Retro Rig Photo Thread
Reply 3320 of 3336, by FlyingToaster
This has been an ongoing project for the last year-ish; after digging one of my nasty old circa-2000 Windows PCs out of my dad's basement, I decided to give it a full refurb. Apparently mice had been nesting inside, and minor flooding in the basement had caused a significant amount of rust:
The attachment 20250329_190246_edit.jpg is no longer available
The attachment 20250329_203114.jpg is no longer available
Soaking the case metal in industrial-strength vinegar removed most of the rust, but unfortunately I had to replace several of the original components that had failed over the years. On the plus side, I think the case cleaned up very well:
The attachment IMG_6272.jpg is no longer available
The attachment IMG_6276.jpg is no longer available
Components list:
-Enlight 7237 mid-tower ATX case
-StarTech ATX 20/24-pin 400-watt PSU
-FIC AD11 Socket A / Socket 462 ATX motherboard
-AMD Athlon Thunderbird 1400C 1.4GHz CPU
-Corsair 256MB UDIMM DDR PC-2100 RAM [2x / 512MB total]
-ATI Radeon 9600 Pro 128MB AGP
-SanDisk 128GB Extreme CF card + IDE-to-CF adapter & 5.25" mount bracket [2x / 256GB total]
-Generic PCI network card
-Creative Sound Blaster Live! Platinum 5.1
-Creative Sound Blaster Live! Drive IR
-Sony MPF920-D 3.5” floppy disk drive
-Plextor PlexWriter 24/10/40A CD-RW drive
I've replaced every case/mobo fan with Noctua equivalents to help reduce noise, plus the PSU's internal fan. As a Win98SE box, the Radeon 9600 Pro is probably overkill, but I got a good deal on it as NISB. It's been a pleasure resurrecting this machine, which I've begun to affectionately refer to as "Rusty," and pairing it with a 19" CRT transports me straight back to the early 2000s every time I use it.
The attachment IMG_6295.jpg is no longer available
Reply 3321 of 3336, by gerry
FlyingToaster wrote on 2026-07-03, 02:21:
This has been an ongoing project for the last year-ish; after digging one of my nasty old circa-2000 Windows PCs out of my dad's […]
Components list:
great rescue, nice spec too - Athlon 1400 and the agp card make it great for everything 98se (and pretty good for win xp if you want that)
Reply 3322 of 3336, by dr_st
That's not a rig, but I found the original CD that came with my first ever CD Recorder - a SCSI Smart&Friendly. Many years ago I burnt The Need For Speed: Special Edition on it. Back before using CD images for everything, I liked duplicating my original discs and using the copies to play, to improve the longevity of the originals.
Burnt CDs tend to degrade much faster; this one still reads fine, even if discoloration is obvious at the edges. The disc is more than 25 years old and was burnt probably 15-20 years ago.
Reply 3323 of 3336, by CC-Adam
RetroPCCupboard wrote on 2026-06-09, 21:14:
Law212 wrote on 2026-06-09, 14:30:
Thanks ! I'm glad someone else appreciates that the desk is also period correct. I love this set up , I just need a good KVM set up but now I am enjoying my retro PC set up immensely
I wish I could see it, but your chosen image host doesn't display images in the UK.
I have the same trouble in the UK, so just use the Opera browser (in Windows and Linux) it's got a free built in VPN perfect for this issue!
Reply 3324 of 3336, by allesclar
Components list:
Love it.
Nice to see another Geekenspiel customer? 😀
I have an old unit and it has a smell of musk (not Elon) about it.
Did you find this unit had an odd off smell due to being in the basement and if so, how did you get rid of it?
Great pictures.
MSI MS6156/Pentium III 450Mhz/256MB SDR DRAM/GeForce Ti 4200/Sound Blaster PCI 128
Asrock K7S41GX/AMD Athlon XP 2400/512MB DDR DRAM/GeForce 6800/Sound Blaster Live 5.1
Asus P5K/Pentium E6600 2.40GHz/4GB DDR 2 DRAM/GeForce 8800GT/Sound Blaster Audigy 2
Reply 3325 of 3336, by allesclar
vad4r wrote on 2021-05-02, 05:55:
In Germany we have the Voodoo Alert Forum https://www.voodooalert.de/board/forum/ , a Forum roundabout the 3Dfx cards. The Users […]
In Germany we have the Voodoo Alert Forum https://www.voodooalert.de/board/forum/ , a Forum roundabout the 3Dfx cards. The Users make every year some Lanparties (before Corona). The lanparties have themes like PCs only with 3Dfx included or "Midrange lanpartie".
Midrange mean: only 1 CPU Core and GPU max to Nvidia 7xxx oder ATI 1xxxx. This is one of my midrange PC:
CPU: Intel Pentium 4 Prozessor 661 "Cedarmill" 3,6Ghz @ 4,38Ghz (max. 4,5Ghz)
CPU cooler: Zalman CNPS9900, converted to CNPS9900max rotor
Case: Zalman GT-1000 "Z Machine"
Mainboard: Asus Striker Extreme (NVIDIA nForce 680i SLI)
RAM: 4GB (2x 2048MB) GEIL Black Dragon DDR2 6400, CL4-4-4-12 with Xilence Dual Heatpipe Passive Memory Cooler
Grafik: 2x XFX GeForce 7950 GT 610M XXX with cooler conversion from Point Of View GeForce 9800 GTX+
NIC: 2x onboard
Sound: Asus SupremeFX
HDD1: WD WD2002FAEX Black 2TB
HDD2: Hitachi HUA722010CLA330 1TB
ODD: LITEON DVD RAM
PSU: be quiet! Pure Power 10 400W
Frontpanel: Lamptron FC5 V2
FAN: 1x 120 & 2x 80 Zalman
Weight: 18,8kg
The attachment 2018_01_22 zMachine (0).jpg is no longer available
The attachment 2018_01_22 zMachine (1a).jpg is no longer available
The attachment 2018_01_22 zMachine (2).jpg is no longer available
The attachment 2018_01_22 zMachine (3).jpg is no longer available
The attachment 2018_01_22 zMachine (6).JPG is no longer available
To new? Please let me know!
Simply stunning setup you have there!!!
Reply 3326 of 3336, by NorsteinB
The attachment 486er fast fertig.jpeg is no longer available
Still have to connect the Roland RA50 (has full MT-32 functionality) and SC-55 to the PicoGUS and the sound system, but I didn't have any DIN5 cables for the MIDI commands and am unsure how to best route the sound without buying extra mixer stuff.
Other than that, I am pretty happy about it:
ASI T-Bird case
Gigabyte GA-486AM/S motherboard w/ 512 K cache
AMD Am5x86 P75-S 133 MHz
2x32 MB 60ns FPM RAM
ELSA Winner 1000 Trio (S3 Trio64 PCI 2 MB)
Terratec Gold 16/96 (ESS 1868F)
PicoGUS
Adaptec AHA-2940 SCSI controller
dual Nakamichi MJ-5.16 drives (5x CD changer, 16x speed)
Mitsumi 3.5" floppy
Peripherals:
Yamaha YST-MS30 2.1 sound system
Cherry G80-1000 keyboard (Cherry MX Blue switches)
Cherry M-5400 mouse (via PicoGUS serial emulation)
Roland RA-50
Roland SC-55 Mk. II
Eizo F931 21" (Trinitron Aperture Grille, 160 Hz up to 1024x768 Hz, up to 2048x1536 resolution at 85 Hz)
Reply 3327 of 3336, by FlyingToaster
allesclar wrote on 2026-07-09, 21:59:
Love it. […]
Components list:
Love it.
Great pictures.
Thank you! Yes, the stickers are all from Geekenspiel.
As far as the smell, stripping down the PC and giving the case a concentrated vinegar bath (and then a thorough rinse with water) seems to have taken care of any lingering odors. It's powerful stuff!
Reply 3328 of 3336, by FlyingToaster
NorsteinB wrote on 2026-07-22, 14:50:
Still have to connect the Roland RA50 (has full MT-32 functionality) and SC-55 to the PicoGUS and the sound system, but I didn't […]
ASI T-Bird case
PicoGUS
Mitsumi 3.5" floppy
Peripherals:
Roland RA-50
Roland SC-55 Mk. II
Beautiful work, and very jealous of your MIDI setup!!
Reply 3329 of 3336, by Lodge_
CPU: AMD K6-2+ 570ACZ with K6-3+ Full Cache Enable Mod @ 600Mhz
MB: DFI P5BV3+ (REV.C+)
Graphics: Voodoo 3500
Memory: 256MB
Sound1: Terratec Gold 16/96 (with Dreamblaster X2)
Sound2: Gravis Ultrasound PNP (David E. Larsson GUS PnP clone)
OS: Windows 95 / OSR2
This might be my favorite build! It all started with a banged-up, rusty AT case and a desire to build a replica of my first PC, which was a Pentium 120 with Windows 95 that I got in 1996. I've rebuilt this PC a few times over the years, but now I've pushed the Socket 7 platform and AT form factor as far as I want to.
The OS had to be Windows 95 because that was what my first PC ran, plus it always warms my heart to hear the legendary Brian Eno startup sound. The Voodoo 3500 was the last part I acquired just a few weeks ago. As for sound, I chose the Terratec sound card because I had one back in the day. I used it to write songs in Impulse Tracker. The GUS PnP is there for DOS.
I love FMV adventures from the '90s, as you might guess from the stickers and this build is great for those. I've also played games like Blood, Doom, X-COM 2, and Star Trek: 25th Anniversary, as well as other point-and-click adventures, in DOS.
I haven't played many FPS games on it yet, but I think that will change with the Voodoo 3500. I previously had a GeForce2 MX400 in this build. Surprisingly, the Voodoo scored higher in 3DMark 99.
Reply 3330 of 3336, by pete8475
Components list:
Very nice, love those cases!
Do you find the cooling better on the cpu with the fan in that orientation? Have you tested it blowing down too?
aka pete4237.5
Reply 3331 of 3336, by arcofreccia
Hi, guys, these are my two vintage retro computers. 😀
Pentium III-S Tualatin 1,4 Ghz - Ram 512 Mb PC133 - Hdd Maxtor 80 Gb IDE - Iomega Zip 100 Mb - Floppy 3,5" - Sound Blaster Platinum - 3dfx Voodoo 5 5500 Agp 64 Mb - Windows 98SE
Pentium 200 MMX - Ram 64 Mb - Hdd 6,4 Gb IDE - Floppy 3.5" - ESS1868F (AudioDrive) ISA - Vga 2D Matrox Millennium II + Diamond Monster 3D (3dfx Voodoo) 4 Mb - Windows 98SE
Pentium 200 MMX - Ram 64 Mb - Hdd 6,4 Gb IDE - Floppy 3.5" - ESS1868F ISA - Matrox Millennium II + Diamond Monster 3D (3dfx Voodoo) 4 Mb - Windows 98SE
Reply 3332 of 3336, by Oxnard
Hi. newb here. I never had had a windows 98 PC this ncie as a kid. Unfortunately the orginal Compac Presairo that my parents had has long since been disposed of.
Lately, I had been feeling nostalgic about my time spent on the old compac Presario. We never had a 3D accelerator installed in that PC. I didnt understand how these things worked back then. Nonetheless, I still attempted to play games on our compac Presario. I just had to use the lowest resolution as they rendered in software. My meager game collection included MW2, battlezone rise of the black dogs and quake 2..
This gateway Oxnard is a beast in comparison to what we had back then. I paid a gentleman $140 to grt this from fb marketplace.
Specs:
Cpu: athlon K7 950
Mobo: MSI MS 6330 rev 2.1 (oem)
GPU: riva TNT2
Sound card: SB CT 5807
Ram: 320MB
HDD: IDE 128 gb (partitioned to 40 Gb)
Optical drives CD and DVD installed by me (DVD not working yet)
OS: windows 98 Se quick install (installed my me. The PC came with windows 9x Me which I didn't want. The PC now has USB functionality thanks the the win 9x Se quick install)
That's the gist of it. So far I ordered a few goodies for this. Im having a hell of a time to configure the audio to work 100% like its supposed to in MW2.
Reply 3333 of 3336, by Oxnard
arcofreccia wrote on Yesterday, 09:11:
How do you like sound blaster platinum? I've ordered that same one! It looked too fun to pass up.
Reply 3334 of 3336, by Oxnard
Sorry I wish I could edit these posts. Wow. A voodoo 5 too. Thats crazy man.
Here I've added picture of me unsuccessfully configuring the audio drivers for MW2.. ill get it eventually. Fun stuff.
Reply 3335 of 3336, by gerry
Oxnard wrote on Yesterday, 18:58:
Hi. newb here. I never had had a windows 98 PC this ncie as a kid. Unfortunately the orginal Compac Presairo that my parents […]
Specs:
Cpu: athlon K7 950
GPU: riva TNT2
Ram: 320MB
Nice PC, lots of games will work a charm on that - the TNT2 was a versatile card - able to play a wide variety of games from the late 90's really well
Reply 3336 of 3336, by Fletchsan
My Retro corner
Compaq Presario 2230 80 MB RAM Win 95
Roland SC-55MK II
Custom Win 98 SE P3-600 Katmai build in an Antec SX630 II case
- Biostar M6TBA v1.3
- 256 MB RAM
- Diamond Viper v770 TNT2 16MB
- 3DFX Voodoo2 12 MB
- SB AWE 64
- 3Com 3C905B-TX Fast EtherLink XL
- Cylon Eye Mod
+ Microsoft Sidewinder 3D Pro
I use a Belkin Soho kvm to switch between the two machines.
Interesting thing I discovered about the 2230 is that given it has 200 MHz Cyrix MediaGX "system on a chip" processor using the Roland SC-55 module for music in games increases the performance. I got another 20% in Doom offloading the music from the processor to general midi !
The Cylon Windows 98 start-up theme
https://youtube.com/shorts/yUB3bqo1PRM?feature=share
