First post, by BadHellie
Hi all, I am new here. As a premise, I am an expert dsp coder with a long experience, but I can't know everything.
For some personal reasons too long to explain, I need to write a D-110 emulator VST, because after some search I saw no such thing exists yet.
Roland made a D50 emulator VST, but the sound engine of the D50 is not quite the same as the D110, despite still LA. I am perfectly aware D50 LA is more advanced and how, but I need to reproduce a lot of custom timbres I had made in the 90's with the D110, and they must sound identical.
Eventually I stumbled across Munt, and I also found and tested the VSTi version of Munt, which however has little purpose to me, since it has no panel to edit patches !!
I have therefore some questions:
1. Is the MT32 LA engine the same as the D20/D110 (same rom samples, same analog waveforms, same TVF response) or it is different ? I never had any MT32 so I can't say. I ask because, in case they were the same, I could easily check Munt code for hints about emulation (in particular, the tricky part is the analog part, since it looks like the tvf is not a real filter, resonance is not a real resonance, and the sawtooth wave is somehow made from the square wave, also I haven't fully understood well how they coped with aliasing)
2. How can one edit custom patches with the Munt Vsti ? Even just for some tests ? I don't want to use Munt standalone if possible (I am using Reaper as my DAW). Is there any way to route a standalone MT32 sysex-based MT32 editor to Reaper Midi in, or is there any simpler solution to edit Munt Vsti patches from within my DAW ?
Thanks in advance 😀
Reply 1 of 16, by sfryers
BadHellie wrote on 2025-06-12, 12:25:
I believe the engines are very similar, but not identical. The MT-32 MIDI specification allows it to intepret D110 SysEx messages, but I understand the output will not always be exactly the same as a real D110.
This is possible using LoopMIDI (https://www.tobias-erichsen.de/software/loopmidi.html) or any other software utility that can create virtual MIDI ports:
  • Install LoopMidi
  • Install MT-32 Editor
  • Open Reaper and enable the LoopMIDI port as a MIDI In port
  • Insert Virtual Instrument on New Track using MuntVSTi
  • Set MIDI Input to LoopMIDI
  • Open MT-32 Editor and set the MIDI Out device to LoopMIDI.
The attachment MT32Edit-Reaper-MuntVSTi.jpg is no longer available
MT-32 Editor- a timbre editor and patch librarian for Roland MT-32 compatible devices: https://github.com/sfryers/MT32Editor
Reply 2 of 16, by BadHellie
Thank you a lot Sfryer for your answer, very helpful !
I will try out that way then.
My goal (well, experiment) by now is indeed being able to edit a mt32 patch with Munt, to just have one analog partial, to check the waveforms and filter response, just to understand if at least the analog part is the same as the d10/20/110. If this turned out the case, at least I can concentrate on 'decyphering' Munt source codes to attempt a reverse engineering (or kind of: I suspect even Munt is a kind of guesswork...)
Reply 3 of 16, by BadHellie
So, I managed to activate the workflow above and could start xperimenting 😀
It is a pity that Munt vst does not support patch editing though, at present it could have been the only LA vst emulator (if we exclude the official D50) !!!
From some preliminary tests, the analog part (the one I am interested with, because tricky to emulate) seems *very close* to the D20.
It looks like TVF uses waveforms computed for every note as in the D20 (in fact, if you shift a note with the pitch bender, resonance is shitfed too, which does not happen if you press the target key without bending).
Sawtooth also seems a plain signed multiplication (ring mod) of the resulting "filtered" square wave with a sine wave as in the D20. Ok !
Only differences found by now are:
1. D20 has a bug with resonance, which in some cutoff/res combination goes nuts - Munt has not this 'bug'
2. D20 seems using a slight HPF - in fact the square wave is not really square, but has the typical curvature of a slight HPF or DC filter applied
I can't say if the real MT32 behaves the same or not though, by not having one to test.
Well Munt source code can therefore be a good starting point for emulating a D10/20/110, it now seems.
I think I will contact the author of Munt VST asking if he has any plans to integrate a patch editor, trying to convince him it would be a nice thing 😉
Reply 4 of 16, by Spikey
Some points:
- The D-110 has a different drum set (and double the ROM, 1MB vs 512KB, which is probably mostly related to the drums)
- The D-110 has its PCM samples in a different order, so that needs to be changed on any patches that have a PCM sample
- Other parameters need tweaking to be equivalent (see next point)
- Sierra made D-110 conversions of their old MT-32 game patches, so you can view the changes between each in an editor like sfryers, which might help you see the tweaks needed in both directions
Synthesis-wise and for most other purposes, the MT-32 is a modified/simplified D-110.
Reply 5 of 16, by BadHellie
Of course, I avoided to mention the pcm part because I know it is different for sure!
Reply 6 of 16, by BadHellie
My focus is the analog part, where tiny details can sound very different. The pcm part substantially just boils down to playing the rom samples, looping, etc. I was starting to record all my d20 pcm samples, then soon I realized there was a d110 rom on the Internet, I managed to decode and exponentiate it and now I could check, they are identical to d20 and very different than mt32
Reply 7 of 16, by farvardin
I don't know how this emulator project went, but I've found some weeks ago a great D-110 emulator on github. It reused some parts of munt and mame, but there have been further developements to remove the mame parts. I've made a fork to fix a few things, and then the original project vanished 🙁
But the fork is still there, you can try it if you wish (it requires the original Roland Roms, link in the readme):
https://github.com/luginf/d110-vst-emulator
🎵 🏰 🎹 My chiptune and Dungeon Synth musics: 🐺 Website - Bandcamp - Spotify
Reply 8 of 16, by BadHellie
Hi, my emulator idea had a very low priority by the way. Then recently somebody managed to integrate munt vst with the editor, as I had requested, and the result is apparently working as expected, so I assigned my project an even lower priority 🤣
The D110 emulator you forked seems very interesting btw, thanks for pointing it out. Unfortunately I am not experienced with Github and with compiling 3rd party code, therefore I am unable to test it until there is a compiled Release for Windows available...
Reply 10 of 16, by BadHellie
Thanks, I found it !
Testing on Windows, several issues...
1. VST3 version: (reaper) does not respond to midi (midi message led stays off); + and - buttons at the left and right of the keyboard have no effect; even using the plugin keyboard, no sound can be heard; I strongly disagree on the choice to force users to put rom data in C:/. Rom data should be located inside the plugin folder (I place vst's in a custom location, D:/VST because I want to be free to use C:/ for the OS only)
2. Standalone version: still no sound despite I can clearly hear the test sound in Options/Test; the midi message led flashes if I play on the virtual KB but no sound is emitted; still + and - buttons have no effect.
Not sure if I should put this on Github issues or it's my fault...
Reply 11 of 16, by farvardin
I totally agree with you, the place for the roms should be configurable. I've changed it to allow to have them in the same folder as the vst or stand alone binary. It looks like it doesn't work yet. I've also allowed to customize the rom folder. It works (you can define this folder as "D:/myroms/" or "D:/VST/" if you wish. The problem is at the moment you need to start the D-110 to be actually able to change that. So for trying that on windows I've put the roms inside the recommended folder (c:\Program Files\Common Files\VST3\D-110 Data\", then I've defined the custom folder, and deleted the previous folder and it worked.
There is a new release with this fix (until I manage to fix the rest), I've tested the standalone version on windows, and I got some sounds. Are you sure you assigned the correct midi channel? You can right clic on the keyboard and select the one you want. Be sure to make the midi channel matching the assigned channel on the "PARTS"!
I can't test the vst3 version on windows at the moment, I've only tested it with a few linux DAW, I had problems with Carla (it detunes the sounds), qtractor (no sound), but it works fine with Ardour. I'm using the standalone version from my DAW (you have to right clic on the keyboard and select "omni" to get all the channels at the same time).
You can post here (I can't guarantee to check the forum often), and you can also open feature requests or bugs on github.
Reply 12 of 16, by BadHellie
Hi! I kept testing. It works !
Problem is, there is evidently some issue with proper handling of midi channel.
1. Why part 1 is assigned to channel 2 and so on until part R which is assigned to channel 1 ? Was it so in D110 ? In my old D20 all.parts were assigned by default to the channel with same part number, and part R was assigned to channel 10...nothing serious though
2. This is likely a bug...it seems that the vst version ignores the midi channel. It always receives on the channel set by keyboard menu. While imho this menu should just affect the target of the virtual keyboard ! If I set virtual keyboard to channel eg. 3, any external midi message, no matter its original channel, will be routed to channel 3...
3. Personally I would not even allow specifying a rom path. The vst plugin should simply look inside the plugin folder, and the standalone version in program folder. Otherwise it is a mess imho...I think every people would expect this behaviour... Trust me 😉
Anyway.....great great great work !
Ps the + - buttons work, it's me who initially failed to grasp their purpose !
Anything else seems ok by now, I will keep you uodated if required !
Ps2. I am now in vacation with just a spare pc, not in my music studio, no midi KB, pretty nothing but headphones, a mic and asio4all 🤣....so I can't really test it better...in october once I am back in my studio I will test it extensively and I will also consider a donation !!
Reply 13 of 16, by BadHellie
Well no I want to do it now. Please tell me a valid paypal email address to donate
Reply 14 of 16, by farvardin
1/ it seems on the original Roland D-110 they assigned channel 2 to part 1 but default. The original creator of this VST/emulator stated this in the Readme, and I've also found on page 17 of the manuel, the example shows the LCD screen with this. And there is a confirmation on this page : https://synthmania.com/2006/10/15/roland-d-110/ (and I think it's kinda awkward, but maybe it's also a reminiscence of the MT-32 which don't use the midi channel 1.
2/ I'm still thinking about a correct way for doing this. At the moment, to be able to receive everything from a connected midi keyboard, or a DAW (for replaying multi parts), you have to set the midi to "omni" (right click on the keyboard). The other mode is to filter and reroute to a given midi channel, always the same on the D-110. This way you can use you keyboard to record to any other channel, without changing the output channel on the keyboard (which is a PITA to change). Can you think of something else?
3/ the rom path is just an addition for the other ways of having the rom (along the binaries, in the vst folder...). So it doesn't hurt to have it.
Thank you for the proposed donation, it's possible to go listen my MT-32 synthpop album if you wish: https://garvalf.bandcamp.com/album/mt-32-espaces-lointains
but you'd also better give it to a local charity 😀 I'm not the original author for the emulator, it's just a pity he made it disappear without reason on his github page. Anyway, like me he used some LLM to help the development, what they can do is quite incredible. I've even asked to port the D-110 on android and it works! https://www.youtube.com/watch?v=qB9abX8oNX8
I've released a new version with the Android apk and some improvements and fixes... https://github.com/luginf/d110-vst-emulator/r … -v0.9.5-fixes14
Reply 15 of 16, by BadHellie
I think YOU deserve the donation instead. Why the original author removed his project ? Then, I've been searching for such a thing since years, to the point I even bothered the author of Munt VST asking to do such a thing, and I was really planning to start working at my personal emulator (which would have been a very long job) - no way, nothing showed up in my searches, having a Roland LA vst seemed impossible (I have the pirated Roland D50 vst but its engine and samples are quite different from the D20/D110). Now you forked it, and you also chimed in in my old thread very kindly to point out about your fork. It's obvious for me that it's you who morally deserve a donation, not the original author of a likely abandonware and never advertised project !
Reply 16 of 16, by BadHellie
As for the midi issue, I have no idea how things are coded there (nor I want to check 🤣) but, again, since it is about a multitimbral instrument, it should respond *exactly* to the specified midi channels, without any routing or anything else. If a part is set to respond to channel 1, the input midi channel 1 shall be sent to that part untouched.
The virtual KB should be a "horthogonal" thing, i.e it is optional (most people will be using a real midi KB), and it must optionally send its notes to the channel specified for it, mixing events with the actual midi input. But its output channel setting must not interfer with the actual physical midi input ! I have no idea why now the converse happens...
