Joseph_Joestar wrote on Yesterday, 05:28:
quigonhu wrote on Yesterday, 03:13:
I tried G400 MAX and TNT2 this week.
The result is intresting. Both of them could active the hardware acceleration without any issue!
Thanks for the detailed testing! That settles it then, the PC version of Metal Gear Solid doesn't require paletted texture support for enabling 3D acceleration. It's just a poorly coded console port.
This reminds me, I had a similar experience with Dino Crisis, another PlayStation port from around that time. It also had rendering issues on a GeForce 6200, while working perfectly fine on a Matrox G400 and even some Radeon cards. That too was completely unrelated to paletted textures. It's possible that Nvidia changed something else with their GeForce 6 series that caused rendering issues with some older games. Not surprising, as those cards are from 2004. At that time, most people were chasing the highest framerates in Doom 3 and Far Cry. I doubt old Win9x titles were much of a priority for Nvidia's QA department back then.
Yes, I noticed that test years ago, since then I realized the Table Fog & 8-bit Paletted Textures compatibility cound be a serious issue to the retro games.
I found an exactly same phenomenon on RE2, at the very beginning part, on the way to the police office, an iron fence gate besides an ambulance. Some graphic cards just show a dark flat board.
My personal experience is, tried to use some early era graphic cards, especially to nVidia's GPU.
The Voodoo 1/2 would be fine, none for 3 or later.
GF3 and before could be ok, but not for 4 or later. Plus, for the Geforce cards, select the Riva128 in the graphic card option , and keep the driver version older than v12.41.
ATI, didn't try at all since I don't have one.
G200/400 or later, be honest Matrox graphic cards have excellent compatibility to those early era 3D games, including RE1/2, good performance without issue. Espcially to the RE1, the G200/400 is one of the few graphic cards that perform almost no display issue at all. ( The other one which I tested was Voodoo1 )
