Reply 20 of 39, by EF PC Vintage Planet
ubertrout wrote on 2026-10-25, 18:43:
EF PC Vintage Planet wrote on 2026-10-25, 09:36:
Thank you so much for the feedback and for looking into this! […]
ubertrout wrote on 2026-10-25, 03:20:
To be honest I'm not sure if the i5-3470 machine has much of a chance. However, the 5800x3d should be much better. I'm realizing how heavy 86box is on the CPU though - it really stresses a single core of the CPU.
Just a quick update from my end: I performed one final clean test using the new pcx-v0.2.1 standard release. I swapped the Matrox Mystique for an S3 Trio64V2/DX (4MB) on the Pentium 166 MMX setup under pure MS-DOS mode. Unfortunately, the behavior remained identical: flawless visual output, a solid 30 FPS counter, 100% host speed, but the game logic is still running in full slow-motion. Seeing that other users are reporting the exact same 0.5x speed dilation makes me think this is indeed a thread-scheduling or timing sync quirk with certain Windows host environments.
I will gladly leave my setups as a reference for future updates and I would love to be kept posted on any further developments or new builds!
On a side note, I manage an Italian retro-hardware Facebook group with over 9,000 members and a dedicated YouTube channel with 1,900 subscribers. Since our community is deeply passionate about early 3D accelerators, I would love to share your amazing work and this forum thread with them, as it could attract more passionate beta-testers. However, I wanted to ask for your permission first before sharing any links out there.
Thank you again to you and the author for this incredible project!
Please do! It's a public project. Obviously the main issue right now is performance but if you spot any rendering problems with a game please let me know. It's most important to me that this be accurate.
Speaking of performance, here's version 0.3. It's still demanding but it should run substantially better than previous versions: https://github.com/z2k-retro/86Box/releases/tag/pcx-v0.3
Wow, version 0.3 is absolutely incredible! You nailed the core issue perfectly.
I just tested the new pcx-v0.3 build on my Ryzen 7 5800X3D setup with both Tomb Raider 1 (DOS PowerSGL) and GLQuake (PowerVR patch). Everything is running beautifully now! The slow-motion effect is completely gone, the games are moving at their normal speed, and the audio stuttering has been entirely fixed. The bit-identical visual rendering looks absolutely amazing.
I want to say a huge thank you to the developer, z2k-retro, for being so incredibly receptive to the feedback and for putting out this game-changing update so fast. I also want to thank user Mattix23 for sharing his results, as confirming that others were experiencing the exact same 0.5x slowdown was crucial to identifying the bug.
As promised, now that the build is working flawlessly, I am going to write a dedicated post on my 9,000+ member Italian retro-hardware Facebook group to share this milestone. Furthermore, as soon as I finish benchmarking more titles on this new build, I will record a dedicated video on my YouTube channel to showcase this amazing PowerVR emulation project to my subscribers and give it the visibility it truly deserves.
Thank you again for your hard work and for keeping this project open to the community!
Reply 21 of 39, by EF PC Vintage Planet
Reply 22 of 39, by ubertrout
EF PC Vintage Planet wrote on 2026-10-25, 20:39:
Wow, version 0.3 is absolutely incredible! You nailed the core issue perfectly. […]
Wonderful! Looking forward to more feedback and squashing any bugs which appear.
Reply 23 of 39, by Mattix23
Hello,
OMG what amazing developer are just working at this awesome project! In less than 24 hours, the bug is definitive gone.
I can only confirm what EF PC Vintage Planet has already written; Now Tomb Raider run flawless smooth.
With my poor old notebook i can play @640x480 with a Pentium 75 emulated and it runs at 30-35 fps. In this case, i don't know if is a bug or a locigal issue, at 1024x768 the video broken and it seems to have not synch with a half of the screen. This problem, when i emulate at least a Pentium 133, doesn't appear.
I wish to make some others tests in these days, for now i can only say a big THANK YOU
Reply 24 of 39, by EF PC Vintage Planet
Mattix23 wrote on 2026-10-26, 08:15:
Hello, OMG what amazing developer are just working at this awesome project! In less than 24 hours, the bug is definitive gone. […]
Hello,
I tested the following configuration on an i5-3470 with 16 GB of DDR3 RAM:
Pentium 90, 32 MB, Mystique 220 + M3D. The game runs quite smoothly, and the frequent crashes I encountered during gameplay on my Ryzen build are resolved—it might freeze, but it recovers on its own without needing to be force-closed via Ctrl+Alt+Del (which, on the Ryzen build, makes frequent saving a necessity). If I switch to a 166MMX—as I did on the Ryzen—it runs in slow motion; not as badly as before, but still in slow motion. I want to try lowering the CPU speed on the Ryzen build as well. Naturally, this is at 640x480 resolution. If you want to play *Unreal*, however, you’ll need at least a 166MMX. I might run some more tests on the Ryzen build tonight, but *Tomb Raider* runs well with a Pentium 90 or even a 120.
Reply 25 of 39, by xabarax
Hi everyone, you guys are awesome! I've compiled the source code for Debian and I'm sharing the link here.
https://archive.org/details/86-box-7.0-linux
I'm actually testing it right now. May the PowerSGL APIs be with us all!
Thank you! Have a fantastic day ahead, and happy testing with your PowerVR build. May your frame rates stay high and your buffers clear! Let me know if you need anything else.
Reply 26 of 39, by starlord
It’s astounding the progress that has been made in regards to 3d accelerators emulation. The fact that we recently have a host of PowerVR wrappers available, and that now some matrox hardware is also supported is awesome.
With this many hardware exclusive games can run.
Reply 27 of 39, by starlord
I know the impression plus was doing some wierd stuff hardware wise, which was what was making it difficult to understand compare to the mystique.
I’m hoping this will change someday, especially with today’s tools.
Reply 28 of 39, by ubertrout
xabarax wrote on 2026-10-26, 11:36:
Hi everyone, you guys are awesome! I've compiled the source code for Debian and I'm sharing the link here. […]
Great! This was originally tested mostly on Ubuntu so it should work great - let me know if you hit any issues.
Reply 29 of 39, by ubertrout
Hello,
Thanks, I'll test Tomb Raider at 1024x768. I think at that point the 4 MB card is coming awfully close to running out of memory, but it also might be an easy fix.
Reply 30 of 39, by ubertrout
Updated to version 0.3.1 - finally got around to testing Turok and it used mirrored v textures in a way which the emulator didn't expect yet. Now it does! https://github.com/z2k-retro/86Box/releases/tag/pcx-v0.3.1
Still looking for PowerVR titles which used the following:
8-bit textures in a real game;
bilinear modes other than the adaptive one PureVex uses;
scenes too large for one render pass;
the FASTFOG mode;
Anything using PREC_BASE.
Reply 31 of 39, by xabarax
ubertrout wrote on 2026-10-28, 03:25:
Updated to version 0.3.1 - finally got around to testing Turok and it used mirrored v textures in a way which the emulator didn' […]
the FASTFOG mode;
Hi! Thanks for the update and for all your work on the PowerVR emulation!
I've tested the current build on two systems, with the following results:
- **Intel Xeon E5-2696 v3 (18 cores):** approximately Pentium 90 performance.
- **AMD Ryzen 9 3900X (12 cores / 24 threads):** approximately Pentium 166 MMX performance.
I've also recorded a video showing Unreal running with this build:
**Video:** https://www.youtube.com/watch?v=ZW6ojIsDde4
The main issue I've encountered, apart from performance, is that enabling the dynamic recompiler causes the emulator to crash with an **"Over limit!"** error. As a workaround, I can disable the dynamic recompiler while the game loads and re-enable it once the game is running.
I found that this is a known issue in the original 86Box project. The **86Box v3.11 release notes mention a fix for the "Over limit!" crash in the dynamic recompiler on x64 builds**:
https://86box.net/2022/11/26/86box-v3-11.html
I'll also compile and test your latest **PCX v0.3.1** release to see whether the issue persists in the current PowerVR branch.
Thanks again for your work! I'll share my findings after testing the latest version.
Reply 33 of 39, by ubertrout
xabarax wrote on 2026-10-28, 15:00:
Hi! Thanks for the update and for all your work on the PowerVR emulation! […]
the FASTFOG mode;
I've found it's quite stable with the new dynamic recompiler, but less so with the old one. 0.31 just fixes rendering in Turok so it won't have any effect on build stability or performance.
Reply 34 of 39, by kingcake
Serious question. Why are there so many 86box clones? It's getting to be a little maddening to install all these dif versions. I guess same could be said about dosbox. Why aren't these additions being submitted to the upstream projects?
Reply 35 of 39, by ubertrout
kingcake wrote on 2026-10-28, 20:14:
This exists to test getting PowerVR working in 86box - my hope is that it will be integrated into the main build. I've been in touch with the devs and an issue was opened: https://github.com/86Box/86Box/pull/8514
For now it's useful to have separate as it's fine-tuned and improved and I solicit feedback.
Reply 36 of 39, by kingcake
ubertrout wrote on 2026-10-28, 20:29:
Ok cool. But I guess I meant in the larger community. I wasn't talking about you specifically.
Reply 37 of 39, by ubertrout
Version 0.3.2 released - this now correctly emulates all PowerVR PCX2 hardware features, even the ones pretty much no games use: https://github.com/z2k-retro/86Box/releases/tag/pcx-v0.3.2
All throughout the reference repository has also been updated: https://github.com/z2k-retro/powervr-pcx2-tools/. This is intended to be a resource for anyone who wants to create their tools without needing a physical card to build on this project.
What should I do next with this project? What are your experiences using it?
