First post, by arcofreccia
Hi, I need some help with an issue regarding the game Motorhead. I installed the game on my first PC (as mentioned in my signature), which meets all the game’s requirements. When I try to launch Motorhead, the monitor displays “mode not supported,” but I can hear the menu audio in the background, and the game starts on the track—yet I still see the “mode not supported” message on the monitor. I’ve tried lowering the audio acceleration to the minimum, reducing the monitor resolution, and even switching to 256 colors to see if that helps. The video signal isn’t reaching the monitor. However, I have a Diamond Monster 3D, and the game’s readme file confirms that the game supports Voodoo Graphics, specifically Voodoo 1. Could this be an issue with the LCD monitor? Thank you
Pentium200MMX/Ram64Mb/Hdd 6,4 Gb/Floppy 3.5"/ESS1868F/Matrox MillenniumII+Diamond Monster3D(3Dfx Voodoo)4 Mb/Win98SE
Pentium III-S1,4 Ghz/Ram512 MbPC133/Hdd Maxtor80Gb/IomegaZip100Mb/Floppy 3,5"/SoundBlasterPlatinum/3DfxVoodoo5/Win98SE
Reply 1 of 18, by leileilol
Motorhead's menu is 640x400x8@70hz. i'd assume your monitor hates that. Also, the default res for the Glide driver when a Voodoo's detected is 512x384x16, so it'll be switching to that during demo mode while nothing is yet configured.
Debian's fucked
Reply 2 of 18, by NeoG_
arcofreccia wrote on 2026-09-04, 09:56:
Well not that the LCD monitor is broken, but when you start exploring older PC software they can use video modes that are no longer supported on modern LCD monitors.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 3 of 18, by arcofreccia
leileilol wrote on 2026-09-06, 13:06:
The strange thing is that, with the same monitor but on the second PC mentioned in my signature, Motorhead works fine. On the PC with the Pentium 200 MMX, the lowest resolution available in the Windows settings is 640x480. But, as I said, Motorhead works on another PC using the same monitor
Reply 4 of 18, by arcofreccia
NeoG_ wrote on 2026-09-06, 13:21:
The strange thing is that when I use the same monitor but with the second PC listed in my signature, Motorhead works 🤔
Reply 5 of 18, by NeoG_
arcofreccia wrote on 2026-09-06, 16:08:
The native 512x384 mode is not produced by the voodoo5, by the time it came out they made the more sensible choice of scan doubling that mode to 1024x768 like most graphics cards do. So it makes sense that it would only happen in a system with an original Voodoo Graphics card.
Reply 6 of 18, by arcofreccia
NeoG_ wrote on 2026-09-06, 23:39:
To be honest, I didn't quite understand—what does "original Voodoo card" mean? Is the Diamond Monster 3D less "original" than a Voodoo 5?
Reply 7 of 18, by NeoG_
arcofreccia wrote on 2026-09-07, 06:30:
The first generation of Voodoo cards from 1996, aka "Voodoo Graphics"
Reply 8 of 18, by arcofreccia
NeoG_ wrote on 2026-09-07, 06:43:
Right, OK. So there’s absolutely no way to get Motorhead to work on the Voodoo 1? The only option is to try another monitor, isn’t it?
Reply 9 of 18, by NeoG_
arcofreccia wrote on 2026-09-07, 06:46:
I'm not familiar with the game, but many games of the time stored the selected display resolution in a settings file in the game directory, maybe the game can be moved out of the incompatible display mode to 640x480 which should work with LCD monitors.
It does depend on the game, Gex: Enter The Gecko for example only runs at 512x384. But GLQuake can run at both resolutions.
Reply 10 of 18, by arcofreccia
NeoG_ wrote on 2026-09-07, 06:56:
So, if I connect my PC to a CRT monitor, it’s likely that Motorhead will work
Reply 11 of 18, by Flashback
Try opening Game\MotorHead.CFG in Notepad and manually editing the renderer to voodoo if you haven't already.
I'm not sure if that will help, but it's worth a shot.
Reply 12 of 18, by arcofreccia
Flashback wrote on 2026-09-07, 17:11:
I opened the file you sent me, but I'm not sure how to edit it 🤔
Reply 13 of 18, by Flashback
My MotorHead.CFG file contains this line:
Renderer	display			// cliff/voodoo/display Render device
Try changing that line to this, then save the file:
Renderer	voodoo			// cliff/voodoo/display Render device
My game is patched to v3.1, so I suppose there's a chance our files may differ if you are using an older version.
Reply 14 of 18, by arcofreccia
Flashback wrote on 2026-09-07, 18:15:
My MotorHead.CFG file contains this line: […]
My file contains this text. Do I need to edit the first line where it says "Renderer"?
Reply 15 of 18, by Flashback
Yep. This is just a manual way to test other renderers since you can't access the frontend.
Editing ScreenDimension values from 320 200 to 640 480 or 512 384 may also be worth trying.
Reply 16 of 18, by RetroPCCupboard
Same issue for me on my Pentium MMX/Voodoo 1. My Dell 20" 1600x1200 monitor says the signal is out of range. My 15" LCD works fine though, but it says it is in 85hz Overdrive mode. So I am guessing that's overclocking the monitor somehow. But it runs great at 640x480. Super-smooth.
Reply 17 of 18, by filipetolhuizen
Have you tried running Motorhead without the Voodoo Graphics installed or using different drivers for your primary card?
Reply 18 of 18, by leileilol
I'd probably set the monitor's refresh rate to Adapter Default to see if it'll stick to 60/70hz for the relevant modes...
Debian's fucked
