Reply 180 of 196, by Lualb
mwdmeyer wrote on 2026-10-23, 22:16:Lualb wrote on 2026-10-23, 21:02:Hi, how are you? I wanted to let you know that I’ve been testing the driver using the alias for the Intel HD4400. I’d like to send you some screenshots from the testing process, along with a .txt output file that should better explain how we might resolve this incompatibility. I’ve attached the images and the text output file.
Seems you are running an older version. Can you try with the latest version? If you have internet on that machine you can use auto update feature.
Yes, it works! Now, time to play some classics—oh yeah!
