ARx2611x3Dxl=ARx2611x3Dx2 updated, it has 3Dfx and 3Dgl (two similar drivers).
WinG 1.0 API added, Desktop shortcuts added and 555 / 565 Color Depth is added.
555 / 565 settings change needs restart and those make also automatic pc restart.
Driver installs atidbg.ini automatically and MultiTexture is enabled by default now.
Default OGL and Bilinear Off is also at desktop for quick OpenGL settings changes!
Bilinear Off is still fastest, but MultiTexture enabled is faster than default Bilinear.
2 colors (monochrome) now possible to use, but only at 640x480, just like 16 color.
16 color needs restart and also 2 color mode,ATi drivers support 8, 16, 24, 32 by drv.
Actually it supports 8, 15bit 555 and 16bit 565 high colors, plus 24 and 32 true color.
XLDVD.bat / Rage23.bat could also to be added to the desktop @ shortcut if needed.
XLDVD.bat is for ATi DVDv1 or ATi DVDv2 if you own RageXL and want DVD playback.
If you do not use DVD, then it probably not needed at all and default atid32ad.dll ok.
Core files are all the same in the driver,you get working 6 x shortcuts and WinG api
List of WinG games : https://www.pcgamingwiki.com/wiki/List_of_WinG_games
OpenGL is the same v1091, but i can recommend also v1073 and from newer v1100
Updated ATiDVD,no need to install ATiDVD Player/ATiMMC Control Panel separaetly
No need to install ATi DVD CP later
Added ATi DVD Player Control Panel!
Its at Start-Settings-Control Panel
Install ATi DVD @ setup.bat to get
ATi MMC Control Panel also for DVD
ATiDVDv1.7z
ATi DVD Player 3.10
Engine v1.0.28.5034
ATiDVDv2.7z
ATi DVD Player 3.10
Engine v1.0.32.5653
Full packages here
https://hingetee.ee/library/ARx2611x3Dxl.7z
https://hingetee.ee/library/AVPDVDATiCombo.7z
https://hingetee.ee/library/ATiRage3MMC+DVD.7z
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
