Yamaha XG emulation at last
Reply 340 of 357, by zaphod77
the mu100 instruments do improve a number of ff7 XG midi files, actually.
Oddly enough, it seems that game was kept in mind with the quality upgrades. Still more FIghting's distorted guitars are much improved, for example.
Reply 341 of 357, by RetroGamer4Ever
When they did the XG MIDI for FF7, they did it using the MU hardware and not the brand-new software, so it should always sound better with XG hardware from that time period. Once this gets a little more baked and fleshed out, it would be great to see YT vid recordings of the FF7 XG MIDIs using the better samples that have been dropped in and then, move on to some of the massive pile of XG MIDIs that were made over the years, using the more advanced hardware options.
Reply 342 of 357, by zaphod77
test them out in s-mu2k.
Try mu-native first, then try mu-basic. you might be surprised. mu-basic map s for midis that soudn wrong withotu it. always has been, always will be. if it sounds great without it, you don't need it. 😀
here's still more fighting.
sw1000xg (it's a mu100 on a card) https://www.youtube.com/watch?v=OGLOqyya6Q4
real mu-2000ex https://www.youtube.com/watch?v=n8MGLBfrRAs
still, nothing beats the original hammond b3 slowdist organ sample from the PS1 original, though.
Reply 344 of 357, by Trelokk
In case anyone hasn't been aware of it:
The S-YXG50 panel looks like this now and the engine supports polyphony 256. Just sayin'. And MU50-1000 can be loaded with it. Some better, some worse, but they do work.
Oh yeah, and there's a patcher which just needs the ROMs and syxg50.dll and you get ready-to-use VST2 dlls as a result. Single files, ROMs embedded, fully portable. It won't get any easier than that. 😀
Reply 345 of 357, by gerwin
Trelokk wrote on 2026-10-15, 20:00:
I tried it yesterday, with all MU variants.
It is very user-friendly indeed. The Windows patcher requires Windows 10, Windows 7 won't do, But there is also a Linux one. Anyways these are pyinstaller executables. the core is python (v3.12+).
In my brief testing I noticed MU50 and 80 being closest sounding to my expectations, of certain midi tracks. But the others are not far off, when configured as MU basic.
Reply 346 of 357, by gmaverick2k
gmaverick2k wrote on 2026-10-08, 15:26:
Got s-mu2000 working using clear instructions from a website
https://moondoldo.com/wordpress/?p=14483
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: Shuttle SK41G/AthlonXP 2200+ 1.8GHz/V3 3000/YMF744/MU90/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
Reply 347 of 357, by zaphod77
So now that these converter projects are around anyone up for making a .TBL to .sf2 or .dls converter? For use with something like Spessasynth?
Reply 348 of 357, by hockinsk
I've worked on a python script that converts the 1x and 2x element MU2000 ROM voices to Bitwig Sampler presets. These are very similar to .sf2 underneath. They sound like recognisable XG voices, but they're obviously quite raw sounding. I got as far as mapping loop and tail, AEG, FEG and ome PEG. There's quite a few challenges though because several aspects of XG/AVM2 parameters don't really have .sf2 equivalents so even though the sample and envelopes are identical, some of the character is not shaped properly. I did think it might be better to do what i did with MUXG2K and bake some of the AVM2 goodness into the samples where possible so it would make the encoding to .sf2 a little more accurate.
Reply 349 of 357, by RetroGamer4Ever
Wasn't the real secret sauce of XG, the DSP-ish stuff (processing commands and such) that was part of the XG MIDI standard and baked into the XG MIDI data?
Reply 350 of 357, by hockinsk
For the time, what was unique was the PCM was source material for a complete subtractive synthesis engine that comes afterwards. Yamaha's digital filter at the time was also what allowed it to sound analogue-like filtering. This is why merely extracting the ROM waves is only a tiny part of AWM2 and why it's so difficult to replicate in software too.
Reply 351 of 357, by zaphod77
unfortunately sf2 without extensions is incapable of handling gs or xg adequately.
.sf2 provides for 2 lfos per part. that much works. ut it also only provides 2 envelope genreators, oen of which can only be applied to volume.
Roland GS synths use three envelope generators. one for volume (TVA) one for filter (TVF) and one for pitch. XG gangs the volume and filter envelopes together. Neither can be put into sf2, because all envelope generators have independent defaults per patch.
AWM2 predates xg, and was used by the TG300 before it was used for XG.
Reply 352 of 357, by hockinsk
That's not technically correct zaphod77 because AWM2 (hence XG/MU) voices do have independent per-element envelopes: iFEG (filter) and iPEG (pitch) which is the same count as GS, so there isn't a shared vol+filter EG as such. AEG is shared across all elements of a voice though, there isn't an iAEG to AWM2.
What you're probably meaning is real MU hardware / MAME / S-MU2000 keeps the iFEG and iPEG hidden and non-editable and running internally as kind of a baked-in-the-ROM and never exposes them at sample playback on the XG MIDI surface to the user. And it's the same for PEG. There's the user-editable global PEG (works like AEG across all element), but each element making that voice has it's own internal iPEG too.
This was a major reason for not going the MAME/SWP30 emulator route with MUXG2K and writing my own AWM2 engine in C++ native (took me 2 years developing it) was because I wanted user-editable control over more things within AWM2 than Yamaha exposed.
On the XG voices that contain them, you'll see that MUXG2K exposes them as editable envelope controls to the user as iPEG and iFEG on each element.
The reason for exposing them and making them editable in Realtime or saved to presets is because ultimately, MUXG2K will be made available to support MPE and MIDI 2.0 and these parameters then become part of the 5D control too. E.g you might have Slide controlling FEG cut-off, but Pressure iFEG 1 resonance and iFEG2 cut-off for example.
Exposed internal Yamaha PEG
Exposed internal Yamaha FEG (Element 1)
Exposed internal Yamaha FEG (Element 2)
Reply 353 of 357, by hockinsk
Here's how much of XG / AWM2 actually maps to SoundFont 2
XG / AWM2                   SF2 2.x equivalent        Fit
Multiple elements / voice Instrument zones Direct
Sample + loop sample + sampleModes Direct
Root key / coarse+fine overridingRootKey + tune Direct
Key-follow (pitch track) scaleTuning Partial
Pitch EG modEnv -> pitch Partial
SFX scripted pitch (siren) (none) None
Vibrato (pitch LFO) vibLFO -> pitch Direct
Amplitude EG volEnv (DAHDSR) Direct
Low-pass cutoff / resonance initialFilterFc / Q Partial
Filter EG modEnv -> filterFc Partial
3 indep. EGs (amp+flt+pit) volEnv + ONE modEnv None
Two LFOs vibLFO + modLFO Direct
LFO waveforms triangle only Partial
Tremolo + wah (amp/flt LFO) modLFO -> vol / filter Partial
Level / pan initialAttenuation / pan Direct
Velocity layer switch velRange per zone Partial
Drum key-map + per-drum zones + keyRange + gens Direct
Drum choke / alt-group exclusiveClass Direct
Reverb / chorus SEND level reverb/chorusEffectsSend Partial
Reverb/chorus/variation FX (send amount only) None
Insertion effects (none) None
Part / master EQ (none) None
SysEx / NRPN deep editing (limited modulators) None
The main wall is SF2 has only two envelopes: volEnv is volume-only, and the single modEnv must be shared between pitch and filter. AWM2 has independent amp + filter + pitch envelopes per element, so you can reproduce a filter EG or a pitch EG, never both at once.
This is why you're better off working with a subtractive synthesis sampler/engine that either takes .sf2 and extends it further or baking in the main wall and accept it's baked in and not going to sound quite the same for most voices. Even the pitch mapping from XG to .sf2 is not so easy either.
Reply 354 of 357, by zaphod77
Here's what i read of this.
11) full. resonance and cutoff exist.
13) the manuals i've read state that filter and amplitude use the SAME EG. but that still doesn't work, because pitch EG is separate from filter EG in XG. it's GS that has three independent envelope generators, and likely fake GS does the same.
15) alternate LFO waveforms are part of insertion effects, which are outside the scope of SF2. GS uses sine wave, or so i'm told. I'm not entirely sure that fake GS uses sine wave LFO. But normally changeable waveforms are part of effects, not of the main instrument.
22) variation is outside the scope of .sf2. there's no variation defaults that I'm aware of in an XG instrument, because variation is not active by default. The variation default parameters are separate from the instrument.
23) insertion effects are outside the scope of sf2. they use their own separate LFOs, which can have changeable waveforms.
So we agree in envelope generators being the main issue. so an extension of the soundfont format is required to allow for three independent EGs per voice.
Reply 355 of 357, by RetroGamer4Ever
Given that SoundFont is essentially an open - and now more or less uncontrolled and abandoned - bit of tech, perhaps the time has come to push forward and revamp it, with a 3.0 version, as some in the MIDI digital workspace have called for. Coupled with the MIDI 2.0 advances, it's certainly time to give some thought to it.
Reply 356 of 357, by Falcosoft
RetroGamer4Ever wrote on 2026-10-31, 12:01:
It has already happened:
https://github.com/SFe-Team-was-taken/SFe
But the problems is that an existing specification does not mean widespread support.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 357 of 357, by fastcall37
The S-YXG2011EE (mentioned earlier) and the S-YXG2006LE both seem to be wrappers over an engine.
I don't know if I should elaborate here or create another topic since they were last mentioned about a month ago 😀
Amazing projects, by the way!
