AIMB-742 - recap needed?
First post, by Mike_
I noticed that for some reason there are a ton of these socket 478 boards on eBay, and prices have gone down quite a bit. They seem to be very useful for a retro build, as in addition to what should be fully functional ISA slots, they have SATA ports, dual channel DDR memory and can fit relatively powerful processors. So I ended up splurging a bit as I got one for $105 including shipping (plus, unfortunately, VAT 🙁 )
Most of the VRM caps seem to be polymers, possibly Chemi-Con PS series, so I suppose they should be fine? However, there are also a few Chemi-con KZG series 6.3V 1200µF caps, should they be replaced? I have heard that they were a problematic series. Based on quick testing with Prime95, the board seems to be fine.
There's also a ton of 100µF 16V general purpose caps, but they are probably fine and at least they shouldn't break anything even if they go bad.
The attachment aimb742_caps1.jpg is no longer available
The attachment aimb742_caps2.jpg is no longer available
Reply 1 of 5, by PcBytes
I think they're fine after 2007. I know KZGs stopped popping after a certain year (though it's possible the bad batches were still circulated until later than 2008, no info on this).
You can replace them if you feel so but I don't think they need it, given the board appears to be made fairly late (the ICS clockgen(?) having a 0833 datecode).
Reply 2 of 5, by rorirub
That board is around 18 years old and the capacitors may well be older. I'd replace ~20 year old caps on general principle due to their age.
Of course it may still run, I've seen Socket 478 Pentium 4 boards that worked fine despite several caps bulging and venting. But I wouldn't risk it myself.
Reply 3 of 5, by Shponglefan
I recently repaired a pair of AIMB-742 motherboards. One board had perfectly fine caps, while the other had a number that were buldged and leaking. I opted to replace caps on both boards with polymers and they seemed fine after the recap.
You can read about my repairs here if you're interested: Advantech AIMB 742 industrial P4 motherboards repair (update: both boards repaired and working!)
In the case of your board, I'd probably leave the caps as is. If it's not showing an sign of failure, they are likely still within spec.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 5, by Mike_
I guess I'll leave them there for now. It also looks like many of them are used as general purpose filtering caps or in parallel to polymers, such as two KZGs on right in the first picture, so they probably won't break anything if they decide to poop out their innards.
Apparently terminating voltage for RAM is done with a linear regulator.
https://in.rxelectronics.com/datasheet/ba/RT9173AGL5.pdf
PcBytes wrote on 2026-09-24, 22:23:
Good point, that board is much newer than you'd expect based on the socket. It also looks like its completely new, so it probably wasn't in use in a machine shop or something for the last 20 years. 😁 Maybe it was a spare part or something. And now that you mention it, there's something that looks like a date code (04 11) next to the serial number...
rorirub wrote on 2026-09-24, 22:37:
Normally quality caps shouldn't auto-fail even after 20 years, it's just that socket 478 and socket A era had the capacitor plague... but many of the caps on this board are polymers and apparently this was manufactured at a much later date.
Reply 5 of 5, by The Solutor
There are vacuum tubes radio that work after 80 years. Replacing capacitors "just because" is not only not required, but can add a risk of some trace that breaks, or whatever else during the soldering/desoldering process
If happens just replace the affected capacitors, as you would have done years before. Where's the problem?
