HDD Synth - Mechanical hard drive sound synthesis
Reply 60 of 77, by jiefjifef
MaverickUK wrote on 2026-07-22, 10:47:
The HDD Synth MKV hardware has arrived!
That's so cool! The fake HDD sound market is booming right now: HDD Clicker is working on a new and improved version too. Retro life is good.
I hope latency won't be a problem on the "real thing"? Have you tried to measure it, and/or compare its latency to even realer mechanical things?
Reply 61 of 77, by jiefjifef
Also on the HDD Synth Win32 front, the latest release is available from https://github.com/MaverickUK/HDDSynth_Win32/ … ses/tag/v0.13.1
Some v0.13.1 feedback (tested on both win98se and winxpsp3):
- Settings dialog: Activity threshold slider now works (forgot to report this earlier but fixed nonetheless)
- I keep hearing random weird aggressively loud bursts of static, especially when experimenting with low latencies? Did something change that could have caused this?
- Audio buffering: the default value seems way too high, and why is the maximum value so huge? Surely nobody would ever be willing to wait 2 seconds before hearing their disk drive? (for giggles: if the hard drive was 700 meters away, admittedly there would be a ~2 second delay, also for reference, 50 meters away would mean ~145 ms of latency)
- I feel suspicious of the reported number of "glitches" per second, feels way too zealous and unhelpful to me, but I'm probably taking it too literally. When I seemed to find a suitable compromise between latency and disk sound quality, the dialog still reported dozens of glitches per second, even though my idle sounds were completely muted and nothing was happening at all, no sounds and no disk activity. Right now I find the glitchymeter too hard to interpret, and I don't want to have to live with e.g. 50-100+ ms of latency, no matter how "glitchy" it might be. Is there an unnecessarily tight loop playing in the background or something, and surely it at least does less work when the options dialog is closed?
- Please double-check that muting idle or activity sounds also actually disables the corresponding functionality completely, instead of still doing busywork and "playing" the sounds, just at zero volume
- Offer an option to reduce sound quality, for users who want low latency at all cost? Could there be "lite" versions of the sound files, does compression of caching help, any other tricks you can think of? I think low latency is super duper important (YOU may not have noticed it being slow, but your brain did)
- I would be feel more comfortable if the program just added a "dumb" normal shortcut in the Start / Programs / StartUp folder instead of whatever opaque thing "Run at Windows Startup" now does, especially since there is no uninstaller
- Suggestion: open the settings dialog if the user tries to launch the application again when it's already in the tray, the user is probably confused, and opening a competing instance is certainly the wrong thing to do here (use case: somebody can't or doesn't want to use the context menu, difficulty using the right mouse button or whatever but wants to access the settings dialog)
- Maybe even open the settings dialog automatically the first time the user opens the application (no settings file yet)?
- Also (or only?) put the hard drive model selection thing in the settings dialog, instead of (only) "hiding" it in the context menu? (if somebody can't or doesn't want to use the context menu)
- Also (or only?) put "Run at Windows Startup" in the settings dialog, instead of (only) "hiding" it in the context menu? (if somebody can't or doesn't want to use the context menu)
- Maybe also add an "Exit" button in the options menu, or would that clutter the dialog too much? (if somebody can't or doesn't want to use the context menu)
- More generally, why are some settings "hidden" in the right click menu and some are in the settings dialog? The choice seems pretty arbitrary? Just put everything in the same place? Also, icons are neat and all but they can be distracting: didn't Apple just start reducing the number of unnecessary icons in macOS menus in macOS 27 betas?
- The settings dialog is probably too wide, some people use win9x on a 640x480 resolution and it doesn't fit
Reply 62 of 77, by jiefjifef
jiefjifef wrote on 2026-07-22, 17:26:
Argh, I meant that the author of HDD Clicker is working on a new version, or that HDD Clicker is being worked on or whatever. Friendly competition is probably very good for "consumers", I'm guessing HDD Synth might be a little bit pricier but maybe the sound quality will be slightly more accurate, can't wait for a comparison.
Reply 63 of 77, by crusher
What a pity this won't work for DOS.
Been following this thread from the beginning on. Now that I realised I can't use it for my DOS build I'm out.
I think I will go with the improved HDD clicker version once it comes out.
Anyway this thing is amazing and professional done.
Every retro product is a welcome for the community.
I wish that everyone who has a use case will be happy with it.
Thanks MaverickUK for all your hard work on this. Keep it up!
Reply 64 of 77, by jiefjifef
No, I'm pretty sure HDD Synth (the hardware) will still work just fine on DOS: it won't care which OS you're running and just does its thing without needing any help from the OS.
In fact, installing HDDSynth_Win32 (the Windows-only software) would be completely pointless if you already had the hardware.
MaverickUK: maybe the HDDSynth_Win32 (software) stuff should have its own separate thread to avoid any further confusion? I really do hope you'll keep developing both, even though the software will probably cannibalize some hardware sales. Also, I hope you didn't find it disrespectful that I mentioned the "competing" HDD Clicker project (again) in this thread, I was just so excited that both projects are being worked on.
Reply 65 of 77, by NeoG_
crusher wrote on 2026-07-23, 06:06:
There is two separate discussions happening in the thread - One is the hardware project and one is the software project. The software project would have issues with DOS, but the hardware project as mentioned is operating system agnostic since it relies on hardware level signalling
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 66 of 77, by MaverickUK
I've spun off the software based HDD Synth Win32 into it's own thread
This thread will only be used for the hardware based HDD Synth going forwards, which as mentioned is designed to work with all computers
http://www.strifestreams.com
Reply 67 of 77, by crusher
Thanks to all for the clarification!
I'm happy to hear that the HDD Synth ISA card as a hardware project will work in DOS computers as well 😀
Reply 68 of 77, by MaverickUK
HDD Synth beta test signup
I've just ordered another run for a new revision of the MK5 prototype. Once I have this I'd like to test it with some willing volunteers before the product is sold via a Kickstarter later this year.
If you are interested, please go to https://forms.gle/ZnynzMdne47vVxBB9 and complete your details
What do you get?
An HDD Synth MK5 prototype to test out and keep. You can consider it limited edition, as the final version won't have the "Prototype" branding on it
What do I need to do?
Test the device out in as many computers as possible. I want to test it in modern computers, retro PCs, Amigas, Ataris and anything else.|
What will it work in?
Anything that has a 5v power rail and an HDD activity LED header
Reply 69 of 77, by MaverickUK
Thanks to everyone who has completed the beta testing survey form, I shall be in touch during August or September
Part of the beta test will involve providing people with 3.5"/2.5" drive bay mounts, to ensure they work as intended
Watch demonstration of HDD Synth drive bay mounts
The 3.5" version has a space to fit an optional larger speaker, if you really want to have a loud HDD!
I'm also going to create a prototype ISA & PCI adapter card slot which will supply power to the card and provide physical controls out the back. Mainly because I really like having some physical controls! 😀
Reply 70 of 77, by MaverickUK
I've just received the MKV revision that I'll be sending out to beta testers, something I'm aiming to do in September 2026
Also prototyped is a case that enables the HDD Synth to be used externally in a more attractive way or allows the device to be safely put into a computer, which worry about short circuts
Finally a early version of the ISA adapter. The HDD Synth connects to this using it's male header which then slot into the female headers on this board. It provides controls via the back panel and extends the LED headers for easy access. Creating PCI, Zorro and other adapters is just a case of changing out the slot in the design.
Reply 71 of 77, by jiefjifef
Looking good! Can't wait to get my hands on one!
Reply 73 of 77, by MaverickUK
GloriousCow wrote on 2026-09-02, 16:16:
What are the license conditions for the audio samples?
It's on my to do list to sort this one, when I upload a library of these
The initial majority I've been working with were created by https://www.gladestock.co.uk/
More recently I've been working with samples I've taken from recordings on https://www.youtube.com/channel/UCPKbhl3GPYnZ2dQ9gn_NLCQ which MMaximus gave his blessing to use
In both cases, no licence has been established as yet
Reply 74 of 77, by MaverickUK
Ahead of sending the HDD Synth to beta testers I was checking it in my Amiga 1200. Unfortunately it didn't survive this experience, so I'm doing some additional investigation to determine the reason. I'm using a modern PSU with stable lines with my 1200, so more likely to be due to power complications caused by the 1200 itself being in the equation.
This will result in another revision of the board to add an eFuse whilst also improving the super cap charging/discharge circuit to use an IC rather than the current basic design. I'm also wanting to improve the regulators that will improve the spin down time, for anyone wanting a really long spin down 😁
Reply 75 of 77, by MaverickUK
The beta testing board is ready !
I will be emailing the selected beta testers today to offer them an oppotunity to beta test the device, before it goes into production which would ideally let it be available for Christmas 2026.
YouTube video of the beta test version
I've also updated the project website with accurate information and new photos
Reply 76 of 77, by Angus.Young
Nice work.. looks like a neat product.. will keep my eye on it as its released..
Reply 77 of 77, by MaverickUK
Just a quick (slightly out of focus!) video demoing the optional OLED screen
I wanted to get this feature in before sending out to the beta testers this week
YouTube video of the optional OLED screen
