Reply 20 of 25, by leileilol
- l33t++
Motorhead will use the software renderer at best.
Debian's fucked
Debian's fucked
The game always launches in 3dfx mode. How can I make it launch in software mode?
Pentium200MMX/Ram64Mb/Hdd 6,4 Gb/Floppy 3.5"/ESS1868F/Matrox MillenniumII+Diamond Monster3D(3Dfx Voodoo)4 Mb/Win98SE
Pentium III-S1,4 Ghz/Ram512 MbPC133/Hdd Maxtor80Gb/IomegaZip100Mb/Floppy 3,5"/SoundBlasterPlatinum/3DfxVoodoo5/Win98SE
You go to the video menu and change the renderer.
It's not in 3dfx mode in the menu by the way.
Debian's fucked
arcofreccia wrote on 2026-09-19, 06:25:filipetolhuizen wrote on 2026-09-13, 04:55:Have you tried running Motorhead without the Voodoo Graphics installed or using different drivers for your primary card?
I had thought about it, but I haven't tried it. My main 2D graphics card is the Millennium II. How do I get Motorhead to run on the Millennium? I don't remember
The menus will always run on the primary card, but there is a chance that there might be something with the Voodoo Graphics detection/initialization. If your monitor still goes off-sync without the Voodoo Graphics, then it's surely something related to the Millenium II card. There might be a BIOS or driver update that fixes this issue. I'd also look for different Voodoo Graphics drivers as well.
filipetolhuizen wrote on Today, 02:46:arcofreccia wrote on 2026-09-19, 06:25:filipetolhuizen wrote on 2026-09-13, 04:55:Have you tried running Motorhead without the Voodoo Graphics installed or using different drivers for your primary card?
Sorry, but I’m not quite sure I’ve understood – when I launch Motorhead, does it start in 3Dfx mode or via the Millennium? Do I need to configure anything before launching the game to make it run on the Millennium?
Game menu is 2D, ran on your primary video card (the Millenium in your case).
The game only switches to the 3D accelerator once the race is starting (either it being a 3Dfx dedicated card like your voodoo 1 or any 2D/3D video card).
In regards to your problem, to rule out the Voodoo card, i'd plug the screen directly to the Millenium see if you see the menu. If it still gets Out of Range error, the Millenium is the problem (video card or drivers, that's to be further tested).
