Table Fog & 8-bit Paletted Textures
Reply 660 of 673, by pentiumspeed
Anyone have i740 test for the table fog and palletized stuff?
Cheers,
Great Northern aka Canada.
Reply 661 of 673, by marxveix
pentiumspeed wrote on 2026-06-08, 23:12:
Cheers,
Re: Hot take: Intel 740 is a decent retro card
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 662 of 673, by marxveix
ATi Rage3 with NFS3 and FOG, its not true, as i used dgVoodoo and -Voodoo2 command, it shows it can, similar case with OpenGL paletted, also it can over GLDirect. Performance bit lower than original, 512x384 and 640x480 playable, 800x600 and 1024x768 probably not so,but it runs higher resolutions also. NFS2SE fog also works, Need for Speed:High Stakes next. Celeron MMX and ATi RageXL AGP.
Win98 and no registry tweaks.
Reply 663 of 673, by marxveix
Rage Pro, Rage XL, Rage 128 Pro are not the only ATi cards:
8-bit palleted textures should also work with Rage2 cards in D3D and CIF, just games speed can be lower on them.
I think all ATi cards between Rage2 up to Rage128 Pro and also ATi Rage Fury Maxx can use them at Direct3D level.
First ATi 3D Rage card did not have palleted textures, can test Rage 2 if needed to verify it and maybe Rage 128. 😀
Reply 664 of 673, by Joseph_Joestar
marxveix wrote on 2026-08-12, 13:14:
I looked at the "Windows 95 Programmer’s Guide" from this page and it does indicate that Rage II supports paletted textures.
If you have the card, try the Final Fantasy 8 demo on it. The config utility should detect paletted textures, if they are available.
My retro stuff
Reply 665 of 673, by marxveix
Joseph_Joestar wrote on 2026-08-12, 13:29:
There is no issue detecting it from ff config from Rage2, Rage2+,Rage2c. Ingame is another case, there its not 100% correct at least the menu and it can be driver issue.
Reply 666 of 673, by Joseph_Joestar
marxveix wrote on 2026-08-12, 16:07:
Interesting. Let me know if a different driver changes things.
Based on the current situation, I could only mark the Rage II paletted texture support as partial/inaccurate.
My retro stuff
Reply 667 of 673, by TheMLGladiator
I think that's one of the known bad drivers. I would recommend 4.11.2560 which can be found here: https://gona.mactar.hu/ATI3DCIF/drivers/w82560en.zip
Resources:
https://gona.mactar.hu/ATI_3D_CIF/ : More info on compatibility, focused on ATI 3D CIF but Direct3D compatibility follows from my personal testing
https://docs.google.com/spreadsheets/d/1hmx-K … dit?usp=sharing : Another resource shared with me by some members on The Retro Web. Haven't verified everything but seems correct from my experience.
Reply 668 of 673, by marxveix
TheMLGladiator wrote on 2026-08-12, 20:57:
I think that's one of the known bad drivers. I would recommend 4.11.2560 which can be found here: https://gona.mactar.hu/ATI3DCI […]
Resources:
Thank you for the table (spreadsheet). If anyone has older 4.03.2621 atid3d.dll from 13.05.97, please share, thanks!
Its question about atid3d.dll file if any Rage2 will work, already tested with some others, so far the same. I will try with Driver 1999 game also (maybe).
ATi Rage Pro / Rage XL AGP, all ok with that same driver, its my driver. For me its the best for Rage3 and it works for Rage2/3 D3D/CIF, cant be that bad. 😀
4.11.2611 drv is taken form 5.40.0/5.40.1 driver base and its files are from 5.40.0 up to 5.40.2 and some are from 5.3x, some files modified and newer.
Maybe error on that 4.12.2111 line, if you have 4.12.2111 driver, share it. https://disk.yandex.ru/d/eV600jDAliJ_3w/Win9x … 64_Rage_PRO?w=1
Reply 669 of 673, by marxveix
Rage2 is not supported by the game if i look readme at ff7 and ff8
Some ATi Rage II info about about paletted textures, but here its from BRender.
Re: ATi RagePro drivers and software
Reply 670 of 673, by Kahenraz
I was testing different Matrox cards today and noticed that both fog table (Thief) and paletted textures works (FF8) for the Matrox G200. This was surprising, because paletted textures is broken on the later G400-G550 in FF8. It doesn't require enabling a flag in Power strip. Actually, if you do enable it in power strip, FF8 breaks completely. Paletted textures works out of the box, unlike with the G400.
Other things I noticed was a lack of multitexturing (Unreal) and poor UI rendering in Incoming.
Reply 671 of 673, by Joseph_Joestar
Kahenraz wrote on 2026-09-11, 01:04:
Cheers! If you can post the relevant screenshots from FF8 and Thief 2, I will add this info to the wiki.
My retro stuff
Reply 672 of 673, by eddman
Joseph_Joestar wrote on 2022-11-26, 12:20:
Found another game which uses paletted textures: GT Interactive's Driver from 1999. […]
Graphics cards tested:
  • 3DFX Voodoo3 2000, using 3DFX reference drivers version 1.07.00
  • Nvidia GeForce FX 5900XT using Nvidia reference drivers version 45.23
  • ATi Radeon 9250 using ATi Catalyst reference drivers version 6.2
Games tested:
  • Driver - retail CD version + official patch version 2.1
Driver configuration utility
The attachment Driver_Config.jpg is no longer available
As expected, paletted texture support is detected on the Voodoo3 and the GeForce FX, while the checkbox remains greyed out and unselectable for the ATi Radeon card.
Driver Cross Town Checkpoint: Los Angeles 2
The attachment Driver_Checkpoint.jpg is no longer available
Among other things, Driver uses paletted textures for the neon signs in the city of Los Angeles. This is immediately visible if you start the Cross Town Checkpoint: Los Angeles 2. On the ATi card, the neon signs are completely static. In comparison, on both the Voodoo3 and GeForce FX the neon signs are animated using color cycling. This is much more apparent in motion, so please refer to this excellent YouTube video posted by @Rendar.
EDIT - added new info provided by Rendar.
Do you have a save file for that mission?
Reply 673 of 673, by Joseph_Joestar
eddman wrote on Today, 18:33:
Well, it's been four years since I tested that, so my memory is a bit fuzzy, but I think I had to activate cheats to reach that part of the game. I don't believe I had a save either, as that's probably one of the later missions.
Unfortunately, I can't really check right now. I had to move a few months back, so all of my retro hardware is currently sitting in storage, save for my WinXP system. Not sure when I'll be able to set up the rest of my retro rigs, since I don't have a lot of free space at the moment.
My retro stuff
