RReady (Rendition Verite & CGL wrapper) Test Build (Alpha 1)
Reply 3540 of 3546, by robertmo3
sharangad wrote on Today, 09:49:
Is the starting position supposed to be the same for both software and VLB carpet.exe?
i don't know, probably yes - you can more less tell that by looking on the map and compare both versions.
there is a spell in front of you so if you just bow down and move forward you shold hear the sound of collecting it
Reply 3541 of 3546, by sharangad
robertmo3 wrote on Today, 10:50:
there is also a readme for all the tools there (mostly for 24fps patch)
https://github.com/raincz/mgcarpet/blob/maste … tools/README.md
Thanks!
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3542 of 3546, by robertmo3
Magic Carpet, part of the HUD near the health bar flickers and disappears. I don't know if this is normal?
check how it is in software. the 3 icons of wizard, heart and ball flicker to (i think) signal you are invincible for some time. later when you become vincible they should stop blinking.
Reply 3543 of 3546, by robertmo3
Moving the mouse always seems to spin to the right, something's off with Dosbox-Rendition.
try using fixed amount of cycles and don't change them while in game
maybe something to do with joystick (disconnect/disable it)
Reply 3544 of 3546, by sharangad
robertmo3 wrote on Today, 11:21:
I'll try that. It happens when I move the mouse.
Reply 3545 of 3546, by sharangad
The mouse problem turned out to be [sdl]autolock. The Dosbox taskbar icon kept getting highlighted, so I disabled it to see if it fixes things. Now the mouse works.
Joystick was already disabled and lowering cycles down to 20,000 and 30,000 lowered the framerate, but not the mouse scrolling in one direction problem.
Now for the sprite problem.
Reply 3546 of 3546, by sharangad
Magic Carpet with sprite rendering, the fix for the sprites kills performance:
https://youtu.be/9O4bZ3JIZT4
It reuses the same part of VRAM for each sprite, overwriting it many many time each frame. I had to turn down the tracking speed on my trackball to get the controls usable, along with capping the framerate to 25 fps.
