First post, by Aaron75
Hi all, joined the forum in 2020 but only posting now due to some new found interest in an old project. Feel free to correct me if i'm in the wrong section.
In mid 2020 i bought an Olivetti PCS44/c 486 PC , which included a matching CRT, keyboard and printer, and have since bought a matching Olivetti branded mouse to complete the setup. I got the system working after soldering a new battery holder to the board, which allowed me to get into the CMOS setup utility and change some HDD related settings so that it could boot. It has the factory installation of Windows 3.1 still loaded on the system, which interestingly was registered to the Thorn EMI electronics company no less. Like a few older laptops I've had the setup utility runs from the HDD rather than an on-board ROM chip, so i'll stick with the original HDD for now to save messing around with recovery disks.
Currently the specs are as follows:
Intel i486 SX running at 25MHz
128mb HDD
640kb base memory
3072kb extended memory
384kb dedicated memory
4096kb total memory (All of which is built into the board, with just one singular slot for expansion)
As far as I can tell it dates from around 1994, which makes the PCS44/c a rather mid-range but respectable PC of the time.
My aim for this PC is to make some period upgrades so that it can handle some light DOS gaming (as it can barely run the flying windows screensaver at the moment!). Since I usually only mess around with 98/XP era retro machines the 486 environment is totally new to me, so I hope that i can seek some upgrade advice.
Sound
The PC doesn't have any onboard sound or sound card from the factory, so my this is one of my top priorities. I had a Sound Blaster Vibra 16 on hand, but shortly after digging it out i noticed some leaking capacitors, so I went on eBay and got a Crystal CX4235 ISA sound card instead. Ifollowed the installation steps from Phil's computer lab's video on this card (https://www.youtube.com/watch?v=3-UdeiE2bVY&list=WL&index=21) and successfully initialised the card as instructed. However, i'm not sure how to make it work in Windows 3.1, so any advice on this would be appreciated.
Memory
I plan to populate the single empty RAM slot to increase the memory, although i'm not sure what kind of stick I'm looking for. I believe it to be called SIMM RAM, and if so, will any capacity work or will my board be restricted to a certain amount?
Graphics
The PC currently has onboard graphics, so I'm wondering if it's possible for me to install a better card in the ISA slot to increase performance. Any eBay recommendations on a suitable, low cost card?
An extra CPU
The current 486SX processor is soldered to the board, but i noticed another socket on the board which looks like another CPU socket. Am I right in saying I can put an upgraded processor in this socket alongside the existing one, or is it for something different? Pics of board attached.
In terms of storage, I don't plan to add a CD ROM or CF card adaptor just yet due to the on-HDD BIOS setup playing havoc when I attempted this previously. I would add another IDE controller, but unfortunately it looks like i'm all out of ISA slots now. I would also like to try some basic networking, but again any hardware i do use will have to be external due to the slots being fully populated
Attached is photos of the PC and motherboard.
Any advice would be very much appreciated!
Thanks in advance,
Aaron
Reply 1 of 16, by davidrg
First thing I'd do if it has the original factory install of Windows is image the hard disk. I still to this day regret not doing that for a DECpc LPv+ 466d2 around 15 years ago - I just casually blew away the factory windows install (with default DEC wallpaper, OEM programs for creating disks, etc) one day in an unsuccessful attempt to use the machine as a linux firewall. I could have just put a different hard drive in. Or imaged the existing one. But no, I wiped it.
As for upgrades - I'd put a network card in it if you've got a free slot after adding other more important things (sound card). Getting stuff on and off vintage computers using the LAN is a whole lot easier than floppy disks and serial cables.
I assume the machine takes 72 pin fast page memory modules (hard to tell from the picture). I don't know what the upper limit is but my box of FPM mostly seems to be 4 and 8MB SIMMs so I assume they're pretty easy to come by.
Reply 2 of 16, by Cuttoon
davidrg wrote on 2022-04-16, 23:24:
Yep, if it were 30 pin SIMMs, there would not be a single one of them empty, but four at a time.
RAM, Populate both sockets with 8 MB modules. A 486 should have 16 MB of RAM.
That socket, afaik, if it were populated OEM, the solder spot would be empty. So, put a DX2-66 in, see what happens - probably will have to engage some jumper to have it know - never hurts to have a proper manual for those things.
Graphics, it seems that you could upgrade the onboard with 512 more kilobytes. Will afford you higher Windows resolutions or color depths, not important for 1994 or earlier DOS games.
New card, only if possible to deactivate the onboard via jumper or bios. Onboard is a Cirrus Logic GD542x, I assume - you could do worse.
sound:
https://www.pc-schnulli.de/hardw/skisa/sktr/cx423x_w31x.rar
have fun!
I like jumpers.
Reply 3 of 16, by Cosmic
That's a really dreamy PC. I love how curved and bubbly the monitor is.
I found the manual for the PCS44 on Archive.org: https://archive.org/details/cap36_201908/cap35/
JUMPER JP1 Not installed: i486 SX processor soldered. Default setting. Installed: i486 DX or i486 DX2 coprocessor soldered (not […]
JUMPER JP1
Installed: i486 DX or i486 DX2 coprocessor soldered (not available on the M300-28/PCS44).
NOTE: If the i487SX or the Overdrive Coprocessor is installed in the coprocessor socket,
there is no need to set this jumper since the system will automatically detect that one of these coprocessors are present.
It sounds like this particular system doesn't come with a coprocessor but you could add one to the unpopulated socket, no jumpers needed. Maybe it also means you could install an OverDrive? There's an "ODP" variant that sits in its own socket and replaces an onboard/soldered CPU.
Each 486 Overdrive typically came in two versions, ODP and ODPR variants. The ODPR chips had 168 pins and functioned as complete swap-out replacements for existing chips, whereas the ODP chips had an extra 169th pin, and were used for inserting into a special 'Overdrive' (Socket 1) socket on some 486 boards, which would disable the existing CPU without needing to remove it (in case that the existing CPU is surface-mounted).
Rigs: Harris 286-16 [WIP] | Am386 DX-40 | i486 DX4-100 | MMX 233 | K6-III+ 600 | P!!!-S 1.3GHz | XP 3200+ 2.3GHz | Q6600 3.2GHz
Reply 4 of 16, by Aaron75
Cuttoon wrote on 2022-04-17, 01:45:
Yep, if it were 30 pin SIMMs, there would not be a single one of them empty, but four at a time. […]
sound:
have fun!
Cosmic wrote on 2022-04-17, 03:36:
That's a really dreamy PC. I love how curved and bubbly the monitor is. […]
JUMPER JP1
Thanks for the replies, they've been very helpful!
I've decided against a separate video card for now, and will look into a network card of some sort instead. As you say this can be a good way for transferring data, which also saves me from struggling with various storage options. Good advice on imaging the original Windows installation too, I'll do this as soon as possible.
Since the PC only has one RAM socket, i'll find an 8mb stick to put in for now to bring it closer to the recommended 16mb.
Interesting to hear that the empty socket is for a CPU, I'll try a DX2 for now and maybe even an overdrive at some point!
And thanks for the links to the sound drivers and manuals, they'll come in very handy. Hopefully I'll get back at some point with some progress!
Reply 5 of 16, by davidrg
For imaging the hard disk, I've successfully used NCommanders DOS Disk Dumper recently though this is easiest to do if the machine is already on the network with a mapped network drive you can dump the image to. A boot disk with a network client on it is probably the easiest way to do that if you want to take an image before setting up any network stuff on the hard disk. Or if you've got a null modem cable there is one for dumping hard disks over serial but I'm not really sure how that one works.
Reply 6 of 16, by Cuttoon
davidrg wrote on 2022-04-18, 20:47:
slooooooooooooooooooowly!
There actually was a system to connect two PCs point to point via the parallel port, called "laplink". So far haven't tried it out but bound to be significantly less slow than serial...
Smaller harddrives you can dump on a parallel attached Zip drive, as well 😉
I like jumpers.
Reply 7 of 16, by biessea
Hi, I am coming late here, but I never seen this thread!
I have the same machine, and I can say I learned a lot from it, and then thanks to my friend I upgraded too.
Beginning about the RAM, yes the system has originally 4mb of RAM but you can expand with more RAM in that slot, remember to put a parity module here, I upgraded with a 16mb of RAM. I put the photo of the module I bought. It runs perfectly.
About the graphic part, the Cirrus Logic GD5428 chip can be upgraded with another 512kb of Vram yes, I will put the photo of exact module that you have to find in the attachments. Now Windows 3.11 can run in higher resolutions!
I made the battery replacement too, as you did I see.
If you need I have the floppy image of the setup disk that you need to enter and write cmos of the system.
I put a Sb Awe64 on the ISA slot to have better sounds too.
The system now works flawlessy, and it is beautiful!
Computer lover since 1992.
Love retro-computing, retro-gaming, high-end systems and all about computer-tech.
Love beer, too.
Reply 8 of 16, by Aaron75
biessea wrote on 2024-07-12, 15:07:
Hi, I am coming late here, but I never seen this thread! […]
Hey there, just logging in for the first time in a while. Great to see another Olivetti receiving some upgrades!
Reply 9 of 16, by biessea
Aaron75 wrote on 2024-09-20, 11:56:
Thank you very much my friend! I really appreciate! It was an hard work but when you finish it, great memories remains!
Love beer, too.
Reply 10 of 16, by rasz_pl
Damn that case looks lovely.
https://theretroweb.com/motherboards/s/olivet … 4-6x-pcs4xx-t-1
Too bad about the budget ET6000 chipset with no cache support 🙁 Still with DX2/66 its just about ok for Doom.
Reply 11 of 16, by EmberBlitz07
Aaron75 wrote on 2022-04-16, 17:06:
Hi all, joined the forum in 2020 but only posting now due to some new found interest in an old project. Feel free to correct me […]
128mb HDD
640kb base memory
Sound
Memory
Graphics
An extra CPU
Thanks in advance,
Aaron
Hello, do you know the model number of the riser card? Got this mobo myself and just need to get the riser + need to know if it has AT or proprietary power.
Intel Pentium II 400MHz ✅
S3 Trio 3D/2X 4MB ✅
128MB SDRAM ✅
Siemens Nixdorf D1064 ✅
AZTech AUDIO TELEPHONY 3500 ✅
Quantum Bigfoot TX 8GB with IDE connection and Molex power support
Reply 12 of 16, by rasz_pl
oh you might be screwed with the riser, its Olivetti proprietary
judging by same 106pin connector same riser used by https://theretroweb.com/motherboards/s/olivet … -60-62-64-65-66
includes battery and some buffering (probably for bus mastering steering)
psu seem to connect to riser and is proprietary
looking at those pictures I dont think I would be able to figure it out 100% without some measurements
Reply 13 of 16, by EmberBlitz07
rasz_pl wrote on 2026-11-08, 02:36:
oh you might be screwed with the riser, its Olivetti proprietary judging by same 106pin connector same riser used by https://the […]
Someone is selling the Olivetti PSU for £30 on eBay, which is definitely wild for an untested PSU. Might shoot an offer if I get the money at some point then that should hopefully be that sorted when I get the riser, should the offer be accepted. Will definitely keep the diagram in mind though
S3 Trio 3D/2X 4MB ✅
128MB SDRAM ✅
Reply 14 of 16, by EmberBlitz07
There's also someone in the US selling the complete setup, I'm not interested in buying it all but I am interested to see if they'll get photos of the riser card.
S3 Trio 3D/2X 4MB ✅
128MB SDRAM ✅
Reply 15 of 16, by rasz_pl
EmberBlitz07 wrote on Yesterday, 03:37:
totally useless to you as its only proprietary aspects are
1 shape so it fits in original case you dont have
2 plug which you have nothing to plug into 😀
Reply 16 of 16, by EmberBlitz07
rasz_pl wrote on Yesterday, 03:54:
totally useless to you as its only proprietary aspects are 1 shape so it fits in original case you dont have 2 plug which you h […]
Hence why I'd get the riser beforehand.
S3 Trio 3D/2X 4MB ✅
128MB SDRAM ✅
