First post, by Hi-FiMan
Upon testing a 6600 GT AGP, 6800 GT AGP, 7800 GS, 7950 GT, and even a Quadro FX 3450 under Windows 2000/XP I noticed things always looked off in 16-bit color games. I first noticed something was wrong in Descent 3 with the "fog" and then I noticed it in almost every other game that renders in 16-bit color; BANDING. This banding was not present on everything like a card that does no dithering at all (GeForce 8+); it seemed to be present only on some textures such as transparencies and maybe some others. The other game I noticed it a lot on was Shogo. You could see banding on the mech arms and some of the skybox textures.
Now common internet mythos says these cards do support dithering in 16-bit color mode but it seems to me that it's somehow incomplete or broken. I've tried multiple drivers from 61.77, 93.71, and even 175.19 and they all have the same behavior. I've also played around with many settings in the driver control panel and rivatuner to no avail. If I install an older card such as a GeForce 5900 Ultra or 4200 Ti, the dithering is all there like one would expect. Interestingly, ATI cards from the time don't seem to have this problem. Radeon X800, FireGL X3, and Radeon X1900 XT cards all render 16-bit color with dither on everything. I did notice 2 or 3 threads on here mentioning broken dither on GeForce 6/7 but the overwhelming consensus seems to disagree. Am I missing something here or should we stay away from these cards for games locked to 16-bit color?
As an aside, driver version 61.77 seems to be the last version that reports supporting 32-bit Z-buffer (without stencil buffer). The only game I know of this matters for is Slave Zero as that game will not render in 32-bit color unless the card supports 32-bit Z-buffers (without stencil buffer). I assume the hardware doesn't actually support 32-bit Z-buffers and just renders with a 24-bit Z-buffer. Only older ATI cards with older drivers seem to support 32-bit Z-buffers but I cannot recall which exact driver; I remember seeing it as an option on Radeon 7200, 7500, 9000, and 9200 cards.
Reply 1 of 15, by Joseph_Joestar
Hi-FiMan wrote on 2026-10-21, 01:06:
Interesting observations. It never occurred to me that there may be some variations in different games, or even certain parts of the same game. While I haven't tested 16-bit dithering extensively, I did sometimes check it while testing the table fog support of various GPUs. For example, here's how Thief 2 looks on a Voodoo 3 card:
file.php?id=242492
And here's the same screenshot on a much newer GTX 650 Ti:
file.php?id=141042
The color banding is very evident on the latter card. If anyone wants to run additional tests with Thief 2, the save file and testing instructions are available in this post. Also, here's how that game looked on my GeForce 6200 card back when I was running the fog tests.
My retro stuff
Reply 2 of 15, by leileilol
Textures never get dithered, but it's possible that paletted textures got regressed here.
Debian's fucked
Reply 3 of 15, by Trashbytes
leileilol wrote on 2026-10-21, 23:15:
IIRC this is exactly what occurred with the switch from the FX series to the 6000 series, pretty sure fog table also got nuked around this time with the newer GPUs, may have been earlier.
Games that use the Lithtec Engine are a good way to test both if I remember right. Same with games using the Dark Engine like Thief and System Shock 2.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 4 of 15, by Hi-FiMan
Yes, textures themselves don't get dithered. It's probably more accurate to say certain blend modes are not getting dithered along with certain types of fog. None of these cards support paletted textures though and I don't think Shogo uses them unless you specify 8-bit textures in the settings which I did not. Also, the Radeon X1900 XT running driver 7.11 renders everything properly with dither and that card also does not support paletted textures. Interestingly, the Radeon also allows me to use MSAA without mucking up the font as long as the alternate pixel center option is enabled.
Reply 5 of 15, by myne
Here's a silly question...
IF the hardware feature was missing, would that make the 6/7 series forever "dead", but with the 8+ having programmable shaders, theoretically they could reimplement the feature accurately?
I built:
Reply 6 of 15, by Hi-FiMan
Trashbytes wrote on 2026-10-22, 00:46:
Table fog works on GeForce 6/7; however, it just might lack dither but I need to double check that. Shogo uses table fog heavily and it shows up on GeForce 6/7. I should also add that the Matrox Parhelia does not support table fog at all.
When I get some time, I will upload some pictures to demonstrate what these cards are doing and not doing.
Reply 7 of 15, by Trashbytes
Hi-FiMan wrote on 2026-10-22, 04:21:
Honestly its been a while since I last looked into it all but Geforce 6 and 7 changed quite a bit under the hood from the earlier cards so its certainly worth running a few tests with the cards to determine exactly what was lost/changed.
Shogo and Thief would both work well for this as each engine will quickly let you test for changes.
Reply 8 of 15, by myne
Table Fog & 8-bit Paletted Textures
I built:
Reply 9 of 15, by The Serpent Rider
Could be some driver regression that affects only specific games like Descent 3.
Easier to force 32-bit color on everything with DgVodoo2 and such.
Reply 10 of 15, by Hi-FiMan
As promised here are the pictures. dgVoodoo2 only works on Windows 7+ and I don't know of anything that can force 32-bit color on Windows XP. I've noticed this banding on every game I've played that renders in 16-bit color.
Interestingly, the FireGL is missing the alternate pixel center option in it's drivers but it seems to do this automatically when MSAA is forced as the Shogo text looks fine with MSAA forced in the driver unlike the GeForce FX/6/7 cards. Also, this driver is dated September 2007 and it has working table fog emulation. Common wisdom suggests driver 7.11 (released November 2007) was the first to offer table fog emulation but this seems to be false.
16-bit color:
FireGL driver version:
FireGL X3 dither:
GeForce 6800 GT banding:
Table fog option:
Table fog disabled:
Table fog enabled:
Reply 11 of 15, by Paar
Fascinating, I always thought that Geforce 6 and 7 series supported 16bit dithering. This quite limits their use as I find the banding intolerable. Radeon X1800 and X1900 series take the crown for backward compatibility I guess.
Reply 12 of 15, by Joseph_Joestar
Hi-FiMan wrote on 2026-10-27, 02:21:
On the TTLG forums, people with Radeon cards first reported working table fog in Thief 2 with the Catalyst 7.11 driver. This is where the info originated. Can you test that game with your older driver using the save that I linked to earlier?
As for Shogo, I remember the fog behavior being inconsistent there. While the game itself claims to use table fog, it can work on some ATi cards, depending on the GPU (e.g. R200 vs. R300) and/or driver version. It's possible that Shogo implemented some sort of fallback for that. Anyhow, from my experience, Thief 2 and Star Wars: Shadows of the Empire are the two definitive table fog tests. If it works in those two games, it will work everywhere else too.
My retro stuff
Reply 13 of 15, by Dothan Burger
It's weird that the hands don't have that dithering issue on the first level with Curry GPU's. On the Second level aboard the ship, I definitely see what you're saying.
I tried applying the official patch 2.2 but then the game became unplayable i.e. I couldn't complete the mission because my character walked too slowly to catch the ship, and no previous saves would load.
Reply 14 of 15, by Hi-FiMan
Joseph_Joestar wrote on 2026-10-27, 20:22:
I tested the Shogo fog on quite a few cards actually. Here's what I found out on Windows XP and 2000:
Matrox Parhelia with various drivers: No fog
Matrox G450 with latest drivers I think: Fog
Radeon 7200 SDR & DDR with driver 6.2: No fog
Radeon 9000/9200 with driver 6.2: No fog
Radeon X1900 XT with driver 7.11: Fog
FireGL X3 with driver from September 2007: Fog
GeForce 2/3/4/FX/6/7 with drivers 12.xx-93.xx: Fog
I can test Thief 2 when I get a chance. I'm in the middle of recapping an Asus A8N32-SLI (damn KZGs) and my solder vacuum nozzle broke...
Reply 15 of 15, by Hi-FiMan
Dothan Burger wrote on 2026-10-27, 23:02:
To be fair, the second level is out of the mech so maybe different effects at play there. I should note that I am using the GOG version.
