Reply 59800 of 59821, by Trashbytes
tehsiggi wrote on 2026-10-02, 11:44:
Trashbytes wrote on 2026-10-02, 11:38:
tehsiggi wrote on 2026-10-02, 04:39:
Bought a HD4850 PCIe and X1300 PCIe for science.
The part that stood out for me: I initially wanted to use a HD4770 for my testing, as it would be absolutely sufficient. However those go for around 25-35€ on ebay here in Germany, whereas the HD4850 can be had for 10€ . Well, not that I need that much horsepower, but hey, I'll take it.
The X1300 wasn't as easy as I though either. Ideally low profile + DVI + as cheap as possible. But many cards are dell OEM ones with DMS-59, making be shudder at the thought of having a dongle on it. So after some search I found one for around 5€.
The 4850 isn't much faster than the 4770 in real world use, it does run cooler and use less power though which may be of interest to you if you are looking for efficiency.
I basically needed "more than 4670" performance in the 4000 series.. and since I had a 5770 back in the day, I thought "Well, why not a 4770" 😁
My favourite is the HD4980 and the 4870X2 both are wonderful GPUs but the 4870X2 is a literal space heater and jet engine all in one.
The HD4890 comes in two flavours the 1Gb model and the 2Gb model ..the 2Gb model is pretty rare to find.
Reply 59801 of 59821, by gmaverick2k
Yamaha MU90 from Japan 😁 yet to recieve
Main:Z440/1650V4/3060Ti/64GB/iFiZenDACV1/KlipschProMedia2.1THX/Philips 43PUS8808/12
98:A7V333/AthlonXp2500+Barton/V3 3000/Vortex2/Solo-1/SC-55/LG StudioWorks 995e
DOS:GA-5AX/P166MMX/V3 2000/PicoGus/ESS 1868f/x2gs
XP:Edge72/3570K/GTX970/X-FiTi
Reply 59803 of 59821, by BitWrangler
Jccwu wrote on 2026-10-02, 13:58:
Rate my new enrgaved brackets
2√2/π
two root two over pi, which is a hair over 9/10, maybe I'm extra picky today 🤣
Reply 59805 of 59821, by MattRocks
Big Pink wrote on 2026-10-01, 18:58:
MattRocks wrote on 2026-10-01, 06:41:
That does not explain physical non-perishable items going astray: they can't put them in the bin in a sorting office and they can't store them on a shelf in a sorting office, so.. they accidentally put them in a lunchbox through lack of training or experience?
All of the above I can cite examples, except for the lunchbox.
Assuming it made it to your local delivery office the most likely explanation, barring theft or dumping, is it got delivered to someone else in error. If the item was Tracked and you got notification that it was heading out on delivery (because it got scanned to core route) then the last person that handled it will be known and they can have their brains picked - the sooner the better before those memories are overwritten by another several hundred packets.
According to tracking, they vanish in transit either between the post office and the sorting office or in the distribution centre.
Desktop timeline [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i7) ] * lost
Reply 59806 of 59821, by MattRocks
Sublime. Do you have a post on how these are made?
Reply 59807 of 59821, by BitWrangler
MattRocks wrote on 2026-10-02, 19:41:
Thing about PCBs is the sharp corners can have them knife their way out of packaging, especially under the kind of mechanical agitation they get in sorting centers 🙁
Reply 59808 of 59821, by Nexxen
10/10
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 59811 of 59821, by G-X
Looks cool. Intending to sell these or just for hobby?
What metal is it made of? Has a kind of brushed aluminium look to it ... or is it steel?
Reply 59812 of 59821, by Ydee
Seems stainless steel to me?
Reply 59813 of 59821, by Living
can we get an STL for 3d print?
Reply 59817 of 59821, by AaronS
Not really "retro retro" but I got this Asrock X79 Extreme 4 board, afaik its the only X79 board (other than Extreme 3 and Extreme 6, also from Asrock) that has multiple PCI slots. Have a 4820K CPU on the way which will allow it to run PCIe 3.0. Hoping it will make a good hybrid setup for multiple OSs.
The attachment SAM_3203.jpg is no longer available
Reply 59818 of 59821, by pan069
Jccwu wrote on Yesterday, 16:37:
G-X wrote on Yesterday, 12:54:
I’ve been selling them for several years now.
Do you have brackets for Sound Blaster 1.0 / 1.5 and/or Snark Barker by any chance? Is it OK for me to contact you directly?
Reply 59819 of 59821, by MattRocks
Buying a CNC machine would be extravagant for making just the occasional backplate.
One card in my collection that would definitely benefit from a new backplate and is an ELSA ERAZOR III with video I/O. Before seeing your post, what I was thinking about is finely snipped/drilled craft aluminium glued to a coarsely snipped/drilled donor backplate - my idea could never look original but it might be functional.
Do you have any thoughts or advice?
