makes a difference. latest memoria patch. Start the memoria launcher > advance tab > model viewer on the bottom left of that page. Memoria version v2025.7.13
Reply 3 of 18, by Dege
Ah, thanks, I think I found it. Did you mean this one?
I pushed the right-arrow key quickly, a lot of times but I got no crash. I used the x64 d3d9.dll from dgv 2.86.5. The game has a 32 it x86 version but the launcher launches the x64 one.
You need DbgView++ and need to set up the dx12 debug layer if you want to see a log from that (DX debug layer is part of the Windows SDK, but I guess you still have it installed):
Re: dgVoodoo crash with Rog Ally
For the _dbg version of dgvoodoo, you just need DbgView++.
Reply 4 of 18, by Dege
Btw, something comes to my mind: I've run into some D3D12 crashes with some games during my testing. The reason was that option DirectXExt\D3D12BoundsChecking was disabled by default and those game needed that.
Modern GPUs like the NV RTX 5060Ti and Intel Arc B580 seems to be more sensitive for buffer overread than my old GTX 1060.
I'm pondering on whether to make it enabled by default, or even remove that option entirely, but I didn't yet do much testing to compare the performance.
Reply 5 of 18, by Sh1nRa358
try it with a hd texture pack. like mine. with it on i get this error with the op instructions to replicate. Here's the texture pack: https://www.nexusmods.com/finalfantasy9/mods/120
btw, ive completely deleted the x86 version to save space so i'm on the x64 version. The bounds checking option didn't solve the issue. Yes I meant that one. the dm downloads no longer work but opening that trace app, putting the game on 1 affinity core, and using the debug layer version with the +api trace, nothing fills the directx properties in the trace app.
Reply 6 of 18, by Dege
Ok, I downloaded the texture pack. How to use it? Should I simply copy the folders present in the .zip into the game "resources" folder?
Reply 7 of 18, by Sh1nRa358
drop into the main folder (with launcher exe) and select it to be on in the memoria launcher mod section
Reply 8 of 18, by Sh1nRa358
bump
Reply 9 of 18, by Dege
I extracted the rar into the main game folder but I don't have any mods (see my folder structure):
Reply 10 of 18, by djc5166
No crash here either, dgvoodoo v2.87.2 x64, memoria v2025.7.13, Steam version
Reply 11 of 18, by Sh1nRa358
You can delete the 86 folder if you only want 64 bit. im on 64 bit so best to be on same page. we keep missing each other 🤣. im also on AMD so that could be a factor in the dx12 memory leak crash. only other thing i can think of is make sure the game is on a non-system drive and/or launch with admin priviledges. also dgvoodoo2 needs to be installed in the x64 folder. Here is the video of the crash.: https://youtu.be/7AS2nHB8EG0
Reply 12 of 18, by Sh1nRa358
yoooo hoooooo. bump. you have the mods in a folder called features. that means you took them out of the Sh1nRa.HD.Crystal.TexturePrise folder. you need to keep those folders inside the Sh1nRa.HD.Crystal.TexturePrise folder in the main directory just like i have in my image. that's the 1st folder you see in the zip. so that's the folder to place in the main directory. i have 8gb of vram on an amd machine. Using dx12 fills it up fast and makes the game crash but using dx11 does not.
Reply 13 of 18, by Dege
If I create a private storage, could you upload your entire game installation to that? Or is it too big?
Reply 14 of 18, by Sh1nRa358
with 1 texture pack mod, its 5gb
Reply 15 of 18, by Dege
Ok, then if I give you a Google Drive link in private, could you plz upload it to there?
Reply 16 of 18, by Sh1nRa358
sent to your dm
Reply 17 of 18, by Dege
Thanks!
I looked at it and indeed, there is resource leakage. It's enough to switch back and forth between 2 models (I used ACTORS) to make the systemmem and VRAM usage increase.
However this is not D3D12 specific, it comes with native D3D9 as well. The model viewer seems not to release the texture(s) of the current model when switching to another, it just leaks away, I checked it in dgV.
So I think the problem is with the application itself.
With D3D9/11 the OS swaps out the leaked resources through the virtual VRAM mechanism so it's not a problem when the allocation exceed the physical size of the VRAM.
D3D12 does not do that. Altough I'm not sure how it exactly works because I boosted my VRAM usage to 17GB on my 12GB card and still didn't get any crash, only loading of the models got slower and slower as it did on your video before the actual crash.
Reply 18 of 18, by Sh1nRa358
It does it in game as well while playing when on dx12 for a while. Unfortunately this is not the only game it happens on when using dx12. what should i tell the devs of memoria in order for them to look into it? hmm, i do get the same issue in dx9 and it's an even faster crash
