My involuntary retro activity today was crawling around on the floor looking for a tiny bit of plastic, I inverted a laptop floppy drive that belongs to my actionnote and the eject button fell off and went seemingly into another dimension. After thoroughly scouring a section of floor, I discovered numerous small screws that I didn't know I had lost, or forgot about... but gave up when I was sure I should have seen it if it was there.
10 minutes of racking my brains as to where the hell it could have gone, and I see I have a baggie of random internal case wiring sitting open near where I dropped it... check in there, yup, found it, damn thing caught a bounce with enough height and reach to drop in that. Really glad I found it though, would have been hard to make a strong replacement for it.
What I started out doing ,which I thought would divert me a mere 5 mins, was looking at whether I could make a special combo drive that fit in a 5.25 half height bay. All the things in one bay! So then, using a thin media bay thing that was part of a case at one time (never had the case arrived with parts) and a laptop optical drive, which have adapters on the cheapie etailers, and a laptop floppy drive, it looks like the stack comes in at half 5.25 height. The media bay thing has a metal cage under it, that seems to be extra bulk for fastening it in the top of a 3.5 cage where it sat on the bottom of the 5.25 cage, weird arrangement. But that means it's hollow and either the floppy might mount nice into it with a hole cut, or it might get removed almost completely and the media bay can be wherever in the stack. Media bay has SD/MMC, Compact Flash and USB. The ribbon connectors that laptop floppy drives have turn out to be a standard. Not sure at the moment though whether I will be making an adapter for the ribbon or whether I will be using a low profile external USB drive in there. Depends on what age of machine I decide to put it in.
I do actually have a faceplate surround for the media bay too, but it will need scrubbing off and carving up a bit, then repainted.
