Any sense buying modern PSU for old hardware?
Reply 300 of 327, by Kasreyn
I opened up a Zasilacz Akyga Basic 700W (AK-B1-700) and took some pictures.
Better let people judge these components for themselves. But please comment with opinions.
Whether or not they want this to be the keeper of their retro treasures 😁
Scripts for fully automated partitioning and installation of GRUB bootloader with Windows 98 & Linux 7.0.11 & Memtest86+ v8.00. Can create BlueSCSI images or write direct to physical drive.
https://archive.org/details/make-win-98-dos-grub-loader
Reply 301 of 327, by Kasreyn
HWMonitor readouts can't be trusted on my 8K3A (running from Akyga Basic 700W (AK-B1-700)). That 5.6V would be much outside ATX allowed +4.75 V to +5.25 V tolerance.
With a multimeter I can see the +5V rail drop from 4.9V to 4.82 after starting Prime95.
Also with multimeter.. 12.7V on the +12V rail, slightly naughty.
Reply 302 of 327, by tehsiggi
The S30C45F dual-diode rectifier is rated for 30A whole device - all of the rails are rated above 30A. That's a red flag already.
The attachment Screenshot 2026-10-28 at 19.12.34.png is no longer available
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 303 of 327, by DaveDDS
Not necessarily. You have to think in "effective Watts" (VxA)
In a switching PS the primary regulator is typically handelling 110v/220v mains ... 30A at 110v is 3300 watts. Disregarding effeciency thats equivalent to 660A at 5V, 275A at 12V etc. The sum of what you can draw at lower (PCish) volrages greatly exceeds the draw from mains.
I'd have to see a schematic and go through a bunch of specs to guess at reasoanle numbers, but assuming mains AC->DC for switcher inputs, I can see 30A being lots for a pretty high end supply (std mains here in N.A. is 110v at 15A(fuse/breaker)) and I've not seen a "personal" system needing even close to that.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 304 of 327, by Mondodimotori
Kasreyn wrote on 2026-10-28, 17:54:
Those are... Not great but also not terrifying.
I have a 462 MOBO without p4 connector and, with an Athlon 1400C + Enermax vintage PSU, I get those voltages readings from Everest. If I had a multimeter I would test them directly. System is rocksolid but, as said, it's a vintage PSU that was probably a decent unit 20+ years ago. Now? Not so sure.
But even then, on that system + the chinesium PSU that claimed 25A on the 5V and max rating of 180W, on Everest the voltages would drop down to 4.6, so well outside ATX standard. And yet the system would POST and I would game on it no fuss.
Reply 305 of 327, by tehsiggi
DaveDDS wrote on 2026-10-28, 20:56:
That rectifier is for the secondary voltage. We're not talking the mains input rectifier here.
That one is used in any of the output rails and is rated at 30Amps max for both diodes together. And those rails are rated for more than 30A. So the math isn't working out. The current rating of the diode would be too low for any of the rails.
Reply 306 of 327, by DaveDDS
tehsiggi wrote on 2026-10-28, 21:39:
Fair enough, Like I said, I'd have to see circuits/specs to say for sure (which I don't care too 😀 )
I admit that it has been *MANY* years since I've designed a PSU, those being simpler, more dedicated and less generic than a PC one. I also know PSUs have increased in capability/complexity a lot since those days and I make no claim of knowing the ins/outs of "modern" ones.
But.. I do know that PSUs are more complex than most people think, and making "rash" judgments based on one component rating without more design details is likely to be inaccurate.
Reply 307 of 327, by Ydee
When I look at Akyga’s product lineup, I get the impression that it’s just one of many retailers selling Chinese-made products sourced from various suppliers, with price being the main criterion. Product quality is therefore likely to vary significantly from batch to batch, and while I don’t rule out the possibility that some high-quality products might be among them, I’d rather stick with tried-and-true brands. But to each his own...
Reply 308 of 327, by Mike_
tehsiggi wrote on 2026-10-28, 18:12:
That's at 100°C case temperature, at lower temperatures it should be able to do more.
Reply 309 of 327, by DaveDDS
Ydee wrote on 2026-10-29, 08:53:
... I’d rather stick with tried-and-true brands. ...
Agreed completely ... a PSU is NOT something you want to "cheap out" on!
Reply 310 of 327, by kagura1050
The fact that a high-power Schottky Barrier Diode (SBD) is attached to a heat sink strongly suggests that it functions either as a freewheeling diode for an internal DC-DC converter or as a component in a path that carries the bulk of the power for a given voltage rail.
In terms of quality, a design can hardly be considered "good" unless it uses a component rated for at least double the current of the rail—for instance, a 60A-rated part for a 30A rail. Relying on a component rated exactly for the operating current—or worse, banking on performance margins that only manifest at low temperatures—is, frankly, not a sound design approach.
古いマシンで新しいOS(Linux/NetBSD)を動かすのが好き。
All or most of the posts are created using Google Translate.
Timezone : UTC+9
Reply 311 of 327, by DaveDDS
Mike_ wrote on 2026-10-29, 09:06:
True, but without a spec for the lower temp, you can't base an informed decision on that. (and you want your stuff to be able to handle high temps that might occur for various reasone - not to mention you don't want to "hit the limit". 100 seems reasonable to me.)
Reply 312 of 327, by tehsiggi
It is not spec'ed to do more:
The attachment Screenshot 2026-10-29 at 10.10.23.png is no longer available
The datasheet also claims:
Peak Repetitive Forward Current
(Rate V R, Square Wave, 20kHz) - 30A
It's a 30A diode. Both diodes individually rated for 15A. It is not adequate for the task at hand. Might be that they have a second on the other side of the heatsink in parallel, but that'd be gambling as well, the one with the lower forward voltage would have to carry more load. And I doubt they did that.
And this is from the MOSPEC datasheet.. that up there is not a genuine mospec part, so I suspect it'll not be better.
DaveDDS wrote on 2026-10-29, 07:29:
This is just an ordinary cheap style ATX power supply. Cheapest capacitors, passive PFC, the mounting screw of the secondary side heatsink nearly pushing into the main transformer. I'd doubt there is any magic sauce in it. And the outputs of the transformer are usually center tapped windings per rail, meaning you need two diodes for rectification. They use a dual schottky like the one here. It's rated for 30A. The sticker claims more than 30A for each rail.
They basically lie, that's it. You can be lucky and the diode survives it's torture, but I wouldn't bet on it. This one looks, by the pictures, to be positioned to belong to the 3.3V rail - it's rated at 35A. It's neighboring dual diode might be for the 5V line and I wouldn't trust it to provide 38A either.
They took a design and slapped a sticker on it. It's a cheap PSU that, if you are planning to drive it to it's limits, should not be considered for a build.
Reminds me of the codegen one I posted here as well. That one btw, did die under high load with >32A on 5V.
kagura1050 wrote on 2026-10-29, 09:12:
It's just the secondary side rectifier for the 3.3V rail. So it just eats up the whole load of that rail. I completely agree, the rating is completely off.
Kasreyn wrote on 2026-10-28, 17:08:
Could you do some more, if possible:
- controller chip on the board
- inner heatsink side next to the transformer, basically the opposite of the (2S)D209L
I looks like for the 5V rail they might have slapped 2 double diodes together, but it's hard to say from that angle.
Reply 313 of 327, by DaveDDS
Yep, I agree - I've not looked at a schematic but if it is on the final output side and rated lower than stated rail output, if is indeed a lie, Stay away.
Even if it were rated 35a I'd still stay away. You want an overloaded PSU to fail by not providing the power you are requesting, not by catastrophic failure.
IME makers of cheap PSUs often lie - they are counting on the fact that very few users actually draw the rated loads (and users like big numbrs even when they don't need them)
Reply 314 of 327, by TELVM
Kasreyn wrote on 2026-10-27, 10:55:
... I am (so far) happily using the Akyga Basic 700W (AK-B1-700) without it blowing up. Powering my Athlon XP 2800+ Barton on EP […]
... I am (so far) happily using the Akyga Basic 700W (AK-B1-700) without it blowing up. Powering my Athlon XP 2800+ Barton on EPoX 8K3A.
These are inexpensive PSUs for the 38A they promise to deliver on +5V rail.
I ordered three and got free shipping for extra cheapness. CheapyD approves and much love to Poland.
https://www.csmegastore.de/i/1876828/akyga-ak … siv-300-w-384-w
Assessing the Quality and Performance of Akyga AK-B1-500 Power Supply Model
"... the Akyga AK-B1-500 is not considered a good PSU; it is described as one of the worst units on the blacklist and is better suited for parts than for powering a PC ... ... Both it and the Logic 400ATX are called “bottom” power supplies and are not recommended ... ... One reply reports very poor quality in this class of PSU: over 13 V on the +12 V rail, tacky capacitors, poor stabilization, and low efficiency ... ... The thread’s practical advice is to use it only if you must and only while it works, because failure can cause damage ..."
file.php?mode=view&id=251727
^ Screams "CRAP" even without looking at its guts. 👎 👎🏻 👎🏼 👎🏽 👎🏾
file.php?id=251677
^ Those are NPN Bipolar Junction Transistors. Efficiency must be "legendary".
Let the air flow!
Reply 315 of 327, by Kasreyn
Thanks guys, I appreciate the in depth analysis so far and I can take more up close photos of the internals.
I have to say though. If you find any capacitors that are a bit wobbly.. just add a dab of solder.
It's all good. Things will be fine. Be like PIPER . EXE.. stop worrying! 🤣
https://youtu.be/NeCGBbrEDhs?si=Sl1WHSpYYwuK3vix&t=297
PIPER.EXE doesn't stop just because there is a little smoke.
https://youtu.be/NeCGBbrEDhs?si=AmKhbkzs97xznCbQ&t=502
Reply 316 of 327, by TELVM
That "Akyga Basic 700W (AK-B1-700)" is a blast from the past, like a "new old stock" year ~2000 vintage budget PSU.
Topology is archaic: Half-bridge with BJT transistors on the primary, group regulation with rectifying diodes on the secondary.
Efficiency has to be atrocious, 66~75% at best. That means 33~25% of waste heat flogging the electrolytic capacitors. "SDCON" and "HANCCON" are cap brands known only to their mother.
However the heatsinks are flimsy. Even this crappy "350W" (in fact with 8/16A 13007 BJTs will probably explode above ~250W) "Allied"/"Oh Deer" of similar technological vintage and "quality" has beefier heatsinks:
file.php?mode=view&id=251808
file.php?mode=view&id=251809
I hope the fan regulation is very aggressive (relatively high RPM even at idle) to try to cool things down.
The D209L main switchers are rated @ 12/25A. No way they can deliver "700W", I'd expect them to explode above ~400W, give or take.
Could be just the angle of the pics, but I can't see any PI coils on the secondary.
Not clear from the pics, but it may have an archaic kind of circuit for +5VSB regulation.
That thing will power a "+5V hungry" retro-PC up to ~400W total draw, but with atrocious efficiency, dubious ripple suppression, and extremely unreliably caps.
Let the air flow!
Reply 317 of 327, by Kasreyn
Time for some additions to the previous photos of Zasilacz Akyga Basic 700W (AK-B1-700)..
Three out of six #1 #2 #4 I could not get a photo of before because they sit in very inaccessible areas behind other bulky components. #2 was in view but the text wasn't legible.
#1 #2 #4 have now been successfully photographed which you can see in the photos at the end.
In the first overview picture counting from left to right, bottom to top, they are:
#1 CTS P515S4 S30C45F - Located to the left on the left heat sink (bottom)
#2 HS 5SL010 MBR30 100CT - Located to the left on the left heat sink (middle)
#3 CTS P515S4 S30C45F - Located to the left on the left heat sink (top) (seen clearly in previous post)
#4 HS 5SL010 MBR30 100CT - Located to the right on the left heat sink (middle) (this sits on the opposite side in line with #2)
#5 HS 2521 DS09L - Located on the right heat sink (top) (seen clearly in previous post)
#6 HS 2521 DS09L - Located on the right heat sink (bottom) (seen clearly in previous post)
So there you have it. A bit more than previous photographs could reveal. To be honest I should have taken more time on the photos but I didn't want to take the PSU apart (and limited to 5 uploads). Unscrewing the board and lifting it out from the case is sort of required.
Reply 318 of 327, by Kasreyn
Solder side Zasilacz Akyga Basic 700W (AK-B1-700)
Reply 319 of 327, by revolstar
The cult/memeworthy forum Elektroda being referenced on VOGONS certainly wasn't on my bingo card for this week! 🤣
Win95 rig: Pentium II 400/64MB RAM/Matrox G400 16MB/Voodoo2 12MB/SB Live! + SB 128
Win98 rig: Athlon XP 2500+/512MB RAM/SB Audigy/GF FX5700
WinXP rig: HP RP5800 - Pentium G850/2GB RAM/GF GT530 1GB
Amiga: A600/2MB RAM
PS2, Ps3, Dreamcast
