Voodoo Rush 4440 + Rush information
Reply 20 of 27, by Pr1ha
sdz wrote on 2026-08-21, 08:24:
Next, I tweaked some internal driver parameters (SST96_FT_CLK_DEL SST96_TF0_CLK_DEL SST96_TF1_CLK_DEL SST96_TT_CLK_DEL, can now be set externally with the new driver, same as then could always be set for a Voodoo/Voodoo2 card but never on the Rush for some reason).
What you're doing is amazing!
Is it possible to modify the gamma parameter in the driver so that it can be set externally?
Reply 21 of 27, by sdz
Yes, it should be possible to implement that.
Reply 22 of 27, by sdz
Gamma can now be set externally, eg:
set SST96_GAMMA=1.7
or per channel, eg:
set SST96_RGAMMA=1.7
set SST96_GGAMMA=1.7
set SST96_BGAMMA=1.7
The attachment S1.jpg is no longer available
The attachment S2.jpg is no longer available
This is only supported on the Alliance ProMotion AT25/AT3D. Macronix 2D IC is not supported.
Reply 23 of 27, by Thandor
Very nice work!
Your card looks very clean with very little glue between chips. What is that makes your cards needing less SMD components?
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 24 of 27, by sdz
@Thandor thanks!
There aren't relly less SMD components, they are all on the bottom side of the PCB, and are way smaller than what was used back in the day on the Voodoo Rush.
Reply 25 of 27, by vmunix
Hi guys sorry to go a bit off topic here but I really need a hand to save this card, as I posted in this thread I'm building this basically just to test the Rush Re: Voodoo Rush (Jazz Adrenaline) , long story short after days and days troubleshooting (maddening because the 2D part works just fine), found a missing resistor after inspecting it under a microscope.
It's R82 apparently connects the reset line between the TMU (pin 208) and the FJR (pin 73). but no idea the value, I was leaning towards a 10K perhaps but the AI says it's actually 47 ohm , kind of low, anyone has a voodoo rush or voodoo 1 at hand? what's connected to pin 208 in the TMU ?
Trailing edge computing.
Reply 26 of 27, by sdz
FJR pin 156 (not 73) is connected to the TMU pin 208 (reset). A zero ohm resistor can be used, or a low value resistor (10, 22, 47).
Reply 27 of 27, by vmunix
sdz wrote on Today, 06:29:
well thank you for the response I will try that, however I noticed as you can see in the picture pin 156 in the FJR is connected to a unpopulated R81 which would connect to 208, instead the missing resistor below connects 73 in the FJR (HRESET) looking at your schematics.
