Reply 240 of 255, by FullYes
775. Had time to do a quick benchmark at 3.73Ghz with the e5800. Tried 3.8GHz but got BSOD in 3dm99. Might see if the other e5800 has more headroom, though at these speeds I’m also borderline on the chipset
The attachment IMG_0229.jpeg is no longer available
The E7500 still edges the E5800 in the lobby benchmark, despite a 600MHz clock disadvantage and a much lower memory clock (but tighter timings, realised now I forgot to put those in, but they are the 3-4-4-8 for the E5800) tomorrow I’ll see if I can tweak these a bit
System 1: K6-3+ 600MHz! MS-5158 (430TX), Voodoo3, AWE64
System 2: Athlon XP-M 2800+ SL-75KAV (KT133A) FX5200
System 3: 775i65g (work in progress) FX5900XT
System 4: i7-2600k, P8P67-M, GTX 460
Reply 241 of 255, by FullYes
2.5-3-3-6 is as good as it gets. 2-3-3-6 also works but doesn’t seem to provide a benefit in any of the benchmarks. I’m not sure this setting is actually applied in the bios
Seeing if I can find any stability problems now with this setup at stock everything.
I might use the case from my i7 for this build and find another for that. The i7 doesn’t need to have any drives, which gives some more options
Reply 242 of 255, by FullYes
Somebody stop me! (It will probably be the wife)
I’ve accidentally bought another PC. I wasn’t planning on it. I was innocently searching eBay for a case for the 775 system - I decided to list the Athlon system to see what would happen: So far, absolutely nothing.
As i said, I was only searching for a case. Preferably something matx. I found a couple of dell OEM cases that would have fit the bill, nothing as fancy as the Antec case I found for the Athlon.
I started looking at Antec stuff. As far as i know, they don’t make much in the way of matx stuff. But I was looking anyway, when I found a sonata case. Complete with some vintage hardware
The attachment IMG_0292.png is no longer available
The attachment IMG_0294.png is no longer available
Can anyone guess what spec it may be from these images? It’s taken me a while, but I have been able to deduce what the board is and what the GPU is. It was much harder to figure out than the MESH PC I bought containing the FX5900XT was
Reply 243 of 255, by FullYes
A few posts ago, I mentioned I had another socket 775 system I wanted to dig out and play around with. Turns out I was wrong!
Behold the magnificence of this Lenovo c205!
The attachment IMG_0332.jpeg is no longer available
It has been sat on the floor in the corner of my office for the last 6 or 7 years. My brother passed it onto me from a house clearance he was involved in.
The original plan was to reset it and sell it. It was “windows 10 ready” so I upgraded it. Big mistake. It barely runs. I think the upgrade took most of a day. I may have even left it overnight to complete. After that I must’ve lost interest and so it remained until now.
I got the specs totally wrong. I thought it had an e7200 or similar in it, but it actually has something much worse. An AMD E-350! Apparently it’s similar to an atom. I’d never heard of it.
It needed a good clean. I have done a mediocre one
The attachment IMG_0334.jpeg is no longer available
I managed to get into windows. Only took half an hour.
The attachment IMG_0336.jpeg is no longer available
Ah. It only has 1.5Gb of RAM?? I guess that could be the problem.
The attachment IMG_0337.jpeg is no longer available
Oh it has a spare slot! And I have some laptop ram kicking about. Time for an upgrade
Reply 244 of 255, by FullYes
So now it has 6Gb RAM (5.5Gb usable - the GPU has the other 512Mb) it is much better. I did not have 2 x 4Gb DDR3 to max it out at 8Gb. But it has made a huge difference.
The attachment IMG_0339.jpeg is no longer available
I’ve been on the Lenovo website (on the machine itself!) to see what windows xp drivers it has. Apparently it only shipped with windows 7, but I’m pretty sure there will be wide ranging xp support
The plan is to have this machine in my garage for a quick reference to a computer catalogue I use called etka. It used to be widely viewable online but it’s all behind paywalls these days. The version I have works on NT/2000/XP only
Of course I’ll be doing some completely unnecessary benchmarks on it 😬
Reply 245 of 255, by FullYes
That’s the C205 all done. WindowsXP works great on it.
Benchmarks. It’s about 2x the speed of the socket 7 system in 99max and does fairly well in 2000 and in 2001 before tanking in 03/05/06
The attachment IMG_0486.jpeg is no longer available
The attachment IMG_0487.jpeg is no longer available
The attachment IMG_0485.jpeg is no longer available
The attachment IMG_0488.jpeg is no longer available
The attachment IMG_0490.jpeg is no longer available
Time to move onto something more interesting now. The Antec sonata case filled with mystery hardware has finally arrived!
Reply 246 of 255, by RetroPCCupboard
FullYes wrote on 2026-01-10, 17:09:
RetroPCCupboard wrote on 2026-01-10, 10:46:
FullYes wrote on 2026-01-09, 19:49:
New CPU day! I just couldn’t help myself (I may have a problem!!) and bought a k6-3 for the socket 7.
Yes. You have a problem. It will probably get worse. You have the retro bug, and there is no cure.
Congrats on your purchase! Hope you have lots of free space in your home for the next retro PC you buy. 😀
No I’ve definitely reached my limit now. I promise!!
Told you!
Reply 247 of 255, by FullYes
Haha. You got me!
I am definitely not going to have any more machines, unless I stumble on a 486 (eek)
It also doesn’t look like I’m selling the Athlon setup either. (No interest at what it cost me)
This other system I’ve acquired. I will be selling it off, and just retain the case and the interesting GPU…as I really have no reason to keep the rest…
On that subject. Here it is!
The attachment IMG_0492.jpeg is no longer available
The attachment IMG_0493.jpeg is no longer available
It’s in much better condition externally than I was expecting
The attachment IMG_0494.jpeg is no longer available
The attachment IMG_0495.jpeg is no longer available
It’s also pretty dust free inside
The attachment IMG_0491.jpeg is no longer available
It looks like it was a prebuilt machine. I didn’t ask for it and it wasn’t in the ad, but the seller sent me all of their original manuals.
Time to check the internals
Reply 248 of 255, by RetroPCCupboard
Nice. Hope the new PC internals are good. Have you used that force feedback wheel yet?
Reply 249 of 255, by FullYes
Removed the ducting for the CPU fan. Interesting solution to airflow. All in the name of reducing noise apparently!
Now I can see the GPU properly
The attachment IMG_0496.jpeg is no longer available
It’s a Quadro FX 1000, similar to an FX 5800. Nice! This will go well in the Athlon machine.
The motherboard is a socket 478 ASUS P4P800-E Deluxe. A very nice board with lots of features. Unfortunately, it very much needs a recap
The attachment IMG_0497.jpeg is no longer available
I decided to see if it would fire up. No shorts and PSU voltages look good. Let’s do it!
The attachment a012fc3b-06ae-49f0-9f01-fdf158c47828.jpeg is no longer available
The attachment 0a978216-d3e3-4516-8522-b6b38b290c6b.jpeg is no longer available
It works! So I stuck a hdd in it and did a win98se quick install on it. Both DVD drives seem to work but the floppy drive needs attention. I could not get it to read my memtest86+ floppy. Didn’t try any others. I used one of my external usb floppy drives instead
The CPU is a 3.2GHz Prescott. Nothing exciting unfortunately!
It has 4 x 512MB Kingston RAM installed. It must have been upgraded at some point as their is paperwork for Corsair ram
The attachment IMG_0498.jpeg is no longer available
Reply 250 of 255, by FullYes
RetroPCCupboard wrote on Today, 17:01:
Yes I used it for a few weeks playing nfs:Porsche. It works well but the bulb for the light on the wheel doesn’t work
Since I got the wheel I also got the joystick and joypad from the same range. Neither are boxed unfortunately. The joystick comes with a usb adaptor that I think will work on the joypad and possibly the wheel as well. Microsoft put out some great stuff around this time. Both of my retro mice are Microsoft optical usb ones that work through a ps/2 adaptor
Reply 251 of 255, by RetroPCCupboard
FullYes wrote on Today, 16:41:
Any games in particular you want the 486 for? I think most will work on your socket 7 machine.
I bought a 386 because I couldn't resist the price (£40), and because I want a machine just for the old point and click adventures and for some authentic software development to make DOS games. Yes, I can do either of those things on my Socket 7, but there is something nostalgic about having to wait for the computer a bit.
I haven't built the 386 yet though, as it requires me to make a custom case. It is from an OEM system, and the seller had stripped it from the case.
Reply 252 of 255, by RetroPCCupboard
FullYes wrote on Today, 17:20:
It is strange to me that the gameport versions of the wheel and Joystick are relatively cheap. Seems nobody wants them, but they are great devices.
Reply 253 of 255, by FullYes
RetroPCCupboard wrote on Today, 17:21:
Any games in particular you want the 486 for? I think most will work on your socket 7 machine. […]
Yeah basically I would have it as a full dos machine, totally un-necessary!
Now I have the k6-3+ and xp-m I can slow both machines down to improve dos compatability too. I’ve yet to find a game that wouldn’t work on either of them. I’ve had more trouble running stuff on the socket 7 than the Athlon weirdly. But something that doesn’t work on one seems to work on the other
Reply 254 of 255, by FullYes
RetroPCCupboard wrote on Today, 17:26:
I’ve never had them before. Friends of mine had them and rated them very highly. I got by for years on a generic 4-axis 4-button stick and 8 button joypad (4 of the buttons were actually mapped to 2 of the analogue axies)
I’ve yet to try the stick, but the joypad works perfectly. And I think both of them cost me less than £10 all in
Reply 255 of 255, by FullYes
So the 478 machine works, but it’s not stable. Not really a surprise. Installing win98 and drivers was trouble-free. But stress testing and benchmarking is problematic at best.
I have been able to complete 1 run of 3dmark99 max so far and that’s it!
The attachment IMG_0499.jpeg is no longer available
Based on these results it’s a bit faster than the Athlon here. (CPU score) Nothing crazy between them.
One thing I do notice on the Athlon on the SDR board, in this benchmark is stutter in The 2nd game. When you round the corner towards the end and look back through the green glass. This system and the 775 are much smoother here.
