VST2Bridge
First post, by Trelokk
Introducing: VST2Bridge, a universal standalone VST2 bridge designed to run 32-bit VST2 plugins in 64-bit hosts and vice versa. This was until now only available in the form of paid software. This version however is free of charge, more stable and available to anyone who wishes to use it, for whatever purposes.
What does it do?
- After downloading the patcher (Win/Linux/Mac supported) and executing it, locate the plugin which you would like to bridge (e.g.: syxg50.dll). It will be found automatically in the patcher dir or can be located manually.
- The patcher will then generate bridges (in the same dir as the source plugin) for the opposite architecture, i.e. a 32-bit plugin receives a 64-bit bridge while a 64-bit plugin gets a 32-bit bridge.
- Windows users will get bridges in DLL and CLAP format while all the others receive CLAP only.
What is it good for?
- In case of the S-YXG50 for example, only 32-bit plugins are available. With a 64-bit bridge, these can also be loaded in 64-bit DAWs or other 64-bit software such as the Falcosoft MIDI Player (without having to keep a separate 32-bit version).
- Also supported is the latest CLAP feature in the popular Doom source port Woof!, currently available in latest dev snapshots only. You would need the plugin DLL, the CLAP bridge and the corresponding host exe (for the S-YXG50, it would require: syxg50.dll, syxg50_x64.clap and vst2bridge-host64.exe which go into Woof!'s "plugins" dir).
Reply 1 of 10, by Falcosoft
Very good product!
With the latest changes it is in full feature parity with JBridge and it is even much more stable!
The new test version of Midi Player uses this VST2 Bridge solution instead of JBridge and it works perfectly:
https://falcosoft.hu/midiplayer_67_test.zip
Website, Youtube
VST Midi Driver Midi Mapper
Reply 2 of 10, by Trelokk
Some speed and stability optimizations are still in the works. 😉
Reply 3 of 10, by Falcosoft
Trelokk wrote on Yesterday, 22:00:
During my testing I had absolutely no stability problems. Do your 'speed and stability optimizations' solve a specific problem or they are general ones?
I'm asking because it seems (at least) for me that some of them are questionable from the perspective of 'stability'.
https://github.com/NightFright2k19/VST2Bridge … ment-6671482491
BTW, I have measured the overhead in case of really heavy plugins like the S-MU2000 and Nuked SC-55 based ones and I experienced less than 5 percent. In case of lighter plugins the percentage value can be higher but in case of these light plugins the overhead does not really matter.
So overall I'm not sure that for 1 or 2 percent performance improvement we should risk stability.
Website, Youtube
Reply 4 of 10, by Trelokk
Well, what has been made does not seem to cause problems. It can be kept as-is now and nothing further will be done in that direction.
Reply 5 of 10, by Falcosoft
Trelokk wrote on Today, 11:32:
I think it CAN cause problems. I made ChatGPT generate a test case for the potential problem. Please, show this to Claude. I'm curious what it reacts to it.
There are 2 possible runs. One uses the state before the optimization while the other uses the state after the optimization:
race-test.exe --pre
race-test.exe --post
The attachment VST2Bridge-Audio-Race-Comparison.zip is no longer available
Website, Youtube
Reply 6 of 10, by Trelokk
Analysis is done and the bug has been found/fixed. Should this resolve everything, I guess this should be left alone. Reverting to pre-PR22 is something that should only be considered if there's really no other way.
Reply 7 of 10, by Falcosoft
Trelokk wrote on Today, 13:55:
I do not think that this workaround fully fixes the problem. It cleverly only bypasses the case demonstrated by the test 😀
As I said in the comment section of the original PR the only real solution would be to publish msg and depth together as one atomic value and read that value in both the wait and dispatch paths.
The remaining problem is that the DLL still reads msg and depth separately.
A delayed wake-up from the previous audio block can put it into the dispatch check for the next block.
If it reads just before the helper clears it, then it reads the new depth just after the helper raises it then finally it can still dispatch early.
Website, Youtube
Reply 8 of 10, by Trelokk
Alright. Reverting PR 22 now. After that, no further messing around with the code. It's finished.
Reply 9 of 10, by Falcosoft
Trelokk wrote on Today, 14:41:
I did not even mention reverting the full original PR. I just mentioned how the problem should have been really fixed.
Can I try to solve it the way I think it should work?
This way you could preserve the performance boost + the original Multimedia Class Scheduler related optimizations + Linux/macOS socket improvements.
I cannot test the Linux/macOS socket improvements but I can test all the Windows related changes.
@Edit:
Thinking about this a little more you may be right. Since there have not been any detected problems with the original implementation so far, it does not make much sense to 'fix' it.
Website, Youtube
Reply 10 of 10, by Trelokk
Autobuild r20 should work again as expected. 😀
