Kasreyn wrote on 2026-10-28, 17:08:
I opened up a Zasilacz Akyga Basic 700W (AK-B1-700) and took some pictures.
Better let people judge these components for themselves. But please comment with opinions.
Whether or not they want this to be the keeper of their retro treasures 😁
Alright, since I haven't posted in this thread for a while, let me take a stab at this. 😉
The label promises 700 Watts of power, with the 3.3V rail capable of 35 Amps, 5V rail for 38 Amps, and 12V rail 32 Amps according to the website's PSU label. Let's keep all of these in mind. 😀
We start with these two pictures:
download/file.php?id=251679&mode=view
download/file.php?id=251677&mode=view
The main thing to observe here is the two NPN BJTs (D209L), the "ERL-35" main transformer, and the two small transformers next to it. From this alone, I can confirm with 99.999% certainty that this PSU is based on a half-bridge PWM topology - it's old (mid-late 70's design, IIRC) , it's not very efficient (almost guaranteed to never go above 80%... so 80_Minus (tm)?? 🤣 ), but it's also well-understood and simple to repair & maintain... a bit like an old carburated car, really. Nothing wrong with these designs when done/constructed with good parts, but they are just outdated.
What to know about this design:
Given the two BJTs, this PSU will have a relatively low switching frequency (mid 25 t0 35 KHz, typically). Low switching frequency means the output power will be lower for a given main transformer size compared to PSUs that use higher switching frequencies and/or more modern design. And in this case, the "ERL-35" main transformer is probably going to limit the total output power of the 3.3V+5V+12V+(-)12V rails to 300-350 Watts.
BUT!
All of the above is assuming all of the parts used in this PSU are of good, honest quality. Can we give this assumption a pass here?
- I think not. In fact, I'm almost certain of it, and here's why:
For starters, that "ERL-35" transformer might appear like any other, but what's often the case with these no-name manufacturers, especially the more modern ones, is they will try to cut every corner possible to save on costs. While the core size might adhere to the standard "35" size (35 x 42 x 12 mm EE or EI type), you can bet the copper windings inside are absolute bare minimum (Copper is a relatively pricey metal!) and/or not wound optimally to try and squeeze more turns in there for higher performance. As such, I wouldn't be surprised if the transformer core saturates below 300 Watts... never mind 350 Watts, which is what a proper ERL-35 core should withstand. More likely, I'd rate this PSU at 250 Watts maximum continuous. Anything more should be considered a gamble.
The D209L BJTs are also likely to be counterfeit and not from a genuine semiconductor manufacturer. In fact, this whole PSU reminds me of the KDMPower MIPC MI-X8775CD "775 Watt" PSU I showed some years back on BCN forums (link here... note: it's a very long read).
If anyone read through that thread, you should see the similarities between that PSU and this one pretty easily. In the case of the KDMPower MI-x8775cd, the two BJTs were a pair of E13009 's... which is more or less on par with the D209L 's... yet one blew open before the 3.25 Amp main fuse did. Does that tell you anything? For those who aren't into PSUs and power electronics, this highly suggests that the E13009 in the KDMPower PSU were bad counterfeits. A proper E13009 or D209L in such large packages (TO-3P and/or TO-247) should easily pass more current and blow such small fuse to dust if it ever shorted. Very likely these counterfeit parts have much smaller dies inside and are nowhere near capable of the specs listed on their labels. Remember this, because this is going to be a recurring theme in such cheap PSUs.
Next, we analyze the secondary (output) side with these three pictures:
download/file.php?id=252122&mode=view
download/file.php?id=252125&mode=view
And given this info:
Kasreyn wrote on 2026-11-02, 20:27:#1 CTS P515S4 S30C45F - Located to the left on the left heat sink (bottom)
#2 HS 5SL010 MBR30 100CT - Located to the left on the […]
#2 HS 5SL010 MBR30 100CT - Located to the left on the left heat sink (middle)
#3 CTS P515S4 S30C45F - Located to the left on the left heat sink (top) (seen clearly in previous post)
#4 HS 5SL010 MBR30 100CT - Located to the right on the left heat sink (middle) (this sits on the opposite side in line with #2)
#1 S30C45F is for the 3.3V rail. So total "raw" secondary-side limit for the 3.3V rail is 30 Amps
#2 and #4 MBR30 100CT 's are in parallel and for the 12V rail. So total "raw" secondary-side limit for the 12V rail is going to be roughly 40-45 Amps Amps
#3 S30C45F is for the 5V rail. So total "raw" secondary-side limit for the 5V rail is 30 Amps
And right away, I can tell you something is fishy up there, which tehsiggi spotted correctly and noted with the following comment:
tehsiggi wrote on 2026-10-29, 09:24:
And this is from the MOSPEC datasheet.. that up there is not a genuine mospec part, so I suspect it'll not be better.
Not only are none of the above non-genuine MOSPEC (or other known semi manufacturer) parts, but look at those S30C45F rectifiers again - they are in a TO-220FP (isolated) cases! 30 Amp rating? From a cheap no-name semiconductor manufacturer?? Not a snowflake's chance in hell!
These are more likely to be 20 Amp rectifiers with sanded off part numbers and new labels put on. (Yes, you'd be surprised to what lengths some counterfeit manufacturers will go to.) Or at best, they might be (don't bet on it) 30 Amp parts, but factory rejects... so no telling what they are capable of really.
But let's leave the above aside for a moment.
The reason I mentioned the words "raw power" in my previous text above is because this is the maximum limit of the rectifiers. Of course, one has to remember that if the PSU output filter (output caps and inductors) are not large enough / not up to the task, then the ripple and noise on the output could (and I bet it would!) go out of spec way before those "raw" limits are reached... meaning the PC / attached hardware will not be able to pull such large loads.
And that's the part we go into next - the output filtering. Starting with this quote:
TELVM wrote on 2026-11-04, 10:59:
Kasreyn I'm still unable to detect any PI coils on the secondary filtering +12V / +5V / +3.3V outputs. Looks like there aren't any present (bad news for ripple suppression 👎 )
There aren't any indeed (5VSB excepted).
And from what I can see, the 3.3V rail and 5V rail are both filtered by only a single electrolytic capacitor... presumably 2200 uF(?)
If that's the case, don't expect to pull more than 10 Amps from these before the ripple and noise goes out of spec.
I would personally say even this is too optimistic. I had a cheapo L&C PSU before - actually, very similar to the one that TELVM posted above, except mine was an even more "bare bones" version, with only one 2200 uF cap per rail. When I used that PSU 20 years ago to try and power up a Pentium II 400 MHz PC with nothing more than a single HDD and a very low power S3 Savage 4 (later changed to a Radeon 7000) GPU, I'd get frequent system lockups. Changing the PSU immediately solved those issues. The system hardly used more than 40 Watts from the 5V rail... but that was already enough to cause the noise and ripple to go out of spec.
So if we have to be realistic in regards to the 3.3V and 5V rail outputs of the Akyga AK-B1-700 shown here, I'd rate both of them at 10 Amps max each... and again, even that is probably a bit too optimistic *** (see below)
Furthermore, we can see from the construction of the output side (and also from the Youtube video of the 500W Akyga earlier) that despite the ancient half-bridge design, this PSU was geared/tweaked towards supplying most of the output power from the 12V rail. In that regard, we see the 12V rail has 3 electrolytic caps filtering it. I can't see what their values are... but even if they are only 1000 uF each, that 12V rail should still be capable of at least around 20-ish Amps of clean power (taking into account that there are no PI coils here.) With bigger caps, more could be pulled... but only up to a point.
This is where we move to analyzing the output toroid - that round thingy with all of the wires wound onto it. I can't quite gauge what size it is from the pictures, but I doubt it will be a T130-size core (i.e. 1.3 inches output diameter... or 33 mm for those of us (rest of the world??) who prefer metric 😉 ). More likely, it's T103-size (1.03 inches / 26 mm). Being also of the more lossy -26 type core (yellow color with one side painted white) and not the better and more expensive -52 core (light green with one side painted blue), that also kind of puts a combined limit on the 5V and 12V rails to about 200 Watts continuous and 250W peak.
So conclusions:
- this is a 250 Watt PSU * on a good day *. I'd be worried to try and push it to or past 300 Watts... which of course won't be possible, because the ripple and noise on the output will probably go out of spec before then... except *maybe* the 12V rail. And with those "Hangkon" output caps, don't expect them to last more than 5 years reliably. Well, maybe they will or maybe they won't - that's the problem with cheapo electrolytic caps (you just never know.)
*** In regards to the "too optimistic" comment above...
From my experiments with the KDMPower MI-x8775CD PSU and also from the Youtube video of the 500W Akyga, we can see the cross-regulation of these cheap no-name PSUs is absolutely dismal. Load the 12V rail a bit more or don't load the 5V rail enough and the 5V rail goes too high / out of spec. Conversely, load the 5V rail even a smidgen without much load on the 12V rail, and the 12V rail goes too high on voltage. This is NOT GOOD!
So in regards to using it for a retro PC - that would be a hard NO in my book.
Well, that's all from me for today - hope you enjoyed the wall-of-text a little. 😀
CharlieFoxtrot wrote on 2026-10-28, 10:26:
This is a new one for me, a scrap metal PFC!
Heh, that's a relatively old trick in these cheapo PSUs. Started around the mid-late 2000's, I think.
CharlieFoxtrot wrote on 2026-10-28, 14:26:
Faking passive PFC choke is something else. It's not like it is an expensive component and even manufacturing that fake one isn't free. Everything on that PSU is probably on a level that it barely functions.
Nothing to argue against that last sentence. Seeing what I did in my KDMPower PSU, the design is badly copied and there are quite a few glaring mistakes on the PCB, starting from the AC input. Mix in questionable / possibly counterfeit components, and it's no wonder why so many of these blow up "randomly".
As to the remark regarding PPFCs - yes, the PPFC inductor IS relatively expensive in regards to the other components in the PSU because it contains many winding of copper. Copper is not cheap. Around $14 per kilogram, currently. Compare that to steel, which is... eh, depending if you get any kind of plating or not on it.. about $1.00 to $1.40 per kg max. If one PPFC nets ~100 grams of copper inside, then 10 of them are about $14 worth of copper. When you include the labor to make them, that's raises the price even further. And FWIW, one of these cheap PSUs costs no more than $2-3 to make in China, but can easily sell for $7-10... often even $15-20 in richer countries. So you can see the numbers start to add up quickly and why corners are cut everywhere.
As for why fake the PPFC coil and not completely go without it - that's because it might be a requirement in some markets, like Europe. Of course, unless someone with the right knowledge and tools bothers to check, most of these cheapo PSUs pass a visual inspection to the authorities upon importation. But if/when they get caught: change the company name, change the label - hey now it's a totally different product! (until someone notices again).
Efficiency of that unit is also atrociously bad, perhaps around 50% or so, even less.
You'd be surprised. These PSUs will be more like in the low to mid 70's at more sane loads and sometimes peak or touch the 80% mark.
Granted this is far from great, I admit too.
But for powering an average Pentium II or 3 PC like they did back in the day, it's not a big deal. Those PII/P3/AMD K6 systems hardly used more than 60-70 Watts under load (the P3's more like 50 Watts with a mid-range DX7 GPU, like a GeForce 4 MX 440, and a single HDD.) At these low loads, modern (and much more powerful) PSUs also tend to have poor efficiency in the high 70's or low 80's. Dropping to low-mid 70's is not that big of a deal at 70W system load. A 70% efficient PSU will draw 100 Watts for that load. An 80%-efficient PSU will reduce that to about 88 Watts. So we are talking about a difference of 12 Watts. That's two average LED light bulbs worth of power consumption. I'm not saying it should be disregarded, but it's also not worth making a big fuss about either, IMO... unless you run that PC 24/7 and you live in a hot climate and/or somewhere with really expensive electricity.
